linuxdev:
I am getting the following serial console messages when I use USRP commands
to detect a X300 software defined radio (connected to the Jetson TX2 by a
Startech PEX10000SFP 10G ethernet adapter plugged into the PCIe port. Any suggestions?
Following are the eth1 (10G ethernet, Tehuti Network, tx40xx driver) relevant messages during bootup:
[ 15.096660] tegra-pcie 10003000.pcie-controller: speed change : Gen-1 -> Gen-2
[ 15.178411] tn40xx: Tehuti Network Driver, 0.3.6.14
[ 15.178413] tn40xx: Supported phys : MV88X3120 MV88X3310 MV88E2010 QT2025 TLK10232 AQR105
[ 15.178529] tn40xx 0000:01:00.0: enabling device (0000 -> 0002)
[ 15.178585] tn40xx: srom 0x0 HWver 16 build 0 lane# 4 max_pl 0x0 mrrs 0x2
[ 15.400295] tn40xx: PHY detected on port 0 ID=40005100 - TLK10232 10Gbps SFP+
[ 15.400297] tn40xx: PHY type by svid 7 found 6
[ 15.673244] tn40xx: fw 0xe
[ 15.673342] tn40xx: eth1, Port A
[ 15.673355] tn40xx: 1 1fc9:4025:1fc9:3015
[ 17.539055] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 15.673359] tn40xx: detected 1 cards, 1 loaded
[ 17.663028] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 17.670954] 8021q: adding VLAN 0 to HW filter on device eth1
Following are the messages after booting and when the Jetson hangs:
nvidia@tegra-ubuntu:~$ [ 34.320449] tn40xx: eth1 Link Up 10G
[ 34.324471] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
nvidia@tegra-ubuntu:~$ sudo s[ 56.397263] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
root@tegra-ubuntu:/home/nvidia# ifconfig
eth0 Link encap:Ethernet HWaddr 00:04:4b:8c:ac:ff
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:39
eth1 Link encap:Ethernet HWaddr 00:0a:cd:2e:4a:4e
inet6 addr: fe80::88b1:5319:8c63:f001/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:5 errors:0 dropped:0 overruns:0 frame:0
TX packets:53 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3000
RX bytes:300 (300.0 B) TX bytes:8537 (8.5 KB)
Interrupt:187 Memory:58000000-58010000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:245 errors:0 dropped:0 overruns:0 frame:0
TX packets:245 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:18719 (18.7 KB) TX bytes:18719 (18.7 KB)
wlan0 Link encap:Ethernet HWaddr 00:04:4b:8c:ac:fd
inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::4fde:cbd9:9f4d:4969/64 Scope:Link
RX packets:68 errors:0 dropped:0 overruns:0 frame:0
TX packets:104 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6027 (6.0 KB) TX bytes:10586 (10.5 KB)
root@tegra-ubuntu:/home/nvidia# ifconfig eth1 192.168.40.1
root@tegra-ubuntu:/home/nvidia# ifconfig eth1 192.168.40.1e[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Kmtu 9000
[ 136.138822] tn40xx: eth1 Link Up 10G
root@tegra-ubuntu:/home/nvidia# uhd_find_devices
linux; GNU C++ version 5.3.1 20151219; Boost_105800; UHD_003.009.002-0-unknown
[ 148.071080] BUG: Bad page state in process swapper/0 pfn:26bd80
[ 148.077135] page:ffffffbdc9af6000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.085208] flags: 0x4000000000000200(arch_1)
[ 148.089682] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.095893] bad because of flags:
[ 148.099244] flags: 0x200(arch_1)
[ 148.102734] Call trace:
[ 148.105762] Disabling lock debugging due to kernel taint
[ 148.196774] BUG: Bad page state in process swapper/0 pfn:f0900
[ 148.202789] page:ffffffbdc3c24000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.210873] flags: 0x200(arch_1)
[ 148.214194] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.220419] bad because of flags:
[ 148.223780] flags: 0x200(arch_1)
[ 148.227307] Call trace:
[ 148.245625] BUG: Bad page state in process swapper/0 pfn:26a8c0
[ 148.251698] page:ffffffbdc9aa3000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.259777] flags: 0x4000000000000200(arch_1)
[ 148.264294] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.270549] bad because of flags:
[ 148.273939] flags: 0x200(arch_1)
[ 148.277341] Call trace:
[ 148.289123] BUG: Bad page state in process kworker/0:4 pfn:26ab80
[ 148.295352] page:ffffffbdc9aae000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.303445] flags: 0x4000000000000200(arch_1)
[ 148.307917] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.314151] bad because of flags:
[ 148.317515] flags: 0x200(arch_1)
[ 148.320978] Call trace:
[ 148.332902] BUG: Bad page state in process swapper/0 pfn:26a840
[ 148.339036] page:ffffffbdc9aa1000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.347149] flags: 0x4000000000000200(arch_1)
[ 148.351610] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.357835] bad because of flags:
[ 148.361201] flags: 0x200(arch_1)
[ 148.364695] Call trace:
[ 148.377061] BUG: Bad page state in process swapper/0 pfn:26b180
[ 148.383172] page:ffffffbdc9ac6000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.391233] flags: 0x4000000000000200(arch_1)
[ 148.395669] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.401906] bad because of flags:
[ 148.405261] flags: 0x200(arch_1)
[ 148.408693] Call trace:
[ 148.420756] BUG: Bad page state in process swapper/0 pfn:26b140
[ 148.426868] page:ffffffbdc9ac5000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.434953] flags: 0x4000000000000200(arch_1)
[ 148.439402] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.445658] bad because of flags:
[ 148.449020] flags: 0x200(arch_1)
[ 148.452462] Call trace:
[ 148.502306] BUG: Bad page state in process swapper/0 pfn:df180
[ 148.508276] page:ffffffbdc37c6000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.516344] flags: 0x200(arch_1)
[ 148.519652] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.525902] bad because of flags:
[ 148.529263] flags: 0x200(arch_1)
[ 148.532755] Call trace:
[ 148.545324] BUG: Bad page state in process compiz pfn:df1c0
[ 148.551060] page:ffffffbdc37c7000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.559132] flags: 0x200(arch_1)
[ 148.562503] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.568740] bad because of flags:
[ 148.572061] flags: 0x200(arch_1)
[ 148.575456] Call trace:
[ 148.589818] BUG: Bad page state in process swapper/0 pfn:26af80
[ 148.595874] page:ffffffbdc9abe000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.603949] flags: 0x4000000000000200(arch_1)
[ 148.608474] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.614711] bad because of flags:
[ 148.618057] flags: 0x200(arch_1)
[ 148.621441] Call trace:
[ 148.640988] BUG: Bad page state in process swapper/0 pfn:252f80
[ 148.647041] page:ffffffbdc94be000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.655062] flags: 0x4000000000000200(arch_1)
[ 148.659439] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.665618] bad because of flags:
[ 148.668931] flags: 0x200(arch_1)
[ 148.672207] Call trace:
[ 148.717074] BUG: Bad page state in process swapper/0 pfn:26afc0
[ 148.723110] page:ffffffbdc9abf000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.731131] flags: 0x4000000000000200(arch_1)
[ 148.735554] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.741790] bad because of flags:
[ 148.745138] flags: 0x200(arch_1)
[ 148.748488] Call trace:
[ 148.759602] BUG: Bad page state in process swapper/0 pfn:df280
[ 148.765595] page:ffffffbdc37ca000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.773644] flags: 0x200(arch_1)
[ 148.776931] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.783190] bad because of flags:
[ 148.786550] flags: 0x200(arch_1)
[ 148.790003] Call trace:
[ 148.802596] BUG: Bad page state in process swapper/0 pfn:df200
[ 148.808558] page:ffffffbdc37c8000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.816596] flags: 0x200(arch_1)
[ 148.819902] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.826147] bad because of flags:
[ 148.829506] flags: 0x200(arch_1)
[ 148.832940] Call trace:
[ 148.926200] BUG: Bad page state in process swapper/0 pfn:234a80
