I tried to print video4linux debug messages.
[ 853.040842] videodev: v4l2_open: video0: open (0)
[ 853.040876] video0: VIDIOC_QUERYCAP: driver=tegra-video, card=vi-output, imx219 9-0010, bus=platform:tegra-capture-vi:0, version=0x00050a68, capabilities=0x84200001, device_caps=0x04200001
[ 853.040942] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a0001, type=6, name=Camera Controls, min/max=0/0, step=0, default=0, flags=0x00000044, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.041027] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2003, type=2, name=Group Hold, min/max=0/1, step=1, default=0, flags=0x00000200, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.041097] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2008, type=5, name=Sensor Mode, min/max=0/7, step=1, default=0, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.041139] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2009, type=5, name=Gain, min/max=16/170, step=1, default=16, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.041206] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200a, type=5, name=Exposure, min/max=13/683709, step=1, default=2495, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.041248] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200b, type=5, name=Frame Rate, min/max=2000000/30000000, step=1, default=30000000, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.041289] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2032, type=258, name=Sensor configuration, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=22, nr_of_dims=1, dims=22,0,0,0
[ 853.041357] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2033, type=258, name=Sensor mode I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 853.041399] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2034, type=258, name=Sensor control I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 853.041439] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2064, type=9, name=Bypass Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.041478] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2065, type=9, name=Override Enable, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.041517] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2066, type=1, name=Height Align, min/max=1/16, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.041556] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2067, type=9, name=Size Align, min/max=0/2, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.041595] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2068, type=1, name=Write ISP format, min/max=1/1, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.041676] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2069, type=258, name=Sensor Signal Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=126, nr_of_dims=2, dims=30,18,0,0
[ 853.041797] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206a, type=258, name=Sensor Image Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 853.041959] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206b, type=258, name=Sensor Control Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=252, nr_of_dims=2, dims=30,36,0,0
[ 853.042010] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206c, type=258, name=Sensor DV Timings, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 853.042043] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206d, type=2, name=Low Latency Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.042075] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206e, type=1, name=Preferred Stride, min/max=0/65535, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.042117] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2082, type=1, name=Sensor Modes, min/max=0/30, step=1, default=30, flags=0x00000004, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.042153] video0: VIDIOC_QUERY_EXT_CTRL: error -22: id=0xc09a2082, type=0, name=, min/max=0/0, step=0, default=0, flags=0x00000000, elem_size=0, elems=0, nr_of_dims=0, dims=0,0,0,0
[ 853.042216] videodev: v4l2_release: video0: release
[ 853.046921] videodev: v4l2_open: video0: open (0)
[ 853.046944] video0: VIDIOC_QUERYCAP: driver=tegra-video, card=vi-output, imx219 9-0010, bus=platform:tegra-capture-vi:0, version=0x00050a68, capabilities=0x84200001, device_caps=0x04200001
[ 853.046985] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a0001, type=6, name=Camera Controls, min/max=0/0, step=0, default=0, flags=0x00000044, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047020] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2003, type=2, name=Group Hold, min/max=0/1, step=1, default=0, flags=0x00000200, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047073] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2008, type=5, name=Sensor Mode, min/max=0/7, step=1, default=0, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047106] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2009, type=5, name=Gain, min/max=16/170, step=1, default=16, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047142] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200a, type=5, name=Exposure, min/max=13/683709, step=1, default=2495, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047177] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200b, type=5, name=Frame Rate, min/max=2000000/30000000, step=1, default=30000000, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047211] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2032, type=258, name=Sensor configuration, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=22, nr_of_dims=1, dims=22,0,0,0
