107 kit app template can't load my stage
Trying to load my stage in kit 107 and it is trying to compile all of the shaders again. However, it seems to stop at a certain point and it doesn’t make any more progress. The app doesn’t crash, but the progress bar doesn’t move.
Ok thanks for the post, but I will some specific info. Can you do any of the following:
  1. send me the scene, fully collected
  2. send me a video of the scene trying to load and the errors
  3. send me the logs.
If it doesn’t load and doesn’t crash, maybe kit if out of memory. It will say this at the bottom. “Scene has stopped loading due to low memory”. Is it a large scene?
Try changing these three settings BEFORE opening your scene:
  1. Turn off FSD (fabric scene delegate) under Preferences > Rendering
  2. Turn off Texture streaming under Rendering Settings > Common > Debug
  3. Turn on “Disable Material loading” under Rendering Settings > Common > Debug (just to see if it will open the geo, without the textures first)
Is it a large scene? How much vram do you have?
