11_CAMERA_OBJECT_IDENTIFICATION
I used JetPack 3.1 to flash TX1 and I follow the guide to run do this example. However, in the last step, when I used the command “./camera_caffe…”(I omit some code), it shows “error==cudasuccess(35 vs. 0)” on the screen.
Could anyone can help me to solve this problem?
Hi 361655243,
We can run “11_CAMERA_OBJECT_IDENTIFICATION” normally on JetPack3.1/TX1.
Could you re-install the JetPack, Caffe and run the sample again?
