linuxdev:
You probably should run a serial console (which can log
to host even when most of the Jetson has crashed and burned)
and post the debug output as the crash or hang occurs.
Following is the bootup log from the serial console with the X300 connected
by 10G to the Jetson TX2. I assign an IP address and set MTU to 9000 for the eth1
ethernet adapter. Then I issue uhd_find_devices and uhd_usrp_probe commands. At
the latter the Jetson TX2 hangs and reboots.
[0000.271] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-f4c42291)
[0000.279] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.284] I> DMA Heap @ [0x84900000 - 0x85300000]
[0000.289] I> bit @ 0xd480000
[0000.292] I> BR-BCT relocated to 0xf7f20000
[0000.296] I> Boot-device: eMMC
[0000.300] I> pmic: reset reason (nverc) : 0x0
[0000.304] I> Reading GPT from 512 for device 00000003
[0000.310] I> Reading GPT from 8388096 for device 00000003
[0000.317] I> Found 6 partitions in 00000003 device
[0000.322] I> Reading GPT from 512 for device 00010003
[0000.328] I> Found 17 partitions in 00010003 device
[0000.334] W> No valid slot number is found in scratch register
[0000.339] W> Return default slot: _a
[0000.343] I> A/B: bin_type (16) slot 0
[0000.346] I> Select partition: bpmp-fw
[0000.350] I> Loading partition bpmp-fw at 0xf7600000
[0000.355] I> Reading two headers - addr:0xf7600000 blocks:1
[0000.360] I> Addr: 0xf7600000, start-block: 58739717, num_blocks: 1
[0000.375] I> Binary(16) of size 524480 is loaded @ 0xf7600000
[0000.381] W> No valid slot number is found in scratch register
[0000.386] W> Return default slot: _a
[0000.390] I> A/B: bin_type (17) slot 0
[0000.393] I> Select partition: bpmp-fw-dtb
[0000.397] I> Loading partition bpmp-fw-dtb at 0xf77f0000
[0000.403] I> Reading two headers - addr:0xf77f0000 blocks:1
[0000.408] I> Addr: 0xf77f0000, start-block: 58740925, num_blocks: 1
[0000.420] I> Binary(17) of size 326672 is loaded @ 0xf77b0200
[0000.547] I> BPMP-FW load address = 0xf7600000
[0000.551] I> BPMP-FW DTB load address = 0x501b0200
[0000.556] I> Loading SCE-FW …
[0000.559] W> No valid slot number is found in scratch register
[0000.565] W> Return default slot: _a
[0000.568] I> A/B: bin_type (12) slot 0
[0000.572] I> Select partition: sce-fw
[0000.575] I> Loading partition sce-fw at 0xf7800000
[0000.580] I> Reading two headers - addr:0xf7800000 blocks:1
[0000.585] I> Addr: 0xf7800000, start-block: 58741925, num_blocks: 1
[0000.594] I> Binary(12) of size 65088 is loaded @ 0xf7800000
[0000.599] I> Init SCE
[0000.602] I> Copy BTCM section
[0000.605] W> No valid slot number is found in scratch register
[0000.610] W> Return default slot: _a
[0000.614] I> A/B: bin_type (13) slot 0
[0000.617] I> Select partition: cpu-bootloader
[0000.622] I> Loading partition cpu-bootloader at 0x96000000
[0000.627] I> Reading two headers - addr:0x96000000 blocks:1
[0000.632] I> Addr: 0x96000000, start-block: 58732545, num_blocks: 1
[0000.643] I> Binary(13) of size 195776 is loaded @ 0x96000000
[0000.648] W> No valid slot number is found in scratch register
[0000.654] W> Return default slot: _a
[0000.657] I> A/B: bin_type (20) slot 0
[0000.661] I> Select partition: bootloader-dtb
[0000.665] I> Loading partition bootloader-dtb at 0x85300000
[0000.671] I> Reading two headers - addr:0x85300000 blocks:1
[0000.676] I> Addr: 0x85300000, start-block: 58733057, num_blocks: 1
[0000.687] I> Binary(20) of size 248032 is loaded @ 0x85300000
[0000.693] I> MB2-params @ 0xf7f00000
[0000.696] I> CPUBL-params @ 0xf7f00000
[0000.700] I> CPU-BL loaded at : 0x96000000
[0000.704] I> Loading TOS …
[0000.707] W> No valid slot number is found in scratch register
[0000.712] W> Return default slot: _a
[0000.716] I> A/B: bin_type (14) slot 0
[0000.719] I> Select partition: secure-os
[0000.723] I> Loading partition secure-os at 0x8490f400
[0000.728] I> Reading two headers - addr:0x8490f400 blocks:1
[0000.734] I> Addr: 0x8490f400, start-block: 58733569, num_blocks: 1
[0000.742] I> Binary(14) of size 54384 is loaded @ 0x8490f400
[0000.748] I> Copying Monitor (length: 0xd270) from 0x8490f600 to 0x40000000
[0000.755] I> Erasing Monitor @ 0x8490f600
[0000.759] I> Unhalting SCE
[0000.763] I> Waypoint2-ACK: 0x5200b8d0
[0000.767] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.2(release):ff7a644
NOTICE: BL31: Built : 21:06:35, Mar 1 2017
NOTICE: Trusty image missing.