[ 148.932263] page:ffffffbdc8d2a000 count:0 mapcount:0 mapping: (null) index:0x0
[ 148.940339] flags: 0x4000000000000200(arch_1)
[ 148.944821] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 148.951039] bad because of flags:
[ 148.954386] flags: 0x200(arch_1)
[ 148.957946] Call trace:
[ 148.990297] BUG: Bad page state in process swapper/0 pfn:234b00
[ 148.996351] page:ffffffbdc8d2c000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.004426] flags: 0x4000000000000200(arch_1)
[ 149.008877] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.015117] bad because of flags:
[ 149.018458] flags: 0x200(arch_1)
[ 149.021972] Call trace:
[ 149.044634] BUG: Bad page state in process swapper/0 pfn:234b40
[ 149.050721] page:ffffffbdc8d2d000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.058805] flags: 0x4000000000000200(arch_1)
[ 149.063305] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.069545] bad because of flags:
[ 149.072915] flags: 0x200(arch_1)
[ 149.076347] Call trace:
[ 149.128808] BUG: Bad page state in process ksoftirqd/0 pfn:234bc0
[ 149.135039] page:ffffffbdc8d2f000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.143157] flags: 0x4000000000000200(arch_1)
[ 149.147647] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.153899] bad because of flags:
[ 149.157305] flags: 0x200(arch_1)
[ 149.160665] Call trace:
[ 149.221361] BUG: Bad page state in process swapper/0 pfn:22fc00
[ 149.227417] page:ffffffbdc8bf0000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.235506] flags: 0x4000000000000200(arch_1)
[ 149.239934] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.246189] bad because of flags:
[ 149.249554] flags: 0x200(arch_1)
[ 149.252978] Call trace:
[ 149.271503] BUG: Bad page state in process swapper/0 pfn:df2c0
[ 149.277494] page:ffffffbdc37cb000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.285617] flags: 0x200(arch_1)
[ 149.288945] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.295146] bad because of flags:
[ 149.298485] flags: 0x200(arch_1)
[ 149.301980] Call trace:
[ 149.314087] BUG: Bad page state in process swapper/0 pfn:df300
[ 149.320118] page:ffffffbdc37cc000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.328174] flags: 0x200(arch_1)
[ 149.331510] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.337724] bad because of flags:
[ 149.341064] flags: 0x200(arch_1)
[ 149.344562] Call trace:
[ 149.357763] BUG: Bad page state in process compiz pfn:df340
[ 149.363528] page:ffffffbdc37cd000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.371617] flags: 0x200(arch_1)
[ 149.374950] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.381200] bad because of flags:
[ 149.384536] flags: 0x200(arch_1)
[ 149.387958] Call trace:
[ 149.412943] BUG: Bad page state in process compiz pfn:22fc80
[ 149.418764] page:ffffffbdc8bf2000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.426860] flags: 0x4000000000000200(arch_1)
[ 149.431338] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.437575] bad because of flags:
[ 149.440941] flags: 0x200(arch_1)
[ 149.444353] Call trace:
[ 149.458610] BUG: Bad page state in process swapper/0 pfn:22fd00
[ 149.464673] page:ffffffbdc8bf4000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.472699] flags: 0x4000000000000200(arch_1)
[ 149.477150] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.483405] bad because of flags:
[ 149.486768] flags: 0x200(arch_1)
[ 149.490097] Call trace:
[ 149.501371] BUG: Bad page state in process swapper/0 pfn:22fcc0
[ 149.507394] page:ffffffbdc8bf3000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.515402] flags: 0x4000000000000200(arch_1)
[ 149.519776] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.525971] bad because of flags:
[ 149.529291] flags: 0x200(arch_1)
[ 149.532586] Call trace:
[ 149.560534] BUG: Bad page state in process swapper/0 pfn:22fd80
[ 149.566571] page:ffffffbdc8bf6000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.574578] flags: 0x4000000000000200(arch_1)
[ 149.578959] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.585137] bad because of flags:
[ 149.588449] flags: 0x200(arch_1)
[ 149.591719] Call trace:
[ 149.601750] BUG: Bad page state in process swapper/0 pfn:22fdc0
[ 149.607766] page:ffffffbdc8bf7000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.615763] flags: 0x4000000000000200(arch_1)
[ 149.620154] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.626347] bad because of flags:
[ 149.629671] flags: 0x200(arch_1)
[ 149.633009] Call trace:
[ 149.670152] BUG: Bad page state in process swapper/0 pfn:22fe00
[ 149.676189] page:ffffffbdc8bf8000 count:0 mapcount:0 mapping: (null) index:0x0
[ 149.684209] flags: 0x4000000000000200(arch_1)
[ 149.688625] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 149.694810] bad because of flags:
[ 149.698127] flags: 0x200(arch_1)
[ 149.701467] Call trace:
-- UHD Device 0
Device Address:
type: x300
addr: 192.168.40.2
fpga: HGS
name:
serial: 30A590A
product: X300
root@tegra-ubuntu:/home/nvidia# [ 152.039007] BUG: Bad page state in process NetworkManager pfn:df380
[ 152.045428] page:ffffffbdc37ce000 count:0 mapcount:0 mapping: (null) index:0x0
[ 152.053570] flags: 0x200(arch_1)
[ 152.056948] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 152.063219] bad because of flags:
[ 152.066626] flags: 0x200(arch_1)
[ 152.070061] Call trace:
root@tegra-ubuntu:/home/nvidia# uhd_find_devicese[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Kusrp_probe
Error: LookupError: KeyError: No devices found for ----->
Empty Device Address
root@tegra-ubuntu:/home/nvidia# uhd_usrp_probefind_devicesifconfig eth1 mtu 9000192.168.40.1e[K
Interrupt:39
UP BROADCAST RUNNING MULTICAST MTU:9000 Metric:1
RX packets:1085 errors:0 dropped:0 overruns:0 frame:0
TX packets:1205 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:65100 (65.1 KB) TX bytes:83489 (83.4 KB)
RX packets:297 errors:0 dropped:0 overruns:0 frame:0
TX packets:297 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:22987 (22.9 KB) TX bytes:22987 (22.9 KB)
RX packets:112 errors:0 dropped:0 overruns:0 frame:0
TX packets:141 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:9337 (9.3 KB) TX bytes:13649 (13.6 KB)
root@tegra-ubuntu:/home/nvidia# ifconfiguhd_usrp_probefind_devicesifconfig eth1 mtu 9000192.168.40.1e[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Ke[Kdown
root@tegra-ubuntu:/home/nvidia# ifconfig eth1 downe[Ke[Ke[Ke[K192.15e[K7e[K68.40.1
[ 207.052047] 8021q: adding VLAN 0 to HW filter on device eth1
root@tegra-ubuntu:/home/nvidia# ifconfig eth1 mtu 9000192.168.40.1e[8Pdowne[Kuhd_usrp_probefind_devices
[ 223.821464] BUG: Bad page state in process swapper/0 pfn:22ff80
[ 223.827528] page:ffffffbdc8bfe000 count:0 mapcount:0 mapping: (null) index:0x0
[ 223.835570] flags: 0x4000000000000200(arch_1)
[ 223.839983] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 223.846202] bad because of flags:
[ 223.849577] flags: 0x200(arch_1)
[ 223.852996] Call trace:
[ 223.874400] BUG: Bad page state in process swapper/0 pfn:22ffc0
[ 223.880450] page:ffffffbdc8bff000 count:0 mapcount:0 mapping: (null) index:0x0
[ 223.888502] flags: 0x4000000000000200(arch_1)
[ 223.892946] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 223.899137] bad because of flags:
[ 223.902501] flags: 0x200(arch_1)
[ 223.905917] Call trace:
[ 223.927114] BUG: Bad page state in process swapper/0 pfn:22f800
[ 223.933160] page:ffffffbdc8be0000 count:0 mapcount:0 mapping: (null) index:0x0
[ 223.941192] flags: 0x4000000000000200(arch_1)
[ 223.945654] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 223.951850] bad because of flags:
[ 223.955195] flags: 0x200(arch_1)
[ 223.958596] Call trace:
[ 223.980018] BUG: Bad page state in process swapper/0 pfn:22f840
[ 223.986107] page:ffffffbdc8be1000 count:0 mapcount:0 mapping: (null) index:0x0
