I already seen that 4k60 is not possible, but what about 1440p120? Is that possible? Or its not due to the speed of DP port?
Hi @cylin577,
If you are using Jetson Orin Nano, 2560x1440@120Hz is not supported/guaranteed.
Although the DisplayPort link bandwidth may look sufficient on paper, the supported display modes are limited by the Jetson platform/display controller clock, not only by the DP port speed.
The Jetson Linux display feature table lists DP 4K@60 as not supported for Orin Nano, and higher DP modes such as 4K@120/8K@30 are supported only on AGX Orin.
Official documentation:
Hope this helps!
