vandev
November 17, 2023, 2:04am
1
I am running gstreamer pipeline to decode H265 stream using Jetson Orin’s hardware decoder. I need to grab frames and process them in CUDA. Best solution I found so far was to use nvivafilter, but seems nvivafilter only supports NV12 or RGBA CUeglColorFormat. Both of these are only 8-bit. My incoming content is 10bit, is there a way to access the 10bit buffer from CUDA?
This is my current pipeline:
/usr/bin/gst-launch-1.0 filesrc location=<mp4> ! \
qtdemux ! queue ! h265parse ! nvv4l2decoder ! \
nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! \
'video/x-raw(memory:NVMM), format=(string)RGBA' ! \
fakesink -e
DaneLLL
November 17, 2023, 3:20am
3
It is not supported on Jetson Nano. 10-bit h265 stream will be decoded into 8-bit YUV420 on Jetson Nano.
vandev
November 17, 2023, 3:35pm
4
I am using " Jetson AGX Orin Developer Kit", not Nano. Is there a way to access the 10bit buffer from CUDA?
DaneLLL
November 20, 2023, 12:58am
5
Please execute the command and share the prints for reference:
$ cat /etc/nv_tegra_release
This topic is in Jetson Nano category, so we get confused. Would like to confirm which platform and software version you are using.
vandev
November 20, 2023, 4:02pm
6
Sorry, not sure how the category “Jetson Nano” is added, the device I use is Jetson AGX Orin Developer Kit:
# R35 (release), REVISION: 2.1, GCID: 32413640, BOARD: t186ref, EABI: aarch64, DATE: Tue Jan 24 23:38:33 UTC 2023
DaneLLL
November 21, 2023, 5:16am
7
Please refer to the sample:
Error generated while running the code after connecting the camera - #15 by DaveYYY
It demonstrates:
GstBuffer → NvBufSurface → CUeglFrame → OpenCV
You can follow the function calls to get CUeglFrame and access the buffer through CUDA.
The pipeline will be like:
filesrc ! qtdemux ! queue ! h265parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),format=P010_10LE' ! appsink
or
filesrc ! qtdemux ! queue ! h265parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),format=I420_10LE' ! appsink
And you can access the buffer in appsink
Besides, the latest release is Jetpack 5.1.2(r35.4.1). It would be great if you can upgrade to latest version.
