17.1 open mpi issue
Hi all,
After installing 17.1, I am having trouble with openmpi:
$ /opt/pgi/linux86-64/2017/mpi/openmpi-1.10.2/bin/mpif90
/opt/pgi/linux86-64/2017/mpi/openmpi-1.10.2/bin/.bin/mpif90: error while loading shared libraries: libopen-pal.so.13: cannot open shared object file: No such file or directory
$ locate libopen-pal.so.13
/opt/pgi/linux86-64/2016/mpi/openmpi-1.10.2/lib/libopen-pal.so.13
/opt/pgi/linux86-64/2016/mpi/openmpi-1.10.2/lib/libopen-pal.so.13.0.2
/opt/pgi/linux86-64/2017/mpi/openmpi-1.10.2/lib/libopen-pal.so.13
/opt/pgi/linux86-64/2017/mpi/openmpi-1.10.2/lib/libopen-pal.so.13.0.2
Any suggestions? This may be related to a previous post ny “TheMatt” but I was not able to find a solution based on that.
Thanks, Jan
First of all, you should set up your environment
export PGI=/opt/pgi
export PATH=$PGI/linux86-64/17.1/bin:$PGI/linux86-64/2017/mpi/openmpi/bin
and then mpif90 should work.
But the $PGI/linux86-64/2017/mpi/openmpi-1.10.2/bin/.bin/mpif90
is not what what you should be running.
I don’t think you need to do the following if you use the right mpif90 in your path
It looks like someone did not build the /.bin version of mpif90 correctly.
But we can get that working.
export LD_LIBRARY_PATH=/opt/pgi/linux86-64/17.1/lib:/opt/pgi/linux86-64/2017/mpi/openmpi-1.10.2/lib:$LD_LIBRARY_PATH
If you look at
ldd /opt/pgi/linux86-64/2017/mpi/openmpi-1.10.2/bin/mpif90
before and after you set LD_LIBRARY_PATH, you will see why it works now.
after discussing this with engineering, how
:/opt/pgi/linux86-64/2017/mpi/openmpi/bin/mpif90 reconciles its paths
makes the "ldd …/.bin/mpif90 " output irrelevant.
dave
Thanks, setting
LD_LIBRARY_PATH
did the trick. Otherwise my environment was fully set up. This must be an omission in the PGI installation files? Previously, I did have not have to set the LD_LIBRARY_PATH AFAICR.
-Jan
If you look at the outputs of
pgfortran -dryrun x.o -Mmpi=mpi
and
mpif90 -dryrun x.o
you will see the mpif90 output has this extra fragment
-rpath /opt/pgi/linux86-64/2016/mpi/openmpi-1.10.2/lib
which points the executable to an area for finding libraries.
Try adding
-Wl,-rpath,/opt/pgi/linux86-64/2016/mpi/openmpi-1.10.2/lib
to your compile line and see what happens.
dave