[ 223.994145] flags: 0x4000000000000200(arch_1)
[ 223.998570] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 224.004799] bad because of flags:
[ 224.008149] flags: 0x200(arch_1)
[ 224.011543] Call trace:
[ 224.023300] BUG: Bad page state in process swapper/0 pfn:22f880
[ 224.029337] page:ffffffbdc8be2000 count:0 mapcount:0 mapping: (null) index:0x0
[ 224.037422] flags: 0x4000000000000200(arch_1)
[ 224.041912] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 224.048142] bad because of flags:
[ 224.051487] flags: 0x200(arch_1)
[ 224.054870] Call trace:
[ 224.095984] BUG: Bad page state in process swapper/0 pfn:22f900
[ 224.102080] page:ffffffbdc8be4000 count:0 mapcount:0 mapping: (null) index:0x0
[ 224.110149] flags: 0x4000000000000200(arch_1)
[ 224.114578] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 224.120786] bad because of flags:
[ 224.124140] flags: 0x200(arch_1)
[ 224.127601] Call trace:
[ 224.139894] BUG: Bad page state in process swapper/0 pfn:22f8c0
[ 224.145981] page:ffffffbdc8be3000 count:0 mapcount:0 mapping: (null) index:0x0
[ 224.154044] flags: 0x4000000000000200(arch_1)
[ 224.158497] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 224.164751] bad because of flags:
[ 224.168111] flags: 0x200(arch_1)
[ 224.171596] Call trace:
[ 224.281010] BUG: Bad page state in process swapper/0 pfn:22fa00
[ 224.287117] page:ffffffbdc8be8000 count:0 mapcount:0 mapping: (null) index:0x0
[ 224.295166] flags: 0x4000000000000200(arch_1)
[ 224.299590] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 224.305815] bad because of flags:
[ 224.309164] flags: 0x200(arch_1)
[ 224.312581] Call trace:
[ 224.334252] BUG: Bad page state in process swapper/0 pfn:22fa40
[ 224.340314] page:ffffffbdc8be9000 count:0 mapcount:0 mapping: (null) index:0x0
[ 224.348368] flags: 0x4000000000000200(arch_1)
[ 224.352822] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 224.359018] bad because of flags:
[ 224.362372] flags: 0x200(arch_1)
[ 224.365813] Call trace:
[ 224.377422] BUG: Bad page state in process swapper/0 pfn:22f980
[ 224.383490] page:ffffffbdc8be6000 count:0 mapcount:0 mapping: (null) index:0x0
[ 224.391557] flags: 0x4000000000000200(arch_1)
[ 224.395981] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 224.402206] bad because of flags:
[ 224.405555] flags: 0x200(arch_1)
[ 224.408965] Call trace:
[ 224.420523] BUG: Bad page state in process swapper/0 pfn:22fa80
[ 224.426592] page:ffffffbdc8bea000 count:0 mapcount:0 mapping: (null) index:0x0
[ 224.434653] flags: 0x4000000000000200(arch_1)
[ 224.439089] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 224.445303] bad because of flags:
[ 224.448652] flags: 0x200(arch_1)
[ 224.452084] Call trace:
[ 224.463871] BUG: Bad page state in process swapper/0 pfn:22f9c0
[ 224.469946] page:ffffffbdc8be7000 count:0 mapcount:0 mapping: (null) index:0x0
[ 224.477997] flags: 0x4000000000000200(arch_1)
[ 224.482467] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 224.488696] bad because of flags:
[ 224.492054] flags: 0x200(arch_1)
[ 224.495458] Call trace:
[ 224.507556] BUG: Bad page state in process swapper/0 pfn:22fac0
[ 224.513592] page:ffffffbdc8beb000 count:0 mapcount:0 mapping: (null) index:0x0
[ 224.521656] flags: 0x4000000000000200(arch_1)
[ 224.526116] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 224.532340] bad because of flags:
[ 224.535672] flags: 0x200(arch_1)
[ 224.539053] Call trace:
-- UHD Device 0
Device Address:
type: x300
addr: 192.168.40.2
fpga: HGS
name:
serial: 30A590A
product: X300
root@tegra-ubuntu:/home/nvidia# uhd_find_devicesifconfig eth1 mtu 9000192.168.40.1e[8Pdowne[K
Interrupt:39
inet addr:192.168.40.1 Bcast:192.168.40.255 Mask:255.255.255.0
inet6 addr: fe80::20a:cdff:fe2e:4a4e/64 Scope:Link
RX packets:2162 errors:0 dropped:0 overruns:0 frame:0
TX packets:2326 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:129720 (129.7 KB) TX bytes:151945 (151.9 KB)
RX packets:334 errors:0 dropped:0 overruns:0 frame:0
TX packets:334 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:26029 (26.0 KB) TX bytes:26029 (26.0 KB)
RX packets:131 errors:0 dropped:0 overruns:0 frame:0
TX packets:164 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:11321 (11.3 KB) TX bytes:15631 (15.6 KB)
root@tegra-ubuntu:/home/nvidia# ifconfiguhd_find_devicesifconfig eth1 mtu 9000192.168.40.1e[8Pdowne[Kuhd_usrp_probe
[ 238.309522] BUG: Bad page state in process swapper/0 pfn:ddd00
[ 238.315510] page:ffffffbdc3774000 count:0 mapcount:0 mapping: (null) index:0x0
[ 238.323586] flags: 0x200(arch_1)
[ 238.326914] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 238.333155] bad because of flags:
[ 238.336524] flags: 0x200(arch_1)
[ 238.339961] Call trace:
[ 238.358098] BUG: Bad page state in process swapper/0 pfn:22fb80
[ 238.364192] page:ffffffbdc8bee000 count:0 mapcount:0 mapping: (null) index:0x0
[ 238.372238] flags: 0x4000000000000200(arch_1)
[ 238.376664] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 238.382880] bad because of flags:
[ 238.386239] flags: 0x200(arch_1)
[ 238.389652] Call trace:
[ 238.473690] BUG: Bad page state in process swapper/0 pfn:dddc0
[ 238.479659] page:ffffffbdc3777000 count:0 mapcount:0 mapping: (null) index:0x0
[ 238.487731] flags: 0x200(arch_1)
[ 238.491054] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 238.497274] bad because of flags:
[ 238.500615] flags: 0x200(arch_1)
[ 238.504089] Call trace:
[ 238.516224] BUG: Bad page state in process swapper/0 pfn:ddd40
[ 238.522236] page:ffffffbdc3775000 count:0 mapcount:0 mapping: (null) index:0x0
[ 238.530303] flags: 0x200(arch_1)
[ 238.533616] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 238.539838] bad because of flags:
[ 238.543199] flags: 0x200(arch_1)
[ 238.546662] Call trace:
[ 238.558214] BUG: Bad page state in process swapper/0 pfn:dde00
[ 238.564225] page:ffffffbdc3778000 count:0 mapcount:0 mapping: (null) index:0x0
[ 238.572269] flags: 0x200(arch_1)
[ 238.575597] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 238.581824] bad because of flags:
[ 238.585171] flags: 0x200(arch_1)
[ 238.588570] Call trace:
[ 238.606941] BUG: Bad page state in process swapper/0 pfn:22f480
[ 238.613024] page:ffffffbdc8bd2000 count:0 mapcount:0 mapping: (null) index:0x0
[ 238.621067] flags: 0x4000000000000200(arch_1)
[ 238.625543] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 238.631736] bad because of flags:
[ 238.635065] flags: 0x200(arch_1)
[ 238.638455] Call trace:
[ 238.659618] BUG: Bad page state in process swapper/0 pfn:22f4c0
[ 238.665692] page:ffffffbdc8bd3000 count:0 mapcount:0 mapping: (null) index:0x0
[ 238.673741] flags: 0x4000000000000200(arch_1)
[ 238.678163] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 238.684378] bad because of flags:
[ 238.687736] flags: 0x200(arch_1)
[ 238.691128] Call trace:
[ 238.702792] BUG: Bad page state in process swapper/0 pfn:22f440
[ 238.708830] page:ffffffbdc8bd1000 count:0 mapcount:0 mapping: (null) index:0x0
[ 238.716867] flags: 0x4000000000000200(arch_1)
[ 238.721320] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 238.727547] bad because of flags:
[ 238.730904] flags: 0x200(arch_1)
[ 238.734275] Call trace:
[ 238.789230] BUG: Bad page state in process swapper/0 pfn:dde40
[ 238.795192] page:ffffffbdc3779000 count:0 mapcount:0 mapping: (null) index:0x0
[ 238.803292] flags: 0x200(arch_1)
[ 238.806611] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 238.812806] bad because of flags:
[ 238.816139] flags: 0x200(arch_1)
[ 238.819554] Call trace:
-- X300 initialization sequence...
-- Determining maximum frame size... 8000 bytes.
-- Setup basic communication...
Error: RuntimeError: Expected FPGA compatibility number 19, but got 33:
The FPGA image on your device is not compatible with this host code build.
Download the appropriate FPGA images for this version of UHD.