ERROR: Error initializing runtime service trusty_fast
[0001.128] I> Welcome to Cboot
[0001.130] I> Cboot Version: 00.00.2014.50-t186-fabbc56c
[0001.135] I> CPU-BL Params @ 0xf7f00000
[0001.139] I> 0) Base:0x00000000 Size:0x00000000
[0001.143] I> 1) Base:0xf7e00000 Size:0x00100000
[0001.148] I> 2) Base:0xf7d00000 Size:0x00100000
[0001.152] I> 3) Base:0xf7c00000 Size:0x00100000
[0001.157] I> 4) Base:0xf7b00000 Size:0x00100000
[0001.161] I> 5) Base:0xf7a00000 Size:0x00100000
[0001.166] I> 6) Base:0xf7600000 Size:0x00200000
[0001.170] I> 7) Base:0xf7000000 Size:0x00400000
[0001.174] I> 8) Base:0xf7900000 Size:0x00100000
[0001.179] I> 9) Base:0xf7800000 Size:0x00100000
[0001.183] I> 10) Base:0xf6800000 Size:0x00800000
[0001.188] I> 11) Base:0x30000000 Size:0x00040000
[0001.192] I> 12) Base:0xf7500000 Size:0x00100000
[0001.197] I> 13) Base:0x30040000 Size:0x00001000
[0001.201] I> 14) Base:0x30048000 Size:0x00001000
[0001.206] I> 15) Base:0x30049000 Size:0x00001000
[0001.210] I> 16) Base:0x3004a000 Size:0x00001000
[0001.214] I> 17) Base:0x3004b000 Size:0x00001000
[0001.219] I> 18) Base:0x3004c000 Size:0x00001000
[0001.223] I> 19) Base:0x3004d000 Size:0x00001000
[0001.228] I> 20) Base:0x3004e000 Size:0x00001000
[0001.232] I> 21) Base:0x3004f000 Size:0x00001000
[0001.237] I> 22) Base:0x00000000 Size:0x00000000
[0001.241] I> 23) Base:0xf7ff0000 Size:0x00010000
[0001.245] I> 24) Base:0x00000000 Size:0x00000000
[0001.250] I> 25) Base:0x00000000 Size:0x00000000
[0001.254] I> 26) Base:0x00000000 Size:0x00000000
[0001.259] I> 27) Base:0x00000000 Size:0x00000000
[0001.263] I> 28) Base:0x84400000 Size:0x00400000
[0001.268] I> 29) Base:0x30000000 Size:0x00010000
[0001.272] I> 30) Base:0xf8000000 Size:0x08000000
[0001.276] I> 31) Base:0x00000000 Size:0x00000000
[0001.281] I> 32) Base:0xf6000000 Size:0x00600000
[0001.285] I> 33) Base:0x80000000 Size:0x76000000
[0001.290] I> 34) Base:0x100000000 Size:0x180000000
[0001.294] I> 35) Base:0x00000000 Size:0x00000000
[0001.299] I> 36) Base:0x00000000 Size:0x00000000
[0001.303] I> 37) Base:0xf7fc0000 Size:0x00020000
[0001.308] I> 38) Base:0x84000000 Size:0x00400000
[0001.312] I> 39) Base:0x96000000 Size:0x02000000
[0001.316] I> 40) Base:0x84800000 Size:0x00b00000
[0001.321] I> 41) Base:0xf7f00000 Size:0x00080000
[0001.325] I> 42) Base:0x00000000 Size:0x00000000
[0001.330] I> 43) Base:0x00000000 Size:0x00000000
[0001.334] platform_init_interrupts-121, 1*
[0001.338] Interrupts Init done
[0001.342] calling constructors
[0001.345] initializing heap
[0001.347] initializing threads
[0001.350] initializing timers
[0001.354] creating bootstrap completion thread
[0001.358] top of bootstrap2()
[0001.361] CPU: ARM Cortex A57
[0001.364] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.369] initializing platform
[0001.373] I> Boot-device: eMMC
[0001.376] I> odm data is 1090000
[0001.379] I> Reading GPT from 512 for device 00000003
[0001.385] I> Reading GPT from 8388096 for device 00000003
[0001.391] I> Found 6 partitions in 00000003 device
[0001.396] I> Reading GPT from 512 for device 00010003
[0001.402] I> Found 17 partitions in 00010003 device
[0001.407] W> No valid slot number is found in scratch register
[0001.412] W> Return default slot: _a
[0001.416] I> A/B: bin_type (1) slot 0
[0001.419] I> Select partition: kernel-dtb
[0001.423] I> Loading partition kernel-dtb at 0x92000000
[0001.432] I> Kernel_dtb @0x92000000
[0001.435] I> Bl_dtb @0x85300000
[0001.438] I> gpio framework initialized
[0001.442] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_main_driver’ driver
[0001.449] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_aon_driver’ driver
[0001.457] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.465] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.472] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.481] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.489] E> tegrabl_blob_init: BMP partition does not have valid Blob
[0001.495] E> tegrabl_load_bmp_blob: BMP blob initialization failed
[0001.501] W> Loading bmp blob to memory failed
[0001.509] I> Find /i2c@c250000’s alias i2c7
[0001.513] I> Reading eeprom i2c=7 address=0x50
[0001.543] I> Device at /i2c@c250000:0x50
[0001.546] I> Reading eeprom i2c=7 address=0x57
[0001.575] I> Device at /i2c@c250000:0x57
[0001.580] I> Find /i2c@c240000’s alias i2c1
[0001.584] I> Reading eeprom i2c=1 address=0x51
[0001.590] I> Eeprom read failed 0x1a800027
[0001.594] I> Find /i2c@3160000’s alias i2c0
[0001.598] I> Reading eeprom i2c=0 address=0x50
[0001.604] I> Eeprom read failed 0x1a800027
[0001.608] I> Find /i2c@3180000’s alias i2c2
[0001.612] I> Reading eeprom i2c=2 address=0x54
[0001.617] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.647] I> Disabling gpio chip_id = 2, gpio pin = 9
[0001.652] I> Device at /i2c@3180000:0x54
[0001.656] I> create_pm_ids: id: 3310-1000-B00-E, len: 15
[0001.661] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.672] I> create_pm_ids: id: 2597-0000-501-C, len: 15
[0001.677] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.688] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0001.693] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.704] initializing target
[0001.707] calling apps_init()
[0001.710] starting app android_boot_app
[0001.714] I> Gpio keyboard init success
[0001.718] I> Kernel type = Normal
[0001.721] I> Loading kernel/boot.img …
[0001.725] W> No valid slot number is found in scratch register
[0001.731] W> Return default slot: _a
[0001.734] I> A/B: bin_type (0) slot 0
[0001.737] I> Select partition: kernel
[0001.741] I> Loading partition kernel at 0xa8000000
[0001.822] W> No valid slot number is found in scratch register
[0001.828] W> Return default slot: _a
[0001.831] I> A/B: bin_type (1) slot 0
[0001.835] I> Select partition: kernel-dtb
[0001.838] I> Loading partition kernel-dtb at 0x92000000
[0001.847] I> Kernel DTB @ 0x92000000
[0001.851] I> Verified boot state = Orange
[0001.855] E> tegrabl_display_clear: display is not initialized
[0001.860] I> Checking boot.img header magic … [0001.864] I> [OK]
[0001.866] I> Valid boot.img @ 0xa8000000
