Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Categories
- All Discussions1,524
- General534
- Graphics109
- GPU Computing419
- Mobile141
- Pro Graphics163
- Tools158
Nvidia Quadro FX SDI video capture
Dear All,
Currently I'm working on an opensource project related to video capture from HD camera (1920x1080).
The project is at very beginning but already have a serious technical issue.
Aims of the project: Capture video from the HD camera using Quadro FX SDI video capture card and NVidia FX5800 graphics card for encoding.
Essence of the issue
After all successful initialization steps video capture has failed with an error.Please, see details below.
Issue description
In my research steps I was guided by NVIDIA Quadro SDI capture programmer's guide (http://www.nvidia.com/docs/IO/40049/PG-03776-001_v05.pdf) and OpenGL NVIDIA video capture extension (http://www.opengl.org/registry/specs/NV/video_capture.txt).
When I call VideoCaptureNV, I always get the following error:
INVALID_VALUE from the OpenGL extension. Please, see at the end of this question short description of the VideoCaptureNV method.
Really, I can't understand the reason for that. Unfortunately, I don't have a possibility to check whether the video capture works correctly with my parameters on Windows platform.
I've attached the test project sources to this question. It is a simple test application.
It consist of the following parts:
1. OpenGL initialization
2. OpenGL context initialization
3. Capture card initialization
4. Start capturing of video frames
Here is short excerpt from video_capture.txt document mentioned above:
enum VideoCaptureNV(uint video_capture_slot, uint *sequence_num,
uint64EXT *capture_time);
can be called to capture one frame of video. If no frames are
available, this call will block until frames are ready for capture
or an error occurs. VideoCaptureNV will return one of SUCCESS_NV,
PARTIAL_SUCCESS_NV, or FAILURE_NV. If the capture operation
completed successfully on all stream with objects bound, SUCCESS_NV
is returned. If some streams succeeded PARTIAL_SUCCESS_NV is
returned. If the capture failed on all streams, or if the capture
state on the specified slot is invalid, FAILURE_NV is returned. In
addition, the following GL errors are generated if FAILURE_NV was
returned because of invalid capture state:
* INVALID_OPERATION if any stream has both texture and buffer
objects bound.
* INVALID_VALUE if any buffer objects bound are not large enough
to contain the the data from the region they are bound to at the
specified offset.
* INVALID_VALUE if the dimensions of any textures bound do not
match the dimensions of the region they are bound to.
* INVALID_OPERATION if the base level of any textures bound has
not been defined.
* INVALID_OPERATION if the internal formats of any textures bound
to the same stream does not match.
* INVALID_OPERATION if automatic mipmap generation is enabled for
any textures bound.
If you need some other info, please ask me and I'll provide it in a moment.
Thanks to all in advance,
Alexey
video_capture.tgz40K -
5 Comments sorted by
I forgot to post the output from my test application. It is describes the error behaviour:
Getting matching framebuffer configs
Found 12 matching FB configs.
Getting XVisualInfos
Matching fbconfig 0, visual ID 0x25: SAMPLE_BUFFERS = 0, SAMPLES = 0
Matching fbconfig 1, visual ID 0xbb: SAMPLE_BUFFERS = 0, SAMPLES = 0
Matching fbconfig 2, visual ID 0x39: SAMPLE_BUFFERS = 1, SAMPLES = 2
Matching fbconfig 3, visual ID 0xcf: SAMPLE_BUFFERS = 1, SAMPLES = 2
Matching fbconfig 4, visual ID 0x3b: SAMPLE_BUFFERS = 1, SAMPLES = 4
Matching fbconfig 5, visual ID 0xd1: SAMPLE_BUFFERS = 1, SAMPLES = 4
Matching fbconfig 6, visual ID 0x49: SAMPLE_BUFFERS = 1, SAMPLES = 8
Matching fbconfig 7, visual ID 0xdf: SAMPLE_BUFFERS = 1, SAMPLES = 8
Matching fbconfig 8, visual ID 0x4b: SAMPLE_BUFFERS = 1, SAMPLES = 16
Matching fbconfig 9, visual ID 0xe1: SAMPLE_BUFFERS = 1, SAMPLES = 16
Matching fbconfig 10, visual ID 0x55: SAMPLE_BUFFERS = 1, SAMPLES = 32
Matching fbconfig 11, visual ID 0xeb: SAMPLE_BUFFERS = 1, SAMPLES = 32
Chosen visual ID = 0x55
Creating colormap
Creating window
Mapping window
Creating context
Created GL 3.0 context
Direct GLX rendering context obtained
Making context current
Number of active jacks: 4
===> Configured a double-link stream
Cycle 0
> Set bits per component
> Set signal format
> Set component sampling
> Set chroma sampling
===> Cycle finished. Begin data transfer preparations
===> Num devices: 1
===> ID matchs 768.
Device locked
==> Device bound
===> Buffer pitch: 5120
===> Capture has begun
Sequence num: 32720, timestamp: 4131212846
Frame 0 failured
Invalid value
Frame 1 failured
Invalid value
Frame 2 failured
Invalid value
Frame 3 failured
Invalid value
Frame 4 failured
Invalid value
Frame 5 failured
Invalid value
Frame 6 failured
Invalid value
Frame 7 failured
Invalid value
Frame 8 failured
Invalid value
Frame 9 failured
Invalid value
Frame 10 failured
Invalid value
===> Capture ended
===> Resources freed
It looks like the buffer is small for capturing but it big enough...
You need to use one internal formats for buffer bindings, eg. YCBYCR8_422_NV:
"The internal format of the pixel data stored in the buffer object can be
specified using the VideoCaptureStreamParameter functions described
below, with set to VIDEO_BUFFER_INTERNAL_FORMAT_NV and
set to a color-renderable internal format (as defined in
section 4.4.4), or one of the Y'CbCr/Y'CbCrA formats defined in
table 4.13. Specifying other internal formats will generate
INVALID_ENUM."
Addmittedly the spec example is wrong there. Let me know if that solves your issue and I will update the spec.
Thanks a lot for the provided info! I'll check it in 2-3 hours and let you know the status.
It works now! Thank you very much for the support! Actually, I've found a code example in Linux SDK which shows how to use VIDEO_BUFFER_INTERNAL_FORMAT_NV.
