are you aware of a network interface card for PC that can be connected directly to he 10GBASE-T port of the Drive AGX device with a HSD-HSD cable?
With such a device we could avoid using the E3585 10G Ethernet dongle, but connect to the device directly.
Any help is appreciated.
Thanks,
Peter
It’s Ethernet 10Gb PHY on Drive AGX to XA and XB by HSD connector, if PC network interface card have HSD connector that should able to work.
Thanks for your reply. That’s exactly my problem: I am not aware of any PC network interface card that has a HSD connector. I tried, but did not find any. Can you recommend a manufacturer and type?
