10 bit output Jetson TX2
Hi does the Jetson TX2 support 10 bit output or does it convert decoded 10 bit content into 8 bit and then output it?
Thanks,
Hi mzfern,
Do you mean HDMI output? 10bit output sw path is not yet supported on rel-28.1. Currently 8,15,16,24 color depth is supported.
Was able to verify that the output of the decoder is 10 bit.
HI mzfern,
What I implied is HDMI output but not the decoder output. Thanks.
Yes I realized that but I could not revert my accepted answer. Thanks though. I needed to know about the HDMI output too.
