Is LLVM code generation not supported by the Community Edition or did I miss something during the install or did i need to preinstall something?
Al
Al
Community edition is the same as the professional edition feature-wise. You should just need to specify -Mllvm to use its code generator.
layzarc@AlsMacPro6:~/pgi$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.5 LTS
Release: 16.04
Codename: xenial
layzarc@AlsMacPro6:~/pgi$ pgf95 -V -Mllvm hello.f90
pgf95-Error-LLVM code generator is not available in this installation
layzarc@AlsMacPro6:~/pgi$ pgf95 -V hello.f90
pgf95 18.10-0 64-bit target on x86-64 Linux -tp nehalem
PGI Compilers and Tools
This looks like a bug with the RC file, I’ve filed TPR#26484 to address it. In the meantime use pgfortran instead of pgf95. There shouldn’t be any semantic difference between pgf90/pgf95/pgfortran.
Thanks switching from pgf95 to pgfortran did the trick. After recompiling my engineering application, the execution time for one test case dropped from 49 to 31 seconds.
Al