[0001.870] I> decompressor handler not found
[0001.874] I> Copying kernel image (462634 bytes) from 0xa8000800 to 0x80080000 … [0001.881] I> Done
[0001.883] I> Move ramdisk (len: 6252235) from 0xa8071800 to 0x98000000
[0001.893] I> Updated bpmp info to DTB
[0001.898] I> Ramdisk: Base: 0x98000000; Size: 0x5f66cb
[0001.903] I> Updated initrd info to DTB
[0001.907] I> disabled_core_mask: 0xffffff0c
[0001.911] I> Kernel type = Normal
[0001.914] I> add_serialno: Serial Num = 0321517104336
[0001.919] W> No valid slot number is found in scratch register
[0001.924] W> Return default slot: _a
[0001.928] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0xf7fc0000 gpt androidboot.secureos=none tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 android.kerneltype=normal androidboot.serialno=0321517104336 androidboot.security=non-secure sdhci_tegra.en_boot_part_access=1
[0001.967] I> Updated bootarg info to DTB
[0001.972] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:8c:ac:fd
[0001.978] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:8c:ac:fe
[0001.984] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:8c:ac:ff
[0001.990] E> “ids” doesn’t exist, creating
[0001.994] E> “connection” doesn’t exist, creating
[0001.999] E> “configs” doesn’t exist, creating
[0002.003] I> create_pm_ids: id: 3310-1000-B00-E, len: 15
[0002.009] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.020] I> create_pm_ids: id: 2597-0000-501-C, len: 15
[0002.025] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.036] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0002.041] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0002.052] I> Adding plugin-manager/ids/3310-1000-B00=/i2c@c250000:module@0x50
[0002.059] E> “i2c@c250000” doesn’t exist, creating
[0002.063] E> “module@0x50” doesn’t exist, creating
[0002.068] I> Adding plugin-manager/ids/2597-0000-501=/i2c@c250000:module@0x57
[0002.075] E> “module@0x57” doesn’t exist, creating
[0002.080] I> Adding plugin-manager/ids/3326-1000-100=/i2c@3180000:module@0x54
[0002.087] E> “i2c@3180000” doesn’t exist, creating
[0002.092] E> “module@0x54” doesn’t exist, creating
[0002.099] I> Adding plugin-manager/ids/3310-1000-B00-E
[0002.106] I> Adding plugin-manager/configs/3310-mem-type 00
[0002.111] I> Adding plugin-manager/configs/3310-power-config 00
[0002.117] I> Adding plugin-manager/configs/3310-misc-config 00
[0002.123] I> Adding plugin-manager/configs/3310-modem-config 00
[0002.129] I> Adding plugin-manager/configs/3310-touch-config 00
[0002.134] I> Adding plugin-manager/configs/3310-display-config 00
[0002.140] E> “chip-id” doesn’t exist, creating
[0002.145] I> Adding plugin-manager/chip-id/A02P
[0002.151] I> Updated memory info to DTB
[0002.157] E> “reset” doesn’t exist, creating
[0002.161] E> “pmc-reset-reason” doesn’t exist, creating
[0002.166] E> “pmic-reset-reason” doesn’t exist, creating
[0002.172] I> disabled_core_mask: 0xffffff0c
[0002.182] I> tegrabl_load_kernel_and_dtb: Done
U-Boot 2016.07-g5971907 (Mar 01 2017 - 21:06:45 -0800)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 2 1 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
462 bytes read in 70 ms (5.9 KiB/s)
p2771-0000 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/Image
18945456 bytes read in 504 ms (35.8 MiB/s)
append: fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 android.kerneltype=normal androidboot.serialno=0335115020673 vpr_resize root=/dev/mmcblk0p1 rw rootwait
Flattened Device Tree blob at 92000000
Booting using the fdt blob at 0x92000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000092000000, end 0000000092041873
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.15-tegra (buildbrain@mobile-u64-1423) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Wed Mar 1 21:09:29 PST 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000f2000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1ffdf9000 s31104 r8192 d30336 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019520
[ 0.000000] Kernel command line: fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 android.kerneltype=normal androidboot.serialno=0335115020673 vpr_resize root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7969692K/8206336K available (10164K kernel code, 1653K rwdata, 5424K rodata, 1132K init, 679K bss, 171108K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdca000000 ( 128 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] .init : 0xffffffc000fba000 - 0xffffffc0010d5000 ( 1132 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc000fba000 ( 15592 KB)
[ 0.000000] .data : 0xffffffc0010f4000 - 0xffffffc0012915b0 ( 1654 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008882] tegra-id: chipid=21817.
[ 0.012711] tegra-id: opt_subrevision=1.
[ 0.017524] Console: colour dummy device 80x25
[ 0.022450] console [tty0] enabled
[ 0.025980] kmemleak: Kernel memory leak detector disabled
[ 0.031681] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.042436] pid_max: default: 32768 minimum: 301
[ 0.047261] Security Framework initialized
[ 0.051535] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.058676] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.066608] Initializing cgroup subsys freezer
[ 0.071230] Initializing cgroup subsys debug
[ 0.075788] CPU0 ipc=752
[ 0.078426] CPU1 ipc=1024
[ 0.081148] CPU2 ipc=1024
[ 0.083864] CPU3 ipc=752
[ 0.086494] CPU4 ipc=752
[ 0.089124] CPU5 ipc=752
[ 0.091779] ASID allocator initialised with 65536 entries
[ 0.133963] CPU1: Booted secondary processor [4e0f0030]
[ 0.145549] CPU2: Booted secondary processor [4e0f0030]
[ 0.157383] CPU3: Booted secondary processor [411fd073]
[ 0.169376] CPU4: Booted secondary processor [411fd073]
[ 0.181369] CPU5: Booted secondary processor [411fd073]
[ 0.181407] Brought up 6 CPUs
[ 0.211643] SMP: Total of 6 processors activated.
[ 0.216536] CPU: All CPU(s) started at EL2
[ 0.221157] devtmpfs: initialized
[ 0.247466] Initilizing CustomIPI irq domain
[ 0.252172] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.264699] pinctrl core: initialized pinctrl subsystem
[ 0.270498] OS set in device tree is L4T.