[ 853.047244] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2033, type=258, name=Sensor mode I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 853.047305] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2034, type=258, name=Sensor control I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 853.047339] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2064, type=9, name=Bypass Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047378] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2065, type=9, name=Override Enable, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047411] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2066, type=1, name=Height Align, min/max=1/16, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047443] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2067, type=9, name=Size Align, min/max=0/2, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047502] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2068, type=1, name=Write ISP format, min/max=1/1, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047535] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2069, type=258, name=Sensor Signal Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=126, nr_of_dims=2, dims=30,18,0,0
[ 853.047569] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206a, type=258, name=Sensor Image Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 853.047626] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206b, type=258, name=Sensor Control Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=252, nr_of_dims=2, dims=30,36,0,0
[ 853.047660] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206c, type=258, name=Sensor DV Timings, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 853.047693] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206d, type=2, name=Low Latency Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047725] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206e, type=1, name=Preferred Stride, min/max=0/65535, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047757] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2082, type=1, name=Sensor Modes, min/max=0/30, step=1, default=30, flags=0x00000004, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.047789] video0: VIDIOC_QUERY_EXT_CTRL: error -22: id=0xc09a2082, type=0, name=, min/max=0/0, step=0, default=0, flags=0x00000000, elem_size=0, elems=0, nr_of_dims=0, dims=0,0,0,0
[ 853.047830] videodev: v4l2_release: video0: release
[ 853.095302] videodev: v4l2_open: video0: open (0)
[ 853.095334] video0: VIDIOC_QUERYCAP: driver=tegra-video, card=vi-output, imx219 9-0010, bus=platform:tegra-capture-vi:0, version=0x00050a68, capabilities=0x84200001, device_caps=0x04200001
[ 853.095381] videodev: v4l2_release: video0: release
[ 853.095427] videodev: v4l2_open: video0: open (0)
[ 853.095446] video0: VIDIOC_QUERYCAP: driver=tegra-video, card=vi-output, imx219 9-0010, bus=platform:tegra-capture-vi:0, version=0x00050a68, capabilities=0x84200001, device_caps=0x04200001
[ 853.095486] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a0001, type=6, name=Camera Controls, min/max=0/0, step=0, default=0, flags=0x00000044, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.095538] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2003, type=2, name=Group Hold, min/max=0/1, step=1, default=0, flags=0x00000200, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.095580] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2008, type=5, name=Sensor Mode, min/max=0/7, step=1, default=0, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.095649] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2009, type=5, name=Gain, min/max=16/170, step=1, default=16, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.095691] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200a, type=5, name=Exposure, min/max=13/683709, step=1, default=2495, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.095759] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200b, type=5, name=Frame Rate, min/max=2000000/30000000, step=1, default=30000000, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.095827] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2032, type=258, name=Sensor configuration, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=22, nr_of_dims=1, dims=22,0,0,0