Please run:
"/usr/lib/uhd/utils/uhd_images_downloader.py"
Then burn a new image to the on-board flash storage of your
USRP X3xx device using the image loader utility. Use this command:
"/usr/bin/uhd_image_loader" --args="type=x300,addr=192.168.40.2"
For more information, refer to the UHD manual:
http://files.ettus.com/manual/page_usrp_x3x0.html#x3x0_flash
root@tegra-ubuntu:/home/nvidia# [ 266.039129] BUG: Bad page state in process NetworkManager pfn:22f5c8
[ 266.045643] page:ffffffbdc8bd7200 count:0 mapcount:0 mapping: (null) index:0x0
[ 266.053835] flags: 0x4000000000000200(arch_1)
[ 266.058328] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 266.064558] bad because of flags:
[ 266.067873] flags: 0x200(arch_1)
[ 266.071308] Call trace:
[ 277.764726] BUG: Bad page state in process swapper/0 pfn:22f5d0
[ 277.770826] page:ffffffbdc8bd7400 count:0 mapcount:0 mapping: (null) index:0x0
[ 277.778882] flags: 0x4000000000000200(arch_1)
[ 277.783353] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 277.789564] bad because of flags:
[ 277.792899] flags: 0x200(arch_1)
[ 277.796312] Call trace:
[ 292.776522] BUG: Bad page state in process swapper/0 pfn:22f5d4
[ 292.782615] page:ffffffbdc8bd7500 count:0 mapcount:0 mapping: (null) index:0x0
[ 292.790665] flags: 0x4000000000000200(arch_1)
[ 292.795096] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 292.801310] bad because of flags:
[ 292.804672] flags: 0x200(arch_1)
[ 292.808077] Call trace:
root@tegra-ubuntu:/home/nvidia# [ 308.031086] BUG: Bad page state in process swapper/0 pfn:22f66c
[ 308.037185] page:ffffffbdc8bd9b00 count:0 mapcount:0 mapping: (null) index:0x0
[ 308.045294] flags: 0x4000000000000200(arch_1)
[ 308.049781] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 308.056059] bad because of flags:
[ 308.059421] flags: 0x200(arch_1)
[ 308.062925] Call trace:
[ 309.878061] BUG: Bad page state in process swapper/0 pfn:ddc20
[ 309.884085] page:ffffffbdc3770800 count:0 mapcount:0 mapping: (null) index:0x0
[ 309.892146] flags: 0x200(arch_1)
[ 309.895472] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 309.901712] bad because of flags:
[ 309.905081] flags: 0x200(arch_1)
[ 309.908504] Call trace:
[ 309.961721] BUG: Bad page state in process Xorg pfn:ddd20
[ 309.967295] page:ffffffbdc3774800 count:0 mapcount:0 mapping: (null) index:0x0
[ 309.975389] flags: 0x200(arch_1)
[ 309.978693] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 309.984914] bad because of flags:
[ 309.988262] flags: 0x200(arch_1)
[ 309.991572] Call trace:
[ 309.998551] BUG: Bad page state in process gdbus pfn:26a864
[ 310.004285] page:ffffffbdc9aa1900 count:0 mapcount:0 mapping: (null) index:0x0
[ 310.012334] flags: 0x4000000000000200(arch_1)
[ 310.016761] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 310.022993] bad because of flags:
[ 310.026344] flags: 0x200(arch_1)
[ 310.029696] Call trace:
[ 310.033277] BUG: Bad page state in process gdbus pfn:26abac
[ 310.038974] page:ffffffbdc9aaeb00 count:0 mapcount:0 mapping: (null) index:0x0
[ 310.047012] flags: 0x4000000000000200(arch_1)
[ 310.051429] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 310.057633] bad because of flags:
[ 310.060970] flags: 0x200(arch_1)
[ 310.064311] Call trace:
[ 310.070070] BUG: Bad page state in process kworker/0:1H pfn:22fc3c
[ 310.076375] page:ffffffbdc8bf0f00 count:0 mapcount:0 mapping: (null) index:0x0
[ 310.084405] flags: 0x4000000000000200(arch_1)
[ 310.088824] page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
[ 310.095013] bad because of flags:
[ 310.098339] flags: 0x200(arch_1)
[ 310.101699] Call trace:
[ 310.106805] page:ffffffbdc8d2ae00 count:0 mapcount:0 mapping: (null) index:0x0
[ 310.114800] flags: 0x4000000000000200(arch_1)
[ 310.119170] page dumped because: VM_BUG_ON_PAGE(page->flags & (((1 << 21) - 1) & ~0))
[ 310.126994] Kernel BUG at ffffffc00016f86c [verbose debug info unavailable]
[ 310.133942] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 310.139414] Modules linked in: fuse bnep bluetooth tn40xx(O) bcmdhd pci_tegra bluedroid_pm
[ 310.147741] CPU: 5 PID: 1934 Comm: uhd_usrp_probe Tainted: G B O 4.4.15-tegra #1
[ 310.156073] Hardware name: quill (DT)
[ 310.159727] task: ffffffc0680f3e80 ti: ffffffc1f68fc000 task.ti: ffffffc1f68fc000
[ 310.167196] PC is at free_one_page+0x380/0x3f0
[ 310.171628] LR is at free_one_page+0x3d8/0x3f0
[ 310.176059] pc : [<ffffffc00016f86c>] lr : [<ffffffc00016f8c4>] pstate: 400001c5
[ 310.183437] sp : ffffffc1f68ffb00
[ 310.186742] x29: ffffffc1f68ffb00 x28: ffffffc1edf74b00
[ 310.192058] x27: 0000000000000018 x26: 0000000000000000
[ 310.197374] x25: ffffffc00124e180 x24: 0000000000000000
[ 310.202691] x23: ffffffc00124e700 x22: 0000000000000002
[ 310.208005] x21: 0000000000234ab8 x20: 0000000000000002
[ 310.213319] x19: ffffffbdc8d2ae00 x18: 00000000000010d8
[ 310.218633] x17: 0000007fa774ec68 x16: ffffffc0008e6334
[ 310.223949] x15: 0007a67c1ea8c33a x14: 26207367616c663e
[ 310.229265] x13: 2d65676170284547 x12: 41505f4e4f5f4755
[ 310.234581] x11: 425f4d56203a6573 x10: 7561636562206465
[ 310.239896] x9 : 0000000000000ae5 x8 : 31202d2029313220
[ 310.245211] x7 : 0000000000000000 x6 : ffffff8000494f38
[ 310.250525] x5 : 0000000000000000 x4 : 0000000000000001
[ 310.255841] x3 : ffffffc1f68ff930 x2 : 0000000000000001
[ 310.261154] x1 : ffffffc1f68fc000 x0 : 4000000000000200
[ 310.266469]
[ 310.267954] Process uhd_usrp_probe (pid: 1934, stack limit = 0xffffffc1f68fc020)
[ 310.275333] Call trace:
[ 310.277773] [<ffffffc00016f86c>] free_one_page+0x380/0x3f0
[ 310.283245] [<ffffffc00016f978>] __free_pages_ok+0x9c/0xb0
[ 310.288718] [<ffffffc00016f9a8>] free_compound_page+0x1c/0x24
[ 310.294450] [<ffffffc000176900>] __put_compound_page+0x38/0x60
[ 310.300270] [<ffffffc000176974>] put_compound_page+0x4c/0x364
[ 310.306002] [<ffffffc00017707c>] put_page+0x58/0x70
[ 310.310868] [<ffffffc0008eefa0>] skb_release_data+0x74/0xe0
[ 310.316427] [<ffffffc0008ef030>] skb_release_all+0x24/0x30
[ 310.321899] [<ffffffc0008ef050>] __kfree_skb+0x14/0x28
[ 310.327025] [<ffffffc0008f2e00>] skb_free_datagram_locked+0x78/0xd8
[ 310.333281] [<ffffffc00097714c>] udp_recvmsg+0x38c/0x694
[ 310.338581] [<ffffffc000982f80>] inet_recvmsg+0x6c/0xc4
[ 310.343794] [<ffffffc0008e5120>] sock_recvmsg+0x44/0x54
[ 310.349006] [<ffffffc0008e63d4>] SyS_recvfrom+0xa0/0x104
[ 310.354307] [<ffffffc000084e70>] el0_svc_naked+0x24/0x28
[ 310.359605] ---[ end trace c63bb006497bdf33 ]---
[ 310.366414] note: uhd_usrp_probe[1934] exited with preempt_count 1
[ 313.132015] bwmgr: clk_set_rate failed for freq 18446744073709551506 Hz with errno -22
[ 315.120014] gk20a 17000000.gp10b: gk20a_channel_timeout_handler: Possible job timeout on ch=507
[ 315.128716] gk20a 17000000.gp10b: gk20a_channel_timeout_handler: Confirmed: job on channel 507 timed out
[ 315.138192] ---- mlocks ----
[ 315.141091]
[ 315.142576] ---- syncpts ----
[ 315.145550] id 4 (disp_d) min 3728 max 3729 refs 1 (previous client : )
[ 315.152159] id 5 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 315.158248] id 6 (disp_f) min 1 max 1 refs 1 (previous client : )
[ 315.164335] id 7 (vblank1) min 18758 max 0 refs 1 (previous client : )
[ 315.170864] id 18 (17000000.gp10b_507) min 26960 max 26962 refs 1 (previous client : )
[ 315.178771] id 19 (17000000.gp10b_506) min 22 max 22 refs 1 (previous client : )
[ 315.186159] id 20 (17000000.gp10b_505) min 19154 max 19158 refs 1 (previous client : 17000000.gp10b_505)
[ 315.196040]
[ 315.197525] ---- channels ----
[ 315.200586]
[ 315.200586] channel 0 - 15810000.se
[ 315.200586]
[ 315.207020] NvHost basic channel registers:
[ 315.211201] CMDFIFO_STAT_0: 00002040
[ 315.214862] CMDFIFO_RDATA_0: 0c050082
[ 315.218522] CMDP_OFFSET_0: 00000000
[ 315.222182] CMDP_CLASS_0: 00000000
[ 315.225842] CHANNELSTAT_0: 00000000
[ 315.229500] The CDMA sync queue is empty.