[ 0.275183] regulator-dummy: no parameters
[ 0.279749] Initializing plugin-manager
[ 0.283821] Plugin module not found
[ 0.287860] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.295805] node /plugin-manager/fragement@0 match with odm-data enable-tegra-wdt
[ 0.304140] node /plugin-manager/fragement@4 match with odm-data enable-tegra-wdt
[ 0.312710] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.322353] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.331661] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.340901] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.349211] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.358181] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.367079] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.375732] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.384474] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.392828] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.401957] node /plugin-manager/fragment-e3326@0 match with board 3326-*
[ 0.410263] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.421757] Adding domain adsp-pd to PM domain ape-pd
[ 0.431182] NET: Registered protocol family 16
[ 0.437315] console [pstore-1] enabled
[ 0.441261] pstore: Registered ramoops as persistent store backend
[ 0.447742] ramoops: attached 0x200000@0x100000000, ecc: 0/0
[ 0.461574] cpuidle: using governor ladder
[ 0.473578] cpuidle: using governor menu
[ 0.479416] bpmp: waiting for handshake
[ 0.483438] bpmp: handshake completed
[ 0.487292] bpmp: synchronizing channels
[ 0.491394] bpmp: channels synchronized
[ 0.495403] bpmp: connect returned 0
[ 0.499670] tegra186-pmc device create success
[ 0.504325] scratch reg offset dts data not present
[ 0.509536] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.517100] PMC: configuring io pad defaults
[ 0.521598] T186 pmc padctrl driver initialized
[ 0.526327] ### PMC reset source: Power on reset
[ 0.531146] ### PMC reset level: L0
[ 0.534787] ### PMC reset status reg: 0x0
[ 0.539624] vdso: 2 pages (1 code @ ffffffc0010f9000, 1 data @ ffffffc0010f8000)
[ 0.547426] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.556030] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.566143] tegra_powergate_init: DONE
[ 0.570184] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.589031] DTB Build time: Mar 1 2017 21:10:33
[ 0.595302] Tegra reboot handler registered.
[ 0.601016] Registering Tegra186 clocks (this may take a while)…done
[ 0.609424] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.616250] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.621190] arm-smmu 12000000.iommu: stage 1 translation
[ 0.626857] arm-smmu 12000000.iommu: stage 2 translation
[ 0.632528] arm-smmu 12000000.iommu: nested translation
[ 0.638105] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.646869] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.657852] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.664782] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.671615] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.719383] arm-smmu 12000000.iommu: registered 66 master devices
[ 0.729871] iommu: Adding device 3460000.sdhci to group 0
[ 0.736230] iommu: Adding device 3400000.sdhci to group 1
[ 0.744564] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.750960] iommu: Adding device 3160000.i2c to group 3
[ 0.756749] iommu: Adding device c240000.i2c to group 4
[ 0.762493] iommu: Adding device 3180000.i2c to group 5
[ 0.768231] iommu: Adding device 3190000.i2c to group 6
[ 0.774088] iommu: Adding device 31b0000.i2c to group 7
[ 0.779902] iommu: Adding device 31c0000.i2c to group 8
[ 0.785652] iommu: Adding device c250000.i2c to group 9
[ 0.791419] iommu: Adding device 31e0000.i2c to group 10
[ 0.798766] iommu: Adding device 3210000.spi to group 11
[ 0.804657] iommu: Adding device c260000.spi to group 12
[ 0.810485] iommu: Adding device 3240000.spi to group 13
[ 0.816713] iommu: Adding device 3100000.serial to group 14
[ 0.822851] iommu: Adding device 3110000.serial to group 15
[ 0.829008] iommu: Adding device 3130000.serial to group 16
[ 0.835847] iommu: Adding device 2490000.ether_qos to group 17
[ 0.842381] iommu: Adding device b000000.rtcpu to group 18
[ 0.848892] Wake73 for irq=42
[ 0.852278] iommu: Adding device smmu_test to group 19
[ 0.858121] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.864776] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.871419] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.878059] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.884698] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.891340] mc-err: Set intmask: 0xf3140
[ 0.895607] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.902513] Wake76 for irq=199
[ 0.905706] Wake77 for irq=199
[ 0.908891] Wake78 for irq=199
[ 0.912077] Wake79 for irq=199
[ 0.915262] Wake80 for irq=199
[ 0.918447] Wake81 for irq=199
[ 0.921634] Wake82 for irq=199
[ 0.924965] iommu: Adding device 3530000.xhci to group 20
[ 0.930934] iommu: Adding device 3550000.xudc to group 21
[ 0.937285] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.943470] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.951247] iommu: Adding device 13e10000.host1x to group 22
[ 0.957424] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.963981] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.970536] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.977088] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.983685] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.990313] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.996878] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 1.003493] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 1.010316] iommu: Adding device 150c0000.nvcsi to group 31
[ 1.016596] iommu: Adding device 15700000.vi to group 32
[ 1.022458] iommu: Adding device 15600000.isp to group 33
[ 1.028387] iommu: Adding device 15210000.nvdisplay to group 34
[ 1.034794] iommu: Adding device 15340000.vic to group 35
[ 1.040638] iommu: Adding device 154c0000.nvenc to group 36
[ 1.046655] iommu: Adding device 15480000.nvdec to group 37
[ 1.052925] iommu: Adding device 15380000.nvjpg to group 38
[ 1.058968] iommu: Adding device 15500000.tsec to group 39
[ 1.064881] iommu: Adding device 15100000.tsecb to group 40
[ 1.071452] iommu: Adding device 15810000.se to group 41
[ 1.077185] iommu: Adding device 15820000.se to group 42
[ 1.082954] iommu: Adding device 15830000.se to group 43
[ 1.088676] iommu: Adding device 15840000.se to group 44
[ 1.094812] iommu: Adding device 17000000.gp10b to group 45
[ 1.101845] tegra-reset 5000000.clock: registered 193 resets.