[ 853.095869] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2033, type=258, name=Sensor mode I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 853.095909] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2034, type=258, name=Sensor control I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 853.095973] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2064, type=9, name=Bypass Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.096013] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2065, type=9, name=Override Enable, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.096050] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2066, type=1, name=Height Align, min/max=1/16, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.096087] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2067, type=9, name=Size Align, min/max=0/2, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.096135] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2068, type=1, name=Write ISP format, min/max=1/1, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.096173] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2069, type=258, name=Sensor Signal Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=126, nr_of_dims=2, dims=30,18,0,0
[ 853.096212] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206a, type=258, name=Sensor Image Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 853.096251] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206b, type=258, name=Sensor Control Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=252, nr_of_dims=2, dims=30,36,0,0
[ 853.096316] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206c, type=258, name=Sensor DV Timings, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 853.096387] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206d, type=2, name=Low Latency Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.096425] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206e, type=1, name=Preferred Stride, min/max=0/65535, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.096463] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2082, type=1, name=Sensor Modes, min/max=0/30, step=1, default=30, flags=0x00000004, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 853.096497] video0: VIDIOC_QUERY_EXT_CTRL: error -22: id=0xc09a2082, type=0, name=, min/max=0/0, step=0, default=0, flags=0x00000000, elem_size=0, elems=0, nr_of_dims=0, dims=0,0,0,0
[ 853.096538] videodev: v4l2_release: video0: release
[ 853.096589] videodev: v4l2_open: video0: open (0)
[ 853.096612] video0: VIDIOC_ENUM_FMT: index=0, type=vid-cap, flags=0x0, pixelformat=RG10, mbus_code=0x0000, description=‘10-bit Bayer RGRG/GBGB’
[ 853.096648] video0: VIDIOC_ENUM_FMT: error -22: index=1, type=vid-cap, flags=0x0, pixelformat=
[ 853.096683] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vid-out, flags=0x0, pixelformat=
[ 853.096716] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vid-overlay, flags=0x0, pixelformat=
[ 853.096748] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vbi-cap, flags=0x0, pixelformat=
[ 853.096788] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vbi-out, flags=0x0, pixelformat=
[ 853.096845] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=sliced-vbi-cap, flags=0x0, pixelformat=
[ 853.096878] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=sliced-vbi-out, flags=0x0, pixelformat=
[ 853.096911] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vid-out-overlay, flags=0x0, pixelformat=
[ 853.096969] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vid-cap-mplane, flags=0x0, pixelformat=
[ 853.097002] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vid-out-mplane, flags=0x0, pixelformat=
[ 853.097111] video0: VIDIOC_ENUM_FRAMESIZES: index=0, pixelformat=RG10, type=1, wxh=3280x2464
[ 853.097192] video0: VIDIOC_ENUM_FRAMESIZES: index=1, pixelformat=RG10, type=1, wxh=3280x1848
[ 853.097265] video0: VIDIOC_ENUM_FRAMESIZES: index=2, pixelformat=RG10, type=1, wxh=1920x1080
[ 853.097336] video0: VIDIOC_ENUM_FRAMESIZES: index=3, pixelformat=RG10, type=1, wxh=1640x1232
[ 853.097430] video0: VIDIOC_ENUM_FRAMESIZES: index=4, pixelformat=RG10, type=1, wxh=1280x720
[ 853.097504] video0: VIDIOC_ENUM_FRAMESIZES: error -22: index=5, pixelformat=RG10, type=0
[ 853.097543] video0: VIDIOC_G_FMT: type=vid-cap, width=1640, height=1232, pixelformat=RG10, field=none, bytesperline=3280, sizeimage=4040960, colorspace=8, flags=0x0, ycbcr_enc=0, quantization=0, xfer_func=0
[ 853.097600] video0: VIDIOC_ENUMINPUT: index=0, name=Camera 0, type=2, audioset=0x0, tuner=0, std=0x00000000, status=0x0, capabilities=0x0
[ 853.097655] video0: VIDIOC_ENUMINPUT: error -22: index=1, name=, type=0, audioset=0x0, tuner=0, std=0x00000000, status=0x0, capabilities=0x0
[ 853.097756] videodev: v4l2_release: video0: release
[ 853.176385] videodev: v4l2_open: video0: open (0)
[ 853.176419] video0: VIDIOC_QUERYCAP: driver=tegra-video, card=vi-output, imx219 9-0010, bus=platform:tegra-capture-vi:0, version=0x00050a68, capabilities=0x84200001, device_caps=0x04200001
[ 853.176467] videodev: v4l2_release: video0: release
[ 853.318499] NVRM: No NVIDIA GPU found.