[ 315.233506]
[ 315.234990]
[ 315.234990] channel 1 - 15820000.se
[ 315.234990]
[ 315.241426] NvHost basic channel registers:
[ 315.245605] CMDFIFO_STAT_0: 00002040
[ 315.249265] CMDFIFO_RDATA_0: acce2882
[ 315.252924] CMDP_OFFSET_0: 00000000
[ 315.256583] CMDP_CLASS_0: 00000000
[ 315.260241] CHANNELSTAT_0: 00000000
[ 315.263892] The CDMA sync queue is empty.
[ 315.267898]
[ 315.269393]
[ 315.269393] channel 2 - 15830000.se
[ 315.269393]
[ 315.275828] NvHost basic channel registers:
[ 315.280008] CMDFIFO_STAT_0: 00002040
[ 315.283660] CMDFIFO_RDATA_0: 28d00b48
[ 315.287320] CMDP_OFFSET_0: 00000000
[ 315.290979] CMDP_CLASS_0: 00000000
[ 315.294640] CHANNELSTAT_0: 00000000
[ 315.298298] The CDMA sync queue is empty.
[ 315.302303]
[ 315.303787]
[ 315.303787] channel 3 - 15840000.se
[ 315.303787]
[ 315.310223] NvHost basic channel registers:
[ 315.314402] CMDFIFO_STAT_0: 00002040
[ 315.318062] CMDFIFO_RDATA_0: 0009c010
[ 315.321721] CMDP_OFFSET_0: 00000000
[ 315.325381] CMDP_CLASS_0: 00000000
[ 315.329040] CHANNELSTAT_0: 00000000
[ 315.332698] The CDMA sync queue is empty.
[ 315.336703]
[ 315.338190]
[ 315.338190] ---- host general irq ----
[ 315.338190]
[ 315.344887] sync_intc0mask = 0x00000001
[ 315.348716] sync_intmask = 0x50000003
[ 315.352372]
[ 315.352372] ---- host syncpt irq mask ----
[ 315.352372]
[ 315.359410]
[ 315.359410] ---- host syncpt irq status ----
[ 315.359410]
[ 315.366622] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 315.372015] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 315.377404] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 315.382794] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 315.388184] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 315.393573] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 315.398963] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 315.404351] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 315.409740] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 315.415130] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 315.420520] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 315.425996] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 315.431473] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 315.436950] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 315.442426] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 315.447903] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 315.453378] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 315.458854] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 315.464333] 17000000.gp10b pbdma 0:
[ 315.467726] id: 0 (tsg), next_id: 0 (tsg) status: valid
[ 315.473129] PUT: 0000002000069520 GET: 0000002000069520 FETCH: 00000dfb HEADER: 20000074
[ 315.481204]
[ 315.482689] 17000000.gp10b eng 0:
[ 315.485912] id: 0 (tsg), next_id: 0 (tsg), ctx: valid busy
[ 315.491491]
[ 315.493162] 17000000.gp10b eng 1:
[ 315.496385] id: 0 (tsg), next_id: 0 (tsg), ctx: invalid [ 315.501693]
[ 315.503176]
[ 319.720003] sdhci-tegra 3440000.sdhci: clock enable is failed, ret: -110
[ 329.727977] mmc1: Timeout waiting for hardware interrupt.
[ 329.733366] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 329.739185] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 329.745005] sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000000
[ 329.750825] sdhci: Argument: 0x92003e01 | Trn mode: 0x00000013
[ 329.756644] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000016
[ 329.762463] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 329.768281] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 329.774099] sdhci: Timeout: 0x0000000e | Int stat: 0x00000001
[ 329.779918] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
[ 329.785737] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 329.791556] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 329.797374] sdhci: Cmd: 0x0000341a | Max curr: 0x00000000
[ 329.803191] sdhci: Host ctl2: 0x0000300b
[ 329.807104] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000f2100010
[ 329.813614] sdhci: ===========================================
[ 331.371972] INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 331.377630] 0-...: (1 GPs behind) idle=ecb/1/0 softirq=16702/16702 fqs=1243
[ 331.384747] (detected by 3, t=5252 jiffies, g=6535, c=6534, q=207)
[ 331.391010] Task dump for CPU 0:
[ 331.394228] swapper/0 R running task 0 0 0 0x00000002
[ 331.401278] Call trace:
[ 331.403722] [<ffffffc000085db8>] __switch_to+0xa4/0xb0
[ 331.408851] [<ffffffc0010f7ea0>] init_thread_union+0x3ea0/0x4000
[ 331.414844] rcu_preempt kthread starved for 4007 jiffies! g6535 c6534 f0x0 s3 ->state=0x1
[ 333.111985] gk20a 17000000.gp10b: gk20a_wait_until_counter_is_N: gk20a_free_channel: channel 505, still waiting, references left: 5, waiting for: 1
[ 338.123975] gk20a 17000000.gp10b: gk20a_wait_until_counter_is_N: gk20a_free_channel: channel 505, still waiting, references left: 5, waiting for: 1
[ 339.839961] mmc1: Timeout waiting for hardware interrupt.
