lastes l4t release
# cat /etc/nv_tegra_release
# R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t186ref, EABI: aarch64, DATE: Fri Jun 26 04:34:27 UTC 2020
when i run
./video_decode H264 --blocking-mode 0 --disable-rendering /usr/src/jetson_
multimedia_api/data/Video/sample_outdoor_car_1080p_10fps.h264
video_decode freeze with output:
# time ./video_decode H264 --blocking-mode 0 --disable-rendering /usr/src/
Set governor to performance before enabling profiler
Creating decoder in non-blocking mode
Opening in O_NONBLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Setting frame input mode to 1
Created the PollThread and Decoder Thread
Starting Device Poll Thread
Capture plane not ON, skipping capture plane
Got V4L2_EVENT_RESOLUTION_CHANGE EVENT
Video Resolution: 1920x1080
Decoder colorspace ITU-R BT.601 with standard range luma (16-235)
Query and set capture successful
^C
real 0m22,321s
user 0m9,000s
sys 0m19,908s
In blocking mode video_decode work well.