[ 853.510767] videodev: v4l2_open: video0: open (0)
[ 853.510831] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=1, error_idx=0, request_fd=0, id/val=0x9a2008/0x3
[ 853.510889] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=1, error_idx=0, request_fd=0, id/val=0x9a2064/0x1
[ 853.510932] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=1, error_idx=0, request_fd=0, id/val=0x9a2065/0x1
[ 853.511128] video0: VIDIOC_S_FMT: type=vid-cap, width=1640, height=1232, pixelformat=RG10, field=none, bytesperline=3280, sizeimage=4040960, colorspace=8, flags=0x0, ycbcr_enc=0, quantization=0, xfer_func=0
[ 853.511196] video0: VIDIOC_REQBUFS: count=2, type=vid-cap, memory=userptr
[ 853.511320] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a200b/0x1c9c380, id/val=0x9a2009/0x10, id/val=0x9a2003/0x0
[ 853.517337] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=3, error_idx=2, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a200a/0x8232, id/val=0x9a2003/0x0
[ 853.557194] video0: VIDIOC_STREAMON: type=vid-cap
[ 853.822836] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=3, error_idx=2, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x13, id/val=0x9a2003/0x0
[ 853.856259] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=3, error_idx=2, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x16, id/val=0x9a2003/0x0
[ 853.889896] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=3, error_idx=2, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x19, id/val=0x9a2003/0x0
[ 853.926682] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=3, error_idx=2, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x1b, id/val=0x9a2003/0x0
[ 854.022842] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=3, error_idx=2, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x1c, id/val=0x9a2003/0x0
[ 854.057053] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=3, error_idx=2, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x1e, id/val=0x9a2003/0x0
[ 854.092363] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x1f, id/val=0x9a200a/0x8231, id/val=0x9a2003/0x0
[ 854.123290] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x21, id/val=0x9a200a/0x8232, id/val=0x9a2003/0x0
[ 854.158676] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x23, id/val=0x9a200a/0x8231, id/val=0x9a2003/0x0
[ 854.190860] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x24, id/val=0x9a200a/0x8232, id/val=0x9a2003/0x0
[ 854.227541] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x25, id/val=0x9a200a/0x8231, id/val=0x9a2003/0x0
[ 854.256944] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x26, id/val=0x9a200a/0x8232, id/val=0x9a2003/0x0
[ 854.322821] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=3, error_idx=2, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x27, id/val=0x9a2003/0x0
[ 854.356435] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x29, id/val=0x9a200a/0x8231, id/val=0x9a2003/0x0
[ 854.392045] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x2a, id/val=0x9a200a/0x8232, id/val=0x9a2003/0x0
[ 854.423314] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x2b, id/val=0x9a200a/0x8231, id/val=0x9a2003/0x0
[ 854.490002] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x2c, id/val=0x9a200a/0x8232, id/val=0x9a2003/0x0
[ 854.522722] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=3, error_idx=2, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x2d, id/val=0x9a2003/0x0
[ 854.556815] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=3, error_idx=2, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x2e, id/val=0x9a2003/0x0
[ 855.289759] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x33, id/val=0x9a200a/0x752f, id/val=0x9a2003/0x0
[ 887.119219] video0: VIDIOC_STREAMOFF: type=vid-cap
[ 887.206939] video0: VIDIOC_REQBUFS: count=0, type=vid-cap, memory=userptr
[ 887.206992] videodev: v4l2_release: video0: release
[ 1002.928873] videodev: v4l2_open: video0: open (0)
[ 1002.928908] video0: VIDIOC_QUERYCAP: driver=tegra-video, card=vi-output, imx219 9-0010, bus=platform:tegra-capture-vi:0, version=0x00050a68, capabilities=0x84200001, device_caps=0x04200001
[ 1002.929005] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a0001, type=6, name=Camera Controls, min/max=0/0, step=0, default=0, flags=0x00000044, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929047] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2003, type=2, name=Group Hold, min/max=0/1, step=1, default=0, flags=0x00000200, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929105] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2008, type=5, name=Sensor Mode, min/max=0/7, step=1, default=0, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929141] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2009, type=5, name=Gain, min/max=16/170, step=1, default=16, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929176] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200a, type=5, name=Exposure, min/max=13/683709, step=1, default=2495, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929212] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200b, type=5, name=Frame Rate, min/max=2000000/30000000, step=1, default=30000000, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929246] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2032, type=258, name=Sensor configuration, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=22, nr_of_dims=1, dims=22,0,0,0
