Hi All,
How to use 10Gbps (10GBASE-KR) Ethernet on my Xavier E3550? Any device I should prepare use to be bridge to connect to them (like 1Gbps 802.3bp Ethernet in port #1~#7 in front of front panel)?
Gary
Hi All,
Gary
Dear garywang,
Are you askng how you can use 10Gbe connections(white color port) in front panel?
Yes.
I saw they should be 10GBASE-KR and seems Dual GbE Dongle w/ HSD Cable is not workable with 2 “10 Gbps 10GBASE-KR Ethernet” ports (based on Front-View).
Could you guide me how to use it?
Gary
Dear garywang,
Could you please check https://developer.download.nvidia.com/driveworks/secure/docs/DRIVE_8.0_Release_Docs/DRIVE_AGX_DevKit_QSG_176-0336-001-drive-agx-developer-kit-p3550-qsg-r5.pdf?i6QXu3BgsmKifEGCupWOqP4SOzW2dBbFjsmxH5MEI2SaD-AK7MVxMy__-WuRiCaO2vwRP0CM1XBFExSfVnyYxX31kI30mztgfGyHDY6cgOMlj7GdV6YPH3l-FN8l4RuUl_Kgr0LbHHMpsMGaRDWTKKQmJKatatZR5kRvwnIJAQfKkCu7GvzJ3pMdQdK0LIVNV_p6ctQn3B9RqDpkWRwHhArzb5LIOnuOE7_E2XNAmtavTVU6c1Xs(Page 10). The dual dongle supports only 1Gbe.
Yes I know.
Because our system is based on 10G bandwidth network migrated from PX2 (TegraA with 10G Ethernet), then I need 10Gbe connections work with my Xavier E3550.
Thanks for your help!
Gary
Dear garywang,
Are you asking to connect 10GbE to RJ45 via dongle? 10Gbe connctions is meant for box-box to communication.
Dear SivaRamaKrishna,
I’m confused about 10GbE ports specification because of different discription on each documents.
Which one from below is these 10GbE ports specification with HSD connector on fron panel ?
Any Update??
Any information would be appreciated.
Dear atsutaka,
Sorry for late update.
10GBASE-T : This is the correct one. Please use this one.
We will update/release DRIVE_Mech_Inst_Guide and DRIVE_AGX_DevKit_QSG you mentioned. Thanks.