[ 339.845347] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 339.851166] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 339.856985] sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000000
[ 339.862803] sdhci: Argument: 0x92003e01 | Trn mode: 0x00000013
[ 339.868621] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000016
[ 339.874439] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 339.880258] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 339.886077] sdhci: Timeout: 0x0000000e | Int stat: 0x00000001
[ 339.891895] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
[ 339.897715] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 339.903533] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 339.909352] sdhci: Cmd: 0x0000341a | Max curr: 0x00000000
[ 339.915169] sdhci: Host ctl2: 0x0000300b
[ 339.919082] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000f2100010
[ 339.925592] sdhci: ===========================================
[ 342.919985] ata1.00: exception Emask 0x0 SAct 0x2000 SErr 0x0 action 0x6 frozen
[ 342.927290] ata1.00: failed command: READ FPDMA QUEUED
[ 342.932494] ata1.00: cmd 60/70:68:50:86:14/00:00:00:00:00/40 tag 13 ncq 57344 in
[ 342.932494] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 342.947287] ata1.00: status: { DRDY }
[ 342.950986] ata1: hard resetting link
[ 343.135965] gk20a 17000000.gp10b: gk20a_wait_until_counter_is_N: gk20a_free_channel: channel 505, still waiting, references left: 5, waiting for: 1
[ 343.443978] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 348.147958] gk20a 17000000.gp10b: gk20a_wait_until_counter_is_N: gk20a_free_channel: channel 505, still waiting, references left: 5, waiting for: 1
[ 348.161156] Watchdog detected hard LOCKUP on cpu 4
[ 348.161156] ------------[ cut here ]------------
[ 348.161157] WARNING: at ffffffc000137e04 [verbose debug info unavailable]
[ 348.161166] Modules linked in: fuse bnep bluetooth tn40xx(O) bcmdhd pci_tegra bluedroid_pm
[ 348.161166]
[ 348.161170] CPU: 3 PID: 1258 Comm: compiz Tainted: G B D O 4.4.15-tegra #1
[ 348.161171] Hardware name: quill (DT)
[ 348.161173] task: ffffffc1dcae3e80 ti: ffffffc06a868000 task.ti: ffffffc06a868000
[ 348.161179] PC is at watchdog_timer_fn+0x230/0x33c
[ 348.161182] LR is at watchdog_timer_fn+0x230/0x33c
[ 348.161184] pc : [<ffffffc000137e04>] lr : [<ffffffc000137e04>] pstate: 800001c5
[ 348.161184] sp : ffffffc06a86b5a0
[ 348.161187] x29: ffffffc06a86b5a0 x28: 0000000000000004
[ 348.161189] x27: ffffffc0010fcb28 x26: ffffffc1ffe2e260
[ 348.161191] x25: ffffffc0010cf2c0 x24: ffffffc06a86b880
[ 348.161193] x23: 0000000000000000 x22: 0000000000000000
[ 348.161195] x21: ffffffc0010fc000 x20: ffffffc0010cf000
[ 348.161197] x19: ffffffc0010cf248 x18: ffffffc000ad5840
[ 348.161199] x17: 000000000000000e x16: ffffffc000a6da80
[ 348.161201] x15: 0000000000000004 x14: 0000000000a41ba3
[ 348.161203] x13: 00000000009d3000 x12: 0000000000a41ba3
[ 348.161205] x11: ffffffc000a6d9f0 x10: ffffffc0012bae88
[ 348.161206] x9 : ffffffc06a86b4f0 x8 : 4c20647261682064
[ 348.161208] x7 : 6574636574656420 x6 : ffffffc0012bb838
[ 348.161210] x5 : 000000028877dabe x4 : 0000000000000000
[ 348.161212] x3 : ffffffc06a86b410 x2 : 0000000000010001
[ 348.161213] x1 : ffffffc06a868000 x0 : 0000000000000026
[ 348.161214]
[ 348.161215] ---[ end trace c63bb006497bdf34 ]---
[ 348.161216] Call trace:
[ 348.161219] [<ffffffc000137e04>] watchdog_timer_fn+0x230/0x33c
[ 348.161223] [<ffffffc00010296c>] __hrtimer_run_queues+0x140/0x350
[ 348.161226] [<ffffffc0001033cc>] hrtimer_interrupt+0x9c/0x1e0
[ 348.161230] [<ffffffc000842b14>] tegra186_timer_isr+0x24/0x30
[ 348.161234] [<ffffffc0000f02f4>] handle_irq_event_percpu+0x84/0x290
[ 348.161236] [<ffffffc0000f0544>] handle_irq_event+0x44/0x74
[ 348.161238] [<ffffffc0000f384c>] handle_fasteoi_irq+0xb4/0x188
[ 348.161241] [<ffffffc0000ef914>] generic_handle_irq+0x24/0x38
[ 348.161243] [<ffffffc0000efc1c>] __handle_domain_irq+0x60/0xb4
[ 348.161245] [<ffffffc0000815dc>] gic_handle_irq+0x5c/0xb4
[ 348.161248] [<ffffffc0000845e8>] el1_irq+0x68/0xd8
[ 348.161250] [<ffffffc0000eeb08>] vprintk_emit+0x318/0x52c
[ 348.161254] [<ffffffc00052c344>] dev_vprintk_emit+0xe0/0x1dc
[ 348.161255] [<ffffffc00052c494>] dev_printk_emit+0x54/0x5c
[ 348.161257] [<ffffffc00052c4e0>] __dev_printk+0x44/0x8c
[ 348.161259] [<ffffffc00052c7f8>] dev_warn+0x64/0x6c
[ 348.161263] [<ffffffc00047f678>] gk20a_wait_until_counter_is_N.isra.12.constprop.24+0x104/0x12c
[ 348.161266] [<ffffffc00048279c>] gk20a_free_channel+0x94/0x5c4
[ 348.161268] [<ffffffc000482d38>] gk20a_channel_release+0x58/0x160
[ 348.161272] [<ffffffc0001bfa2c>] __fput+0x90/0x1bc
[ 348.161273] [<ffffffc0001bfbb4>] ____fput+0xc/0x14
[ 348.161276] [<ffffffc0000bb290>] task_work_run+0xa8/0xc4
[ 348.161279] [<ffffffc000088d08>] do_notify_resume+0x58/0x68
[ 348.161281] [<ffffffc000084d68>] work_pending+0x1c/0x20
[ 348.449812] ata1.00: qc timeout (cmd 0xec)
[ 348.455208] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 348.461306] ata1.00: revalidation failed (errno=-5)
[ 348.466239] ata1: hard resetting link
[ 348.959966] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 349.951944] mmc1: Timeout waiting for hardware interrupt.
[ 349.957332] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 349.963151] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 349.968971] sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000000
[ 349.974789] sdhci: Argument: 0x92003e01 | Trn mode: 0x00000013
[ 349.980609] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000016
[ 349.986427] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 349.992245] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 349.998063] sdhci: Timeout: 0x0000000e | Int stat: 0x00000001
[ 350.003880] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
[ 350.009698] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 350.015516] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 350.021335] sdhci: Cmd: 0x0000341a | Max curr: 0x00000000
[ 350.027152] sdhci: Host ctl2: 0x0000300b
[ 350.031064] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000f2100010
[ 350.037573] sdhci: ===========================================
[ 353.467949] gk20a 17000000.gp10b: gk20a_wait_until_counter_is_N: gk20a_free_channel: channel 505, still waiting, references left: 5, waiting for: 1
[ 358.479941] gk20a 17000000.gp10b: gk20a_wait_until_counter_is_N: gk20a_free_channel: channel 505, still waiting, references left: 5, waiting for: 1
[ 358.963945] ata1.00: qc timeout (cmd 0xec)
[ 358.968096] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 358.974191] ata1.00: revalidation failed (errno=-5)
[ 358.979132] ata1: limiting SATA link speed to 1.5 Gbps
[ 358.984304] ata1: hard resetting link
[ 359.479949] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 360.063926] mmc1: Timeout waiting for hardware interrupt.
[ 360.069312] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 360.075131] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 360.080949] sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000000
[ 360.086769] sdhci: Argument: 0x12003e00 | Trn mode: 0x00000013
[ 360.092588] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000016
[ 360.098405] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 360.104224] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 360.110042] sdhci: Timeout: 0x0000000e | Int stat: 0x00000001
[ 360.115861] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
[ 360.121679] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 360.127497] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 360.133316] sdhci: Cmd: 0x0000341a | Max curr: 0x00000000
[ 360.139134] sdhci: Host ctl2: 0x0000300b
[ 360.143046] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000f2100010
[ 360.149555] sdhci: ===========================================
[ 363.491928] gk20a 17000000.gp10b: gk20a_wait_until_counter_is_N: gk20a_free_channel: channel 505, still waiting, references left: 5, waiting for: 1
[ 368.503923] gk20a 17000000.gp10b: gk20a_wait_until_counter_is_N: gk20a_free_channel: channel 505, still waiting, references left: 5, waiting for: 1
[ 370.175908] mmc1: Timeout waiting for hardware interrupt.
[ 370.181293] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 370.187113] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 370.192933] sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000000
[ 370.198751] sdhci: Argument: 0x12003e00 | Trn mode: 0x00000013
[ 370.204570] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000016
[ 370.210388] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 370.216207] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 370.222025] sdhci: Timeout: 0x0000000e | Int stat: 0x00000001
[ 370.227844] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
[ 370.233662] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 370.239479] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 370.245297] sdhci: Cmd: 0x0000341a | Max curr: 0x00000000
[ 370.251115] sdhci: Host ctl2: 0x0000300b
[ 370.255028] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000f2100010
[ 370.261538] sdhci: ===========================================
[ 373.515913] gk20a 17000000.gp10b: gk20a_wait_until_counter_is_N: gk20a_free_channel: channel 505, still waiting, references left: 5, waiting for: 1
[ 378.527906] gk20a 17000000.gp10b: gk20a_wait_until_counter_is_N: gk20a_free_channel: channel 505, still waiting, references left: 5, waiting for: 1
[ 380.287891] mmc1: Timeout waiting for hardware interrupt.
