This issue reproduces in L4T 32.4.3 as well.
Here’s the test command line we used. The nvinfer configuration is derived from the sample test application of DeepSteeam.
$ gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4 ! \
decodebin ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 \
height=720 ! nvinfer config-file-path=dstest1_pgie_config.txt ! \
nvvideoconvert ! nvdsosd ! perf ! nvegltransform ! nveglglessink sync=false
Then, we aggregated the result of lsof while gst-launch is running as above.
About 7000 dmabuf handles are generated on the whole of the system.
$ lsof | grep dmabuf | wc -l
lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/120/gvfs
Output information may be incomplete.
7075
Also the following is the breakdown of the result. The head number of each line shows the total occurrences of dmabuf handles for each command name lsof identifies. Dmabuf handles of compiz, gmain, gdbus and dconf\x20 reside regardless of the gst-launch execution. Others occur while gst-launch is running.
$ lsof | grep dmabuf | uniq -c --check-chars=9
110 compiz 6110 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
110 gmain 6110 6121 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
110 gdbus 6110 6128 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
110 dconf\x20 6110 6130 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
630 gst-launc 11580 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 cuda-EvtH 11580 11582 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
1575 gst-launc 11580 11583 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 typefind: 11580 11600 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 gmain 11580 11601 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 qtdemux0: 11580 11602 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
630 multiqueu 11580 11603 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 NVMDecBuf 11580 11605 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 NVMDecDis 11580 11606 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 NVMDecFrm 11580 11607 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 NVMDecVPR 11580 11608 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 V4L2_DecT 11580 11609 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 gst-launc 11580 11610 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 m:src 11580 11611 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
315 nvv4l2dec 11580 11612 nvidia mem REG 0,11 9649 anon_inode:dmabuf (stat: No such file or directory)