[ 1.109159] iommu: Adding device d000000.bpmp to group 46
[ 1.115002] bpmp: ping status is 0
[ 1.118714] bpmp d000000.bpmp: firmware tag is c11dd04ae487c849cc552f8f702ed830
[ 1.128729] iommu: Adding device 2600000.dma to group 47
[ 1.134985] GPIO line 424 (wifi-enable) hogged as output/high
[ 1.141053] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 1.147001] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 1.153560] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 1.162925] GPIO line 315 (wifi-wake-ap) hogged as input
[ 1.168571] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 1.177449] iommu: Adding device 10003000.pcie-controller to group 48
[ 1.184364] iommu: Adding device sound to group 49
[ 1.190872] iommu: Adding device 3510000.hda to group 50
[ 1.197423] iommu: Adding device adsp_audio to group 51
[ 1.204091] iommu: Adding device 2993000.adsp to group 52
[ 1.214992] iommu: Adding device c160000.aon to group 53
[ 1.222546] vdd-ac-bat: 5000 mV
[ 1.227699] vdd-1v8-ap: 1800 mV
[ 1.232023] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 1.237869] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 1.259920] SCSI subsystem initialized
[ 1.264200] usbcore: registered new interface driver usbfs
[ 1.269998] usbcore: registered new interface driver hub
[ 1.275631] usbcore: registered new device driver usb
[ 1.284012] GPIO line 241 (touch-rail-1) hogged as output/high
[ 1.290357] GPIO line 242 (touch-rail-2) hogged as output/high
[ 1.296558] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 1.304804] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 1.312437] tps65132 0-003e: No active discharge gpio for regulator tps65132-outp
[ 1.320413] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.327521] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.334478] outp: 4000 ↔ 6000 mV
[ 1.338265] tps65132 0-003e: No active discharge gpio for regulator tps65132-outn
[ 1.346207] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.353264] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.360203] outn: 4000 ↔ 6000 mV
[ 1.374640] media: Linux media interface: v0.10
[ 1.379447] Linux video capture interface: v2.00
[ 1.388165] pps_core: LinuxPPS API ver. 1 registered
[ 1.393362] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.402902] PTP clock support registered
[ 1.408734] Tegra WDT setup timeout = 120 seconds.
[ 1.413792] tegra_wdt_t18x 30c0000.watchdog: tegra_wdt_t18x_probe done
[ 1.422050] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 1.429890] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 1.436137] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 1.442337] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 1.453720] vddio-ddr: at 1125 mV
[ 1.461568] avdd_dsi_csi: 1200 mV
[ 1.469567] vdd-1v8: 1800 mV
[ 1.477569] vdd-3v3-sys: 3300 mV
[ 1.482004] spmic-ldo0: at 1800 mV
[ 1.486350] spmic-ldo1: at 800 mV
[ 1.493571] vddio-3v3: 3300 mV
[ 1.497435] vddio-sdmmc1: 1800 ↔ 3300 mV at 3300 mV
[ 1.505567] vdd-rtc: 1000 mV
[ 1.509403] avdd-ts-hv: 1800 ↔ 3300 mV at 1800 mV
[ 1.517570] spmic-ldo6: at 1500 mV
[ 1.521947] vdd-pex-1v05: 1000 mV
[ 1.526090] dvdd-pex: 1000 mV
[ 1.529626] max77620 4-003c: max77620 probe successful
[ 1.535304] Advanced Linux Sound Architecture Driver Initialized.
[ 1.543012] en-vdd-sd: 3300 mV
[ 1.546759] en-vdd-cam: 1800 mV
[ 1.550600] vdd-hdmi: 5000 mV
[ 1.554036] vdd-usb0-5v: 5000 mV
[ 1.557734] vdd-usb1-5v: 5000 mV
[ 1.565569] en-vdd-ts-1v8: 1800 mV
[ 1.573569] en-vdd-ts-hv-3v3: 3300 mV
[ 1.577932] en-vdd-disp-3v3: 3300 mV
[ 1.582203] en-mdm-pwr-3v7: 3700 mV
[ 1.586376] en-vdd-disp-1v8: 1800 mV
[ 1.590629] en-vdd-cam-hv-2v8: 2800 mV
[ 1.595088] en-vdd-cam-1v2: 1200 mV
[ 1.599273] vdd-fan: 5000 mV
[ 1.602549] vdd-3v3: 3300 mV
[ 1.606204] dis-vdd-1v2: 1200 mV
[ 1.609827] en-vdd-vcm-2v8: 2800 mV
[ 1.613991] vdd-usb2-5v: 5000 mV
[ 1.617638] vdd-sys-bl: 3300 mV
[ 1.621442] en-vdd-sys: 1200 mV
[ 1.625782] gpio tegra-gpio wake53 for gpio=159(X:5)
[ 1.632718] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 1.640281] clocksource: Switched to clocksource arch_sys_counter
[ 1.677892] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.684967] nvmap_page_pool_init: Total RAM pages: 2008807
[ 1.690683] nvmap_page_pool_init: nvmap page pool size: 251100 pages (980 MB)
[ 1.692955] Wake76 for irq=199
[ 1.692958] Wake77 for irq=199
[ 1.692960] Wake78 for irq=199
[ 1.692962] Wake79 for irq=199
[ 1.692964] Wake80 for irq=199
[ 1.692966] Wake81 for irq=199
[ 1.692967] Wake82 for irq=199
[ 1.694074] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 1.694301] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 1.694400] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 1.694500] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 1.694851] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 1.694992] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 1.695123] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 1.695253] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 1.695281] isomgr_init(): iso emc max clk=1866000KHz
[ 1.695284] isomgr_init(): max_iso_bw=26870400KB
[ 1.695490] tegra186-pmc-iopower pmc-iopower: Rail iopower-sys is having fixed voltage 1800000
[ 1.695558] tegra186-pmc-iopower pmc-iopower: Rail iopower-uart is having fixed voltage 1800000
[ 1.695647] tegra186-pmc-iopower pmc-iopower: Rail iopower-conn is having fixed voltage 1800000
[ 1.695706] tegra186-pmc-iopower pmc-iopower: Rail iopower-edp is having fixed voltage 1800000
[ 1.695768] tegra186-pmc-iopower pmc-iopower: Rail iopower-pex-ctrl-audio is having fixed voltage 1800000
[ 1.695828] tegra186-pmc-iopower pmc-iopower: Rail iopower-ufs is having fixed voltage 1800000
[ 1.695896] tegra186-pmc-iopower pmc-iopower: Rail iopower-ddr0 is having fixed voltage 0
[ 1.695946] tegra186-pmc-iopower pmc-iopower: Rail iopower-ddr1 is having fixed voltage 0
[ 1.695998] tegra186-pmc-iopower pmc-iopower: Rail iopower-csi-dsi is having fixed voltage 1200000
[ 1.696055] tegra186-pmc-iopower pmc-iopower: Rail iopower-cam is having fixed voltage 1800000
[ 1.696119] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc4 is having fixed voltage 1800000
[ 1.696184] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc1-hv is having voltages: 1800000:3300000
[ 1.696249] tegra186-pmc-iopower pmc-iopower: Rail iopower-audio-hv is having fixed voltage 1800000
[ 1.696340] tegra186-pmc-iopower pmc-iopower: Rail iopower-dbg is having fixed voltage 1800000
[ 1.696431] tegra186-pmc-iopower pmc-iopower: Rail iopower-spi is having fixed voltage 1800000
[ 1.696491] tegra186-pmc-iopower pmc-iopower: Rail iopower-ao is having fixed voltage 1800000
[ 1.696573] tegra186-pmc-iopower pmc-iopower: Rail iopower-ao-hv is having fixed voltage 3300000
[ 1.696642] tegra186-pmc-iopower pmc-iopower: Rail iopower-dmic-hv is having fixed voltage 1800000
[ 1.696702] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc2-hv is having fixed voltage 3300000
[ 1.696755] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc3-hv is having voltages: 1800000:3300000
[ 1.696766] tegra186-pmc-iopower pmc-iopower: NO_IO_POWER setting 0x00000000
[ 1.697008] NET: Registered protocol family 2
[ 1.697561] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.698368] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.699633] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.699704] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.699931] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.700234] NET: Registered protocol family 1
[ 1.700651] RPC: Registered named UNIX socket transport module.