[ 1002.929281] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2033, type=258, name=Sensor mode I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 1002.929316] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2034, type=258, name=Sensor control I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 1002.929350] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2064, type=9, name=Bypass Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929383] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2065, type=9, name=Override Enable, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929416] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2066, type=1, name=Height Align, min/max=1/16, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929450] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2067, type=9, name=Size Align, min/max=0/2, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929509] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2068, type=1, name=Write ISP format, min/max=1/1, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929543] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2069, type=258, name=Sensor Signal Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=126, nr_of_dims=2, dims=30,18,0,0
[ 1002.929602] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206a, type=258, name=Sensor Image Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 1002.929636] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206b, type=258, name=Sensor Control Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=252, nr_of_dims=2, dims=30,36,0,0
[ 1002.929757] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206c, type=258, name=Sensor DV Timings, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 1002.929876] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206d, type=2, name=Low Latency Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929923] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206e, type=1, name=Preferred Stride, min/max=0/65535, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.929994] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2082, type=1, name=Sensor Modes, min/max=0/30, step=1, default=30, flags=0x00000004, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.930028] video0: VIDIOC_QUERY_EXT_CTRL: error -22: id=0xc09a2082, type=0, name=, min/max=0/0, step=0, default=0, flags=0x00000000, elem_size=0, elems=0, nr_of_dims=0, dims=0,0,0,0
[ 1002.930075] videodev: v4l2_release: video0: release
[ 1002.934775] videodev: v4l2_open: video0: open (0)
[ 1002.934799] video0: VIDIOC_QUERYCAP: driver=tegra-video, card=vi-output, imx219 9-0010, bus=platform:tegra-capture-vi:0, version=0x00050a68, capabilities=0x84200001, device_caps=0x04200001
[ 1002.934842] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a0001, type=6, name=Camera Controls, min/max=0/0, step=0, default=0, flags=0x00000044, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.934877] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2003, type=2, name=Group Hold, min/max=0/1, step=1, default=0, flags=0x00000200, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.934930] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2008, type=5, name=Sensor Mode, min/max=0/7, step=1, default=0, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.934993] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2009, type=5, name=Gain, min/max=16/170, step=1, default=16, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.935028] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200a, type=5, name=Exposure, min/max=13/683709, step=1, default=2495, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.935083] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200b, type=5, name=Frame Rate, min/max=2000000/30000000, step=1, default=30000000, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.935118] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2032, type=258, name=Sensor configuration, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=22, nr_of_dims=1, dims=22,0,0,0
[ 1002.935181] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2033, type=258, name=Sensor mode I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 1002.935217] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2034, type=258, name=Sensor control I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 1002.935250] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2064, type=9, name=Bypass Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.935284] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2065, type=9, name=Override Enable, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.935319] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2066, type=1, name=Height Align, min/max=1/16, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.935358] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2067, type=9, name=Size Align, min/max=0/2, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.935392] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2068, type=1, name=Write ISP format, min/max=1/1, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.935425] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2069, type=258, name=Sensor Signal Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=126, nr_of_dims=2, dims=30,18,0,0