[ 380.293277] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 380.299097] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 380.304917] sdhci: Blk size: 0x00007080 | Blk cnt: 0x00000000
[ 380.310736] sdhci: Argument: 0x12003e00 | Trn mode: 0x00000013
[ 380.316555] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000016
[ 380.322373] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 380.328191] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 380.334009] sdhci: Timeout: 0x0000000e | Int stat: 0x00000001
[ 380.339826] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
[ 380.345644] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 380.351462] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 380.357280] sdhci: Cmd: 0x0000341a | Max curr: 0x00000000
[ 380.363098] sdhci: Host ctl2: 0x0000300b
[ 380.367010] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000f2100010
[ 380.373520] sdhci: ===========================================
[ 381.879896] sdhci-tegra 3440000.sdhci: clock enable is failed, ret: -62
[ 383.539899] gk20a 17000000.gp10b: gk20a_wait_until_counter_is_N: gk20a_free_channel: channel 505, still waiting, references left: 5, waiting for: 1
[ 391.409635] Bad mode in Synchronous Abort handler detected, code 0x86000005 -- IABT (current EL)
[ 391.409638] Bad mode in Synchronous Abort handler detected, code 0x86000006 -- IABT (current EL)
[ 391.409640] Bad mode in Synchronous Abort handler detected, code 0x86000006 -- IABT (current EL)
[ 391.409642] Bad mode in Synchronous Abort handler detected, code 0x86000005 -- IABT (current EL)
[ 391.409644] Internal error: Oops - bad mode: 0 [#2] PREEMPT SMP
[ 391.409653] Modules linked in: fuse bnep bluetooth tn40xx(O) bcmdhd pci_tegra bluedroid_pm
[ 391.409657] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G B D W O 4.4.15-tegra #1
[ 391.409658] Hardware name: quill (DT)
[ 391.409660] task: ffffffc001104530 ti: ffffffc0010f4000 task.ti: ffffffc0010f4000
[ 391.409663] PC is at 0x0
[ 391.409668] LR is at get_page_from_freelist+0x738/0xa6c
[ 391.409670] pc : [<0000000000000000>] lr : [<ffffffc000171880>] pstate: 200000c5
[ 391.409671] sp : ffffffc0010f77b0
[ 391.409673] x29: ffffffc0010f77b0 x28: ffffffc00124e180
[ 391.409676] x27: 0000000000000003 x26: 0000000021020002
[ 391.409678] x25: ffffffc00124e700 x24: 0000000000000008
[ 391.409680] x23: ffffffc0010fc000 x22: 0000000002095220
[ 391.409682] x21: 00000000020b5220 x20: 0000000000000000
[ 391.409684] x19: 0000000000000003 x18: 0000000003200031
[ 391.409685] x17: 0000007fabbadf18 x16: ffffffc000a6da80
[ 391.409687] x15: 0000000000000001 x14: 0000000000008948
[ 391.409689] x13: 0000000000000008 x12: ffffff8000f45128
[ 391.409691] x11: ffffff8001000064 x10: 0000000000000003
[ 391.409693] x9 : 0000000000000000 x8 : 0000000000000068
[ 391.409695] x7 : ffffffc00124e3d8 x6 : 0000000000000004
[ 391.409696] x5 : ffffffc00124e3c8 x4 : 0000000000006705
[ 391.409698] x3 : 0000000000000003 x2 : 0000000000000040
[ 391.409700] x1 : 0000000067066705 x0 : ffffffc00124e700
[ 391.409701]
[ 391.409702] Process swapper/0 (pid: 0, stack limit = 0xffffffc0010f4020)
[ 391.409703] Call trace:
[ 391.409704] [< (null)>] (null)
[ 391.409707] [<ffffffc000171ce8>] __alloc_pages_nodemask+0x134/0x9f4
[ 391.409709] [<ffffffc000172620>] __alloc_page_frag+0x78/0x178
[ 391.409713] [<ffffffc0008f1fe4>] __napi_alloc_skb+0xb8/0x10c
[ 391.409717] [<ffffffc0008feec8>] napi_get_frags+0x38/0x50
[ 391.409736] [<ffffffbffcf52f20>] bdx_poll+0x2c8/0xca8 [tn40xx]
[ 391.409739] [<ffffffc00090130c>] net_rx_action+0x12c/0x364
[ 391.409742] [<ffffffc0000a41bc>] __do_softirq+0x10c/0x368
[ 391.409744] [<ffffffc0000a4668>] irq_exit+0x84/0xdc
[ 391.409747] [<ffffffc0000efc28>] __handle_domain_irq+0x6c/0xb4
[ 391.409749] [<ffffffc0000815dc>] gic_handle_irq+0x5c/0xb4
[ 391.409751] [<ffffffc0000845e8>] el1_irq+0x68/0xd8
[ 391.409757] [<ffffffc0007368d0>] cpuidle_enter+0x18/0x20
[ 391.409760] [<ffffffc0000e3040>] call_cpuidle+0x28/0x50
[ 391.409762] [<ffffffc0000e31e4>] cpu_startup_entry+0x17c/0x340
[ 391.409765] [<ffffffc000a5cd54>] rest_init+0x84/0x8c
[ 391.409770] [<ffffffc000fba97c>] start_kernel+0x39c/0x3b0
[ 391.409771] [<0000000080a63000>] 0x80a63000
[ 391.409775] ---[ end trace c63bb006497bdf35 ]---
[ 391.409776] Internal error: Oops - bad mode: 0 [#3] PREEMPT SMP
[ 391.411542] Modules linked in: fuse bnep bluetooth tn40xx(O) bcmdhd pci_tegra bluedroid_pm
[ 391.411546] CPU: 5 PID: 717 Comm: in:imklog Tainted: G B D W O 4.4.15-tegra #1
[ 391.411547] Hardware name: quill (DT)
[ 391.411549] task: ffffffc070685780 ti: ffffffc1eb018000 task.ti: ffffffc1eb018000
[ 391.411550] PC is at 0x0
[ 391.411553] LR is at get_page_from_freelist+0x4fc/0xa6c
[ 391.411555] pc : [<0000000000000000>] lr : [<ffffffc000171644>] pstate: 600000c5
[ 391.411555] sp : ffffffc1eb01ba50
[ 391.411558] x29: ffffffc1eb01ba50 x28: ffffffc00124e180
[ 391.411559] Kernel panic - not syncing: Fatal exception in interrupt
[ 391.411561] x27: ffffffc0010d8088 x26: 0000000000000020
[ 391.411563] x25: 00000001fed81000 x24: 0000000000000001
[ 391.411565] x23: ffffffc0010fc000 x22: 00000000024200ca
[ 391.411567] x21: ffffffc1ffe590a8 x20: 0000000000000001
[ 391.411569] x19: ffffffc1ffe59088 x18: 0000000000000014
[ 391.411570] x17: 0000007f7d434760 x16: 000000000048f6b8
[ 391.411572] x15: 00000000000001db x14: 2ce33e6c02ce33e7
[ 391.411574] x13: 000000000000016d x12: a3d70a3d70a3d70b
[ 391.411576] x11: 00000000000000b9 x10: 0000000000000045
[ 391.411578] x9 : 0000000000000002 x8 : 0000000000000000
[ 391.411579] x7 : 0000000000000000 x6 : 0000000000000000
[ 391.411581] x5 : 000000000012f3af x4 : 0000000000000080
[ 391.411583] x3 : 0000000000006705 x2 : 0000000000000002
[ 391.411584] x1 : 0000000067076705 x0 : ffffffc00124e700
[ 391.411585]
[ 391.411587] Process in:imklog (pid: 717, stack limit = 0xffffffc1eb018020)
[ 391.411587] Call trace:
[ 391.411588] [< (null)>] (null)
[ 391.411591] [<ffffffc000171ce8>] __alloc_pages_nodemask+0x134/0x9f4