[ 1.700653] RPC: Registered udp transport module.
[ 1.700655] RPC: Registered tcp transport module.
[ 1.700657] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.700850] Unpacking initramfs…
[ 1.879490] Freeing initrd memory: 6104K (ffffffc018000000 - ffffffc0185f6000)
[ 1.894904] host1x 13e10000.host1x: initialized
[ 1.900638] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.901603] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 1.901749] audit: initializing netlink subsys (disabled)
[ 1.901782] audit: type=2000 audit(1.864:1): initialized
[ 1.909746] io scheduler noop registered (default)
[ 1.915308] Adding domain tsec-pd to PM domain host-pd
[ 1.917881] tsec 15500000.tsec: initialized
[ 1.919137] tsec 15100000.tsecb: initialized
[ 1.919578] Adding domain nvdec-pd to PM domain host-pd
[ 1.921563] nvdec 15480000.nvdec: initialized
[ 1.922123] Adding domain vic03-pd to PM domain host-pd
[ 1.922144] Adding domain msenc-pd to PM domain host-pd
[ 1.922166] Adding domain nvjpg-pd to PM domain host-pd
[ 1.925493] falcon 15340000.vic: initialized
[ 1.926656] falcon 154c0000.nvenc: initialized
[ 1.927880] falcon 15380000.nvjpg: initialized
[ 1.928929] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.929690] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.930482] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.931251] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.932083] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.932880] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.933654] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.934409] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.935937] tegradc 15210000.nvdisplay: Display dc.15210000 registered with id=0
[ 1.935943] DC OR NODE connected to /host1x/sor1
[ 1.935978] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.936006] parse_tmds_config: No tmds-config node
[ 1.936095] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1250000, vi_iso_bw=1500000, max_bw=1500000
[ 1.936097] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.943383] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.943385] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.943387] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.943415] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 1.943419] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 1.945163] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 1.945989] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.946255] PD DISP0 index2 UP
[ 1.946485] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.946666] PD DISP1 index3 UP
[ 1.946751] PD DISP2 index4 UP
[ 1.948761] console [ttyS0] disabled
[ 1.973462] PD DISP2 index4 DOWN
[ 1.973552] PD DISP1 index3 DOWN
[ 1.973628] PD DISP0 index2 DOWN
[ 1.975203] tegradc 15210000.nvdisplay: probed
[ 2.350238] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 2.350355] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.364012] Console: switching to colour frame buffer device 240x67
[ 2.399562] tegradc 15210000.nvdisplay: fb registered
[ 2.399744] gpio tegra-gpio wake21 for gpio=121(P:2)
[ 2.399778] PD DISP0 index2 UP
[ 2.400180] PD DISP1 index3 UP
[ 2.400266] PD DISP2 index4 UP
[ 2.407142] rate get on hub 408000000
[ 2.407514] Parent Clock set for DC plld2
[ 2.409613] dc clk 148500000
[ 2.412813] tegradc 15210000.nvdisplay: Link compression not supported by the panel
[ 2.412817] rate get on compclk 148500000
[ 2.427908] tegradc 15210000.nvdisplay: Window 3 assigned to head 1
[ 2.444582] tegradc 15210000.nvdisplay: Window 4 assigned to head 1
[ 2.461243] tegradc 15210000.nvdisplay: Window 5 assigned to head 1
[ 2.523785] console [ttyS0] enabled
[ 2.531048] bootconsole [uart0] disabled
[ 2.541078] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 2.550204] serial-tegra 3130000.serial: RX in PIO mode
[ 2.556445] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.566972] gpio tegra-gpio-aon wake35 for gpio=16(V:2)
[ 2.572387] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.578805] nct1008_nct72 7-004c: starting parse dt
[ 2.583912] nct1008_nct72 7-004c: success parsing dt
[ 2.589118] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.593726] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.606675] tegradc 15210000.nvdisplay: vrr_setup failed
[ 2.637407] tmp451: Enabled overheat logging at 104.00C
[ 2.637534] gpio tegra-gpio-aon wake35 for gpio=16(V:2)
[ 2.637577] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.640355] THERMAL EST: found 3 subdevs
[ 2.640358] THERMAL EST num_resources: 0
[ 2.640369] [THERMAL EST subdev 0]
[ 2.640373] [THERMAL EST subdev 1]
[ 2.640377] [THERMAL EST subdev 2]
[ 2.640643] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 2.640646] THERMAL EST: thz register success.