[ 1002.935459] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206a, type=258, name=Sensor Image Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 1002.935493] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206b, type=258, name=Sensor Control Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=252, nr_of_dims=2, dims=30,36,0,0
[ 1002.935527] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206c, type=258, name=Sensor DV Timings, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 1002.935561] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206d, type=2, name=Low Latency Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.935594] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206e, type=1, name=Preferred Stride, min/max=0/65535, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.935652] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2082, type=1, name=Sensor Modes, min/max=0/30, step=1, default=30, flags=0x00000004, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.935685] video0: VIDIOC_QUERY_EXT_CTRL: error -22: id=0xc09a2082, type=0, name=, min/max=0/0, step=0, default=0, flags=0x00000000, elem_size=0, elems=0, nr_of_dims=0, dims=0,0,0,0
[ 1002.935759] videodev: v4l2_release: video0: release
[ 1002.983465] videodev: v4l2_open: video0: open (0)
[ 1002.983493] video0: VIDIOC_QUERYCAP: driver=tegra-video, card=vi-output, imx219 9-0010, bus=platform:tegra-capture-vi:0, version=0x00050a68, capabilities=0x84200001, device_caps=0x04200001
[ 1002.983546] videodev: v4l2_release: video0: release
[ 1002.983593] videodev: v4l2_open: video0: open (0)
[ 1002.983611] video0: VIDIOC_QUERYCAP: driver=tegra-video, card=vi-output, imx219 9-0010, bus=platform:tegra-capture-vi:0, version=0x00050a68, capabilities=0x84200001, device_caps=0x04200001
[ 1002.983686] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a0001, type=6, name=Camera Controls, min/max=0/0, step=0, default=0, flags=0x00000044, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.983741] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2003, type=2, name=Group Hold, min/max=0/1, step=1, default=0, flags=0x00000200, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.983809] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2008, type=5, name=Sensor Mode, min/max=0/7, step=1, default=0, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.983846] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2009, type=5, name=Gain, min/max=16/170, step=1, default=16, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.983920] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200a, type=5, name=Exposure, min/max=13/683709, step=1, default=2495, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.983985] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a200b, type=5, name=Frame Rate, min/max=2000000/30000000, step=1, default=30000000, flags=0x00000020, elem_size=8, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.984023] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2032, type=258, name=Sensor configuration, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=22, nr_of_dims=1, dims=22,0,0,0
[ 1002.984059] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2033, type=258, name=Sensor mode I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 1002.984094] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2034, type=258, name=Sensor control I2C packet, min/max=0/4294967295, step=1, default=0, flags=0x00000184, elem_size=4, elems=1026, nr_of_dims=1, dims=1026,0,0,0
[ 1002.984129] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2064, type=9, name=Bypass Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.984163] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2065, type=9, name=Override Enable, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.984197] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2066, type=1, name=Height Align, min/max=1/16, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.984231] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2067, type=9, name=Size Align, min/max=0/2, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.984264] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2068, type=1, name=Write ISP format, min/max=1/1, step=1, default=1, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.984298] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2069, type=258, name=Sensor Signal Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=126, nr_of_dims=2, dims=30,18,0,0
