My task is simple: display a 16-bits-per-channel image through OpenGl, and apply some basic imageprocessing stuff. I use textures and PBO. Everything looks fine, but the texture binding fails. I would appriciate any kind of help!
Here is the relevant part of the source:
cutilSafeCall( CUDA_FreeArray() );
cutilSafeCall( CUDA_MallocArray(&imgbuffer, width, height, memNeeded) );
//imagebuffer is the actual data of the imagecontent RGBA each channel is 16bit
//memNeeded is the exact size of the image data
//the imagedata is ok, i've checked
//Creating GL texture...
glEnable(GL_TEXTURE_2D);
glGenTextures(1, &gl_Tex);
glBindTexture(GL_TEXTURE_2D, gl_Tex);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA16, w, h, 0, GL_RGBA, GL_UNSIGNED_SHORT, imgbuffer);
//Texture created...
//Creating PBO...
glGenBuffers(1, &gl_PBO);
glBindBuffer(GL_PIXEL_UNPACK_BUFFER_ARB, gl_PBO);
glBufferData(GL_PIXEL_UNPACK_BUFFER_ARB, w * h * 8, imgbuffer, GL_STREAM_COPY);
CUT_CHECK_ERROR_GL();
//PBO created...
///this seems ok
cutStartTimer(hTimer);
TColor *d_dst = NULL;
cutilSafeCall( cudaGLMapBufferObject((void**)&d_dst, gl_PBO) );
CUT_CHECK_ERROR("Bind hiba elott");
cutilSafeCall( CUDA_Bind2TextureArray()); // <--------- this is the line where the cuda exception is CudaErrorInvalidTexture. The program exits with -1 returning value.....
CUT_CHECK_ERROR("Bind hiba");
cuda_Copy(d_dst, w, h);
cutilSafeCall( CUDA_UnbindTexture() );
cutilSafeCall( cudaGLUnmapBufferObject(gl_PBO) );
glTexSubImage2D( GL_TEXTURE_2D, 0, 0, 0, w, h, GL_RGBA, GL_UNSIGNED_SHORT, BUFFER_DATA(0) );
glBegin(GL_TRIANGLES);
glTexCoord2f(0, 1); glVertex2f(-1, -1);
glTexCoord2f(2, 1); glVertex2f(3, -1);
glTexCoord2f(0, -1); glVertex2f(-1, 3);
glEnd();
glFinish();
glutSwapBuffers();
cutStopTimer(hTimer);
FPS();
glutPostRedisplay();
The relevant part of the .cu file is here:
//try to create a struct with 4*16bit data.....
texture<ushort4, 2, cudaReadModeNormalizedFloat> texImage;
cudaChannelFormatDesc shortIntTex = cudaCreateChannelDesc(16,16,16,16,cudaChannelFormatKindUnsigned);
//CUDA array descriptor
cudaArray *a_Src;
//#include "FrameDecoder_copy_kernel.cu"
__global__ void Copy(
TColor *dst,
int imageW,
int imageH
//do some imageprocessing, but this part of the code is never reached....
extern "C" void
cuda_Copy(TColor *d_dst, int imageW, int imageH)
dim3 threads(BLOCKDIM_X, BLOCKDIM_Y);
dim3 grid(iDivUp(imageW, BLOCKDIM_X), iDivUp(imageH, BLOCKDIM_Y));
Copy<<<grid, threads>>>(d_dst, imageW, imageH);
extern "C"
cudaError_t CUDA_Bind2TextureArray()
///this function fails, the return value is CudaErrorInvalidTexture
return cudaBindTextureToArray(texImage, a_Src, shortIntTex);
extern "C"
cudaError_t CUDA_UnbindTexture()
return cudaUnbindTexture(texImage);
extern "C"
cudaError_t CUDA_MallocArray( unsigned char **h_Source, int imageW, int imageH, int memNeeded)
cudaError_t error;
error = cudaMallocArray(&a_Src, &shortIntTex, imageW, imageH);
error = cudaMemcpyToArray(a_Src, 0, 0,
*h_Source, memNeeded ,
cudaMemcpyHostToDevice
return error;
The compiler throws this line after the binding:
“Microsoft C++ exception: cudaError at memory location 0x0012ea3c…”
I can provide more source if requested.
Thanks a lot,
Peter Bako