[ 2.640812] THERMAL EST: end of probe, return err: 0
[ 2.640989] tegra_profiler: Branch: Dev
[ 2.640991] tegra_profiler: Version: 1.109
[ 2.640993] tegra_profiler: Samples version: 37
[ 2.640994] tegra_profiler: IO version: 20
[ 2.641002] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.641005] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.641009] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.641012] armv8_pmu: arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.641015] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.641017] armv8_pmu: arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.641020] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.641023] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.641026] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.641028] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.641031] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.641034] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.641212] tegra_profiler: auth: init
[ 2.644361] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.644372] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.645284] scsi host0: tegra_ahci
[ 2.645612] scsi host1: tegra_ahci
[ 2.645742] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 2.645745] ata2: DUMMY
[ 2.646446] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.646845] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.647242] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.648030] tun: Universal TUN/TAP device driver, 1.6
[ 2.648033] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.648144] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.648145] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.648183] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.648185] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.648364] PPP generic driver version 2.4.2
[ 2.648488] PPP BSD Compression module registered
[ 2.648494] PPP Deflate Compression module registered
[ 2.648512] PPP MPPE Compression module registered
[ 2.648520] NET: Registered protocol family 24
[ 2.648562] usbcore: registered new interface driver asix
[ 2.648585] usbcore: registered new interface driver ax88179_178a
[ 2.648606] usbcore: registered new interface driver cdc_ether
[ 2.648639] usbcore: registered new interface driver smsc95xx
[ 2.648665] usbcore: registered new interface driver net1080
[ 2.648687] usbcore: registered new interface driver cdc_subset
[ 2.648709] usbcore: registered new interface driver zaurus
[ 2.648745] usbcore: registered new interface driver cdc_ncm
[ 2.649061] usbcore: registered new interface driver usb-storage
[ 2.649116] usbcore: registered new interface driver usbserial
[ 2.649136] usbcore: registered new interface driver ftdi_sio
[ 2.649164] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.649184] usbcore: registered new interface driver option
[ 2.649201] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.649234] usbcore: registered new interface driver pl2303
[ 2.649248] usbserial: USB Serial support registered for pl2303
[ 2.649470] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.651595] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.781058] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.783573] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.783587] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.783750] i2c /dev entries driver
[ 2.784530] [OV5693]: probing v4l2 sensor.
[ 3.136301] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.136552] ata1.00: supports DRM functions and may not be fully accessible
[ 3.136557] ata1.00: ATA-9: Samsung SSD 850 EVO 500GB, EMT02B6Q, max UDMA/133
[ 3.136560] ata1.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 31/32)
[ 3.137327] ata1.00: supports DRM functions and may not be fully accessible
[ 3.137723] ata1.00: configured for UDMA/133
[ 3.152564] scsi 0:0:0:0: Direct-Access ATA Samsung SSD 850 2B6Q PQ: 0 ANSI: 5
[ 3.152987] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 3.153167] sd 0:0:0:0: [sda] Write Protect is off
[ 3.153228] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 3.154130] sda: sda1
[ 3.154620] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.519605] random: nonblocking pool is initialized
[ 3.568281] gspca_main: v2.14.0 registered
[ 3.568328] usbcore: registered new interface driver gspca_zc3xx
[ 3.568632] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.570355] FAN dev name: pwm-fan
[ 3.570402] FAN:gpio request success.
[ 3.570407] FAN: can’t find tach_gpio
[ 3.570434] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.570585] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 3.570589] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.570593] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.570861] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.570864] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.570867] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.570871] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.570874] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.570876] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.570879] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.570882] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.570885] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.570888] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.571319] device-mapper: uevent: version 1.0.3
[ 3.571492] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.571710] sdhci: Secure Digital Host Controller Interface driver
[ 3.571711] sdhci: Copyright(c) Pierre Ossman
[ 3.571716] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.572013] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.572304] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.572680] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.572748] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.573194] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.574677] usbcore: registered new interface driver usbhid
[ 3.574678] usbhid: USB HID core driver
[ 3.574695] sdhci-tegra 3460000.sdhci: voltage switch failed in probe, err: -524
[ 3.576988] nvadsp 2993000.adsp: in probe()…
[ 3.577862] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.577890] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.578014] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.578478] tegra_central_actmon d230000.actmon: in probe()…
[ 3.580597] tegra_central_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.581031] kfuse 3830000.kfuse: initialized
[ 3.581345] Denver: backdoor interface is NOT available.
[ 3.582331] coresight-tmc 8030000.etf: TMC initialized
[ 3.582639] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.583063] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.583433] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.583817] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.584381] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.584887] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.585391] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.585889] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.585912] Module initialized successfully
[ 3.589363] camchar: rtcpu character device driver loaded
[ 3.591099] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.591225] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.591290] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.591832] **** A57 ECC: Enabled
[ 3.591834] tegra18_a57_serr_init: on CPU 0 a A57 Core
[ 3.591955] parse_throttle_dt_data: Num cap clks = 4
[ 3.591958] parse_throttle_dt_data: clk=mcpu type=1
[ 3.591960] parse_throttle_dt_data: clk=bcpu type=2
[ 3.591965] parse_throttle_dt_data: clk=gpu type=4
[ 3.591967] parse_throttle_dt_data: clk=emc type=3
[ 3.592418] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.592607] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.593018] Adding domain se-pd to PM domain host-pd
[ 3.594495] tegra-se-nvhost 15810000.se: initialized
[ 3.594882] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.595205] tegra-se-nvhost 15820000.se: initialized
[ 3.595486] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.595763] tegra-se-nvhost 15830000.se: initialized
[ 3.595973] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.596242] tegra-se-nvhost 15840000.se: initialized
[ 3.596509] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.599992] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.602561] cpufreq: platform driver Initialization: pass
[ 3.602842] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.602846] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.602877] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ea896
[ 3.602879] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.604043] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.605045] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.606353] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.606488] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.607727] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 3.607732] Tachometer driver initialized with pulse_per_rev: 1 and win_len: 1
[ 3.608296] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.609404] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.609735] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c ac ff
[ 3.609802] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.610228] libphy: dwc_phy: probed
[ 3.611364] tegra210_adsp_audio_platform_probe: platform probe started
[ 3.611633] sdhci-tegra 3440000.sdhci: voltage switch failed in probe, err: -524
[ 3.611924] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 3.612161] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 3.612475] pad_id 28: PMC_IMPL_E_33V_PWR_0 = [0x39]
[ 3.612475] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 3.612784] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 3.616434] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 3.616440] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 3.616441] tegra210-adsp adsp_audio: using adma channel page 0
[ 3.617080] tegra210_adsp_audio_platform_probe probe successfull.
