I’m buying a SN2010 from HPE and I need a 1GB copper link. Datasheet list this one (JD089B - HPE X120 1G SFP RJ45 T Transceiver) as compatible, but not sure if I can stick this module directly into a SFP28 port of the switch. I think I read that for a QSFP28 you would need an adapter to place the module.
Thnx!