[ 1002.984332] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206a, type=258, name=Sensor Image Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 1002.984367] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206b, type=258, name=Sensor Control Properties, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=252, nr_of_dims=2, dims=30,36,0,0
[ 1002.984426] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206c, type=258, name=Sensor DV Timings, min/max=0/4294967295, step=1, default=0, flags=0x00000104, elem_size=4, elems=112, nr_of_dims=2, dims=30,16,0,0
[ 1002.984461] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206d, type=2, name=Low Latency Mode, min/max=0/1, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.984520] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a206e, type=1, name=Preferred Stride, min/max=0/65535, step=1, default=0, flags=0x00000000, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.984555] video0: VIDIOC_QUERY_EXT_CTRL: id=0x9a2082, type=1, name=Sensor Modes, min/max=0/30, step=1, default=30, flags=0x00000004, elem_size=4, elems=1, nr_of_dims=0, dims=0,0,0,0
[ 1002.984614] video0: VIDIOC_QUERY_EXT_CTRL: error -22: id=0xc09a2082, type=0, name=, min/max=0/0, step=0, default=0, flags=0x00000000, elem_size=0, elems=0, nr_of_dims=0, dims=0,0,0,0
[ 1002.984656] videodev: v4l2_release: video0: release
[ 1002.984707] videodev: v4l2_open: video0: open (0)
[ 1002.984728] video0: VIDIOC_ENUM_FMT: index=0, type=vid-cap, flags=0x0, pixelformat=RG10, mbus_code=0x0000, description=‘10-bit Bayer RGRG/GBGB’
[ 1002.984762] video0: VIDIOC_ENUM_FMT: error -22: index=1, type=vid-cap, flags=0x0, pixelformat=
[ 1002.984807] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vid-out, flags=0x0, pixelformat=
[ 1002.984840] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vid-overlay, flags=0x0, pixelformat=
[ 1002.984873] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vbi-cap, flags=0x0, pixelformat=
[ 1002.984906] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vbi-out, flags=0x0, pixelformat=
[ 1002.984938] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=sliced-vbi-cap, flags=0x0, pixelformat=
[ 1002.984971] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=sliced-vbi-out, flags=0x0, pixelformat=
[ 1002.985003] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vid-out-overlay, flags=0x0, pixelformat=
[ 1002.985035] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vid-cap-mplane, flags=0x0, pixelformat=
[ 1002.985068] video0: VIDIOC_ENUM_FMT: error -22: index=0, type=vid-out-mplane, flags=0x0, pixelformat=
[ 1002.985168] video0: VIDIOC_ENUM_FRAMESIZES: index=0, pixelformat=RG10, type=1, wxh=3280x2464
[ 1002.985257] video0: VIDIOC_ENUM_FRAMESIZES: index=1, pixelformat=RG10, type=1, wxh=3280x1848
[ 1002.985340] video0: VIDIOC_ENUM_FRAMESIZES: index=2, pixelformat=RG10, type=1, wxh=1920x1080
[ 1002.985401] video0: VIDIOC_ENUM_FRAMESIZES: index=3, pixelformat=RG10, type=1, wxh=1640x1232
[ 1002.985463] video0: VIDIOC_ENUM_FRAMESIZES: index=4, pixelformat=RG10, type=1, wxh=1280x720
[ 1002.985514] video0: VIDIOC_ENUM_FRAMESIZES: error -22: index=5, pixelformat=RG10, type=0
[ 1002.985553] video0: VIDIOC_G_FMT: type=vid-cap, width=1640, height=1232, pixelformat=RG10, field=none, bytesperline=3280, sizeimage=4040960, colorspace=8, flags=0x0, ycbcr_enc=0, quantization=0, xfer_func=0
[ 1002.985611] video0: VIDIOC_ENUMINPUT: index=0, name=Camera 0, type=2, audioset=0x0, tuner=0, std=0x00000000, status=0x0, capabilities=0x0
[ 1002.985642] video0: VIDIOC_ENUMINPUT: error -22: index=1, name=, type=0, audioset=0x0, tuner=0, std=0x00000000, status=0x0, capabilities=0x0
[ 1002.985750] videodev: v4l2_release: video0: release
[ 1003.065293] videodev: v4l2_open: video0: open (0)
[ 1003.065324] video0: VIDIOC_QUERYCAP: driver=tegra-video, card=vi-output, imx219 9-0010, bus=platform:tegra-capture-vi:0, version=0x00050a68, capabilities=0x84200001, device_caps=0x04200001
[ 1003.065381] videodev: v4l2_release: video0: release
[ 1003.217156] NVRM: No NVIDIA GPU found.
[ 1003.414808] videodev: v4l2_open: video0: open (0)
[ 1003.414876] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=1, error_idx=0, request_fd=0, id/val=0x9a2008/0x6
[ 1003.414934] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=1, error_idx=0, request_fd=0, id/val=0x9a2064/0x1
[ 1003.414979] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=1, error_idx=0, request_fd=0, id/val=0x9a2065/0x1
[ 1003.415188] video0: VIDIOC_S_FMT: type=vid-cap, width=3280, height=2464, pixelformat=RG10, field=none, bytesperline=6560, sizeimage=16163840, colorspace=8, flags=0x0, ycbcr_enc=0, quantization=0, xfer_func=0
[ 1003.415253] video0: VIDIOC_REQBUFS: count=2, type=vid-cap, memory=userptr
[ 1003.415403] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a200b/0x1406f40, id/val=0x9a2009/0x10, id/val=0x9a2003/0x0
[ 1003.418044] video0: VIDIOC_S_EXT_CTRLS: which=0x9a0000, count=4, error_idx=3, request_fd=0, id/val=0x9a2003/0x1, id/val=0x9a2009/0x6a, id/val=0x9a200a/0x1387, id/val=0x9a2003/0x0
[ 1003.461062] video0: VIDIOC_STREAMON: type=vid-cap
[ 1249.330172] videodev: v4l2_release: video0: release