[ 3.617080] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 3.617202] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 3.625735] OPE platform probe
[ 3.625805] OPE platform probe successful
[ 3.631762] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 3.648297] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.648582] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.648639] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.648697] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.648770] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 247
[ 3.648981] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.650804] sdhci-tegra 3400000.sdhci: voltage switch failed in probe, err: -524
[ 3.673602] gpio tegra-gpio wake18 for gpio=101(M:3)
[ 3.673778] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.677340] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 3.677414] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 3.677481] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 3.677549] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 3.677618] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 3.677686] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 3.677756] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 3.677824] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 3.677894] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 3.677960] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 3.678030] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 ↔ ADMAIF11 mapping ok
[ 3.678098] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 ↔ ADMAIF12 mapping ok
[ 3.678165] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 ↔ ADMAIF13 mapping ok
[ 3.678231] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 ↔ ADMAIF14 mapping ok
[ 3.678271] mmc0: MAN_BKOPS_EN bit is not set
[ 3.678303] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 ↔ ADMAIF15 mapping ok
[ 3.678372] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 ↔ ADMAIF16 mapping ok
[ 3.678445] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 ↔ ADMAIF17 mapping ok
[ 3.678513] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 ↔ ADMAIF18 mapping ok
[ 3.678582] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 ↔ ADMAIF19 mapping ok
[ 3.678653] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 ↔ ADMAIF20 mapping ok
[ 3.679693] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 ↔ ADSP PCM1 mapping ok
[ 3.679770] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 ↔ ADSP PCM2 mapping ok
[ 3.679796] compress asoc: ADSP-FE3 ↔ ADSP COMPR1 mapping ok
[ 3.679819] compress asoc: ADSP-FE4 ↔ ADSP COMPR2 mapping ok
[ 3.685371] mmc0: Skipping tuning since strobe enabled
[ 3.688371] gpio tegra-gpio wake71 for gpio=125(P:6)
[ 3.688402] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.692594] mmc0: periodic cache flush enabled
[ 3.692602] mmc0: new HS400 MMC card at address 0001
[ 3.692840] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.692934] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.694005] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 3.708859] pad_id 28: PMC_IMPL_E_33V_PWR_0 = [0x39]
[ 3.708861] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 3.709626] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 3.709630] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 3.710141] GACT probability NOT on
[ 3.710150] Mirror/redirect action on
[ 3.710162] u32 classifier
[ 3.710162] Actions configured
[ 3.710183] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.710822] Initializing XFRM netlink socket
[ 3.711102] NET: Registered protocol family 10
[ 3.711887] NET: Registered protocol family 17
[ 3.711901] NET: Registered protocol family 15
[ 3.711907] 8021q: 802.1Q VLAN Support v1.8
[ 3.712101] Registered cp15_barrier emulation handler
[ 3.712118] Registered setend emulation handler
[ 3.713459] registered taskstats version 1
[ 3.714010] Adding domain ispa-pd to PM domain host-pd
[ 3.716588] isp 15600000.isp: initialized
[ 3.717000] Adding domain ve-pd to PM domain host-pd
[ 3.719814] nvcsi 150c0000.nvcsi: initialized
[ 3.720868] Wake76 for irq=199
[ 3.720869] Wake77 for irq=199
[ 3.720870] Wake78 for irq=199
[ 3.720870] Wake79 for irq=199
[ 3.720871] Wake80 for irq=199
[ 3.720872] Wake81 for irq=199
[ 3.720872] Wake82 for irq=199
[ 3.721190] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 3.721192] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 3.723352] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.723661] xhci-tegra 3530000.xhci: Firmware timestamp: 2016-09-01 11:32:41 UTC, Version: 55.05 release
[ 3.724034] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.724642] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.725694] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 3.725704] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 3.726479] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 3.726500] xhci-tegra 3530000.xhci: irq 54, io mem 0x03530000
[ 3.726595] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.726597] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.726599] usb usb1: Product: xHCI Host Controller
[ 3.726601] usb usb1: Manufacturer: Linux 4.4.15-tegra xhci-hcd
[ 3.726602] usb usb1: SerialNumber: 3530000.xhci
[ 3.726831] hub 1-0:1.0: USB hub found
[ 3.726851] hub 1-0:1.0: 4 ports detected
[ 3.727053] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.727616] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.728869] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.730601] tegra186-cam-rtcpu b000000.rtcpu: booting sce with Camera RTCPU FW
[ 3.730616] tegra186-cam-rtcpu b000000.rtcpu: sce gets unhalted
[ 3.731903] tegra-camera-rtcpu-character-device ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.732715] tegra-camera-rtcpu-character-device ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.732876] tegra186-cam-rtcpu b000000.rtcpu: enabling tracing
[ 3.732950] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.733193] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=2 ivc=2 sha1=fb16914d17f56e81ad21e716791045b9ac83064a
[ 3.733902] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 3.733960] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 3.734028] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 3.734146] input: gpio-keys as /devices/gpio-keys/input/input3
[ 3.740297] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 3.740305] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 3.740419] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.740421] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.740423] usb usb2: Product: xHCI Host Controller
[ 3.740425] usb usb2: Manufacturer: Linux 4.4.15-tegra xhci-hcd
[ 3.740426] usb usb2: SerialNumber: 3530000.xhci
[ 3.740616] hub 2-0:1.0: USB hub found
[ 3.740630] hub 2-0:1.0: 3 ports detected
[ 3.765253] tegra_rtc c2a0000.rtc: setting system clock to 2017-07-05 19:42:15 UTC (1499283735)
[ 3.780205] tegra-vi4 15700000.vi: initialized
[ 3.795525] bpmp: mounted debugfs mirror
[ 3.795897] [dram-timers] DRAM derating cdev registered.
[ 3.798777] outp: disabling
[ 3.798781] outn: disabling
[ 3.798789] spmic-ldo0: disabling
[ 3.798956] spmic-ldo1: disabling
[ 3.799087] en-vdd-cam: disabling
[ 3.799089] vdd-usb0-5v: disabling
[ 3.799093] en-vdd-disp-3v3: disabling
[ 3.799094] en-mdm-pwr-3v7: disabling
[ 3.799095] en-vdd-disp-1v8: disabling
[ 3.799097] en-vdd-cam-hv-2v8: disabling
[ 3.799098] en-vdd-cam-1v
