• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 6.4
• JetPack Version (valid for Jetson only): NA
• TensorRT Version: 8.6
• NVIDIA GPU Driver Version (valid for GPU only): 535
• Issue Type( questions, new requirements, bugs): question
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing): NA
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description): NA
Related code:
NvDsObjEncUsrArgs userData = { 0 };
/* To be set by user */
userData.saveImg = false; // don’t save now
userData.attachUsrMeta = true; // attach encoded buffer
/* Set if Image scaling Required */
userData.scaleImg = FALSE;
userData.scaledWidth = 0;
userData.scaledHeight = 0;
/* Quality */
userData.quality = p_config->crop_encode_config.crop_quality;
/*Main Function Call */
nvds_obj_enc_process (p_config->crop_encode_config.crop_ctx, &userData, ip_surf, obj_meta, frame_meta);
I saved images using the buffers attached by nvds_obj_enc_process but I saw a lot of 0 byte images being saved. Do I need to skip invalid bbox before calling nvds_obj_enc_process? If so, how do I do that? deepstream-image-meta-test doesn’t include code for bbox validation before encoding.
These messages are printed to the terminal:
Corrupt JPEG data: premature end of data segment
Corrupt JPEG data: 1426 extraneous bytes before marker 0xd9
Corrupt JPEG data: 1404 extraneous bytes before marker 0xd9
Corrupt JPEG data: 18681 extraneous bytes before marker 0xd9
Corrupt JPEG data: 9162 extraneous bytes before marker 0xd9
Corrupt JPEG data: 41000 extraneous bytes before marker 0xd9
Corrupt JPEG data: 2477 extraneous bytes before marker 0xd9
Corrupt JPEG data: 41097 extraneous bytes before marker 0xd9
Corrupt JPEG data: 3337 extraneous bytes before marker 0xd9
Corrupt JPEG data: 10089 extraneous bytes before marker 0xd9