[ 391.411595] [<ffffffc0001966cc>] handle_mm_fault+0x1200/0x1598
[ 391.411598] [<ffffffc00009ab74>] do_page_fault+0x1c8/0x444
[ 391.411600] [<ffffffc00008139c>] do_mem_abort+0x40/0xa0
[ 391.411602] [<ffffffc000084adc>] el0_da+0x18/0x1c
[ 391.411603] ---[ end trace c63bb006497bdf36 ]---
[ 391.411605] Internal error: Oops - bad mode: 0 [#4] PREEMPT SMP
[ 391.413391] Modules linked in: fuse bnep bluetooth tn40xx(O) bcmdhd pci_tegra bluedroid_pm
[ 391.413394] CPU: 3 PID: 169 Comm: kworker/u12:5 Tainted: G B D W O 4.4.15-tegra #1
[ 391.413395] Hardware name: quill (DT)
[ 391.413401] Workqueue: events_unbound call_usermodehelper_exec_work
[ 391.413402] task: ffffffc1f4025780 ti: ffffffc1ef764000 task.ti: ffffffc1ef764000
[ 391.413404] PC is at 0x0
[ 391.413406] LR is at get_page_from_freelist+0x738/0xa6c
[ 391.413407] pc : [<0000000000000000>] lr : [<ffffffc000171880>] pstate: 200000c5
[ 391.413408] sp : ffffffc1ef767970
[ 391.413411] x29: ffffffc1ef767970 x28: ffffffc00124e180
[ 391.413413] x27: 0000000000000002 x26: ffffffc1c358f380
[ 391.413415] x25: ffffffc00124e700 x24: 0000000000000004
[ 391.413417] x23: ffffffc0010fc000 x22: 00000000026000c0
[ 391.413419] x21: 00000000026200c0 x20: 0000000000000000
[ 391.413421] x19: 0000000000000002 x18: 0000000000000014
[ 391.413423] x17: 0000007f915fd1a8 x16: ffffffc00020027c
[ 391.413425] x15: ffffffc000a6da80 x14: 00000000fa83b2da
[ 391.413426] x13: 0000000000000001 x12: 000000000005cf6d
[ 391.413428] x11: 0000000000000000 x10: 00000000000008a0
[ 391.413430] x9 : 0000000000000000 x8 : 0000000000000068
[ 391.413432] x7 : ffffffc00124e370 x6 : 0000000000000003
[ 391.413434] x5 : ffffffc00124e360 x4 : 0000000000006705
[ 391.413435] x3 : 000000000000000c x2 : 0000000000000040
[ 391.413437] x1 : 0000000067096705 x0 : ffffffc00124e700
[ 391.413437]
[ 391.413439] Process kworker/u12:5 (pid: 169, stack limit = 0xffffffc1ef764020)
[ 391.413440] Call trace:
[ 391.413441] CPU5: stopping
[ 391.413442] [< (null)>] (null)
[ 391.413444] CPU: 5 PID: 717 Comm: in:imklog Tainted: G B D W O 4.4.15-tegra #1
[ 391.413447] [<ffffffc000171ce8>] __alloc_pages_nodemask+0x134/0x9f4
[ 391.413447] Hardware name: quill (DT)
[ 391.413449] [<ffffffc000172834>] alloc_kmem_pages_node+0x30/0x38
[ 391.413450] Call trace:
[ 391.413453] [<ffffffc00009db00>] copy_process.isra.49+0x1a8/0x17e8
[ 391.413457] [<ffffffc000088fd8>] dump_backtrace+0x0/0x100
[ 391.413459] [<ffffffc00009f26c>] _do_fork+0x74/0x38c
[ 391.413461] [<ffffffc0000891a0>] show_stack+0x14/0x1c
[ 391.413463] [<ffffffc00009f5d0>] kernel_thread+0x34/0x3c
[ 391.413467] [<ffffffc0003070f0>] dump_stack+0x90/0xb4
[ 391.413469] [<ffffffc0000b40a0>] call_usermodehelper_exec_work+0x2c/0xd8
[ 391.413472] [<ffffffc00008ec10>] handle_IPI+0x300/0x30c
[ 391.413474] [<ffffffc0000b7240>] process_one_work+0x154/0x434
[ 391.413476] [<ffffffc00008161c>] gic_handle_irq+0x9c/0xb4
[ 391.413478] [<ffffffc0000b7654>] worker_thread+0x134/0x40c
[ 391.413479] [<ffffffc0000845e8>] el1_irq+0x68/0xd8
[ 391.413482] [<ffffffc0000bcebc>] kthread+0xe0/0xf4
[ 391.413483] [<ffffffc0000a4668>] irq_exit+0x84/0xdc
[ 391.413485] [<ffffffc000084e10>] ret_from_fork+0x10/0x40
[ 391.413488] [<ffffffc0000efc28>] __handle_domain_irq+0x6c/0xb4
[ 391.413489] ---[ end trace c63bb006497bdf37 ]---
[ 391.413490] [<ffffffc0000815dc>] gic_handle_irq+0x5c/0xb4
[ 391.413492] [<ffffffc0000845e8>] el1_irq+0x68/0xd8
[ 391.415259] [<ffffffc0000ae354>] exit_signals+0xa8/0x118
[ 391.415262] [<ffffffc0000a1ed8>] do_exit+0x78/0x9a0
[ 391.415264] [<ffffffc000089330>] die+0x188/0x1a0
[ 391.415266] [<ffffffc00008940c>] arm64_notify_die+0x1c/0x58
[ 391.415269] [<ffffffc000089660>] bad_mode+0x84/0x90
[ 391.415271] [<ffffffc000171644>] get_page_from_freelist+0x4fc/0xa6c
[ 391.415272] [<ffffffc000171ce8>] __alloc_pages_nodemask+0x134/0x9f4
[ 391.415274] [<ffffffc0001966cc>] handle_mm_fault+0x1200/0x1598
[ 391.415276] note: kworker/u12:5[169] exited with preempt_count 1
[ 391.415277] [<ffffffc00009ab74>] do_page_fault+0x1c8/0x444
[ 391.415279] [<ffffffc00008139c>] do_mem_abort+0x40/0xa0
[ 391.415280] [<ffffffc000084adc>] el0_da+0x18/0x1c
[ 391.415286] ------------[ cut here ]------------
[ 391.415287] WARNING: at ffffffc0000a452c [verbose debug info unavailable]
[ 391.415292] Modules linked in: fuse bnep bluetooth tn40xx(O) bcmdhd pci_tegra bluedroid_pm
[ 391.415293]
[ 391.415295] CPU: 3 PID: 169 Comm: kworker/u12:5 Tainted: G B D W O 4.4.15-tegra #1
[ 391.415296] Hardware name: quill (DT)
[ 391.415302] task: ffffffc1f4025780 ti: ffffffc1ef764000 task.ti: ffffffc1ef764000
[ 391.415304] PC is at __local_bh_enable_ip+0x68/0xb8
[ 391.415308] LR is at _raw_spin_unlock_bh+0x20/0x28
[ 391.415310] pc : [<ffffffc0000a452c>] lr : [<ffffffc000a62044>] pstate: 400001c5
[ 391.415311] sp : ffffffc1ef767680
[ 391.415313] x29: ffffffc1ef767680 x28: ffffffc00124e180
[ 391.415315] x27: 0000000000000002 x26: ffffffc1f4025780
[ 391.415317] x25: ffffffc1f4025780 x24: 00000000000001c0
[ 391.415319] x23: 0000000000000001 x22: 0000000000000000
[ 391.415321] x21: ffffffc000e27c50 x20: ffffffc1f4025780
[ 391.415322] x19: ffffffc0012de458 x18: 0000000000000014
[ 391.415324] x17: 0000007f915fd1a8 x16: ffffffc00020027c
[ 391.415326] x15: ffffffc000a6da80 x14: 0ffffffffffffffe
[ 391.415328] x13: 0000000000000028 x12: ffffffc001111000
[ 391.415330] x11: ffffffc001298e88 x10: 0000000000000001
[ 391.415332] x9 : 00000000000090ec x8 : ffffffc1f4025fa0
[ 391.415333] x7 : 0000000000000000 x6 : 00000002d9090768
[ 391.415335] x5 : ffffffc001115238 x4 : ffffffc0010fd048
[ 391.415337] x3 : ffffffc001115198 x2 : 0000000000000000
[ 391.415339] x1 : 0000000000000201 x0 : ffffffc001259000
[ 391.415339]
[ 391.415340] ---[ end trace c63bb006497bdf38 ]---
[ 391.415341] Call trace:
[ 391.415343] [<ffffffc0000a452c>] __local_bh_enable_ip+0x68/0xb8
[ 391.415345] [<ffffffc000a62044>] _raw_spin_unlock_bh+0x20/0x28
[ 391.415352] [<ffffffc0001272ac>] cgroup_exit+0x58/0xe4
[ 391.415354] [<ffffffc0000a20fc>] do_exit+0x29c/0x9a0
[ 391.415356] [<ffffffc0
