hello tianyi2,
please try below steps to disable TCU.
- modify mb1-bct, tegra194-mb1-bct-misc-l4t.cfg to disable combined-uart. it’s 0x2 for UART-C
enable_combined_uart = 0;
spe_uart_instance = 0x2;
- modify kernel device tree, to load uart8250 driver and update the bootargs.
serial@c280000 {
compatible = "nvidia,tegra20-uart"; // To load uart8250 driver
status = "okay";
chosen {
bootargs = "console=ttyS2,115200 earlycon=uart8250,mmio32,0x0c280000";
- you may disassembler the bpmp-dtb, changes the content as following,
serial {
- port = <3>;
+ port = <2>;
has_input;
- combined-uart {
- enabled;
- update flash configure file, p2972-0000.conf.common. change console=ttyS2 for UART-C.
CMDLINE_ADD="console=ttyS2,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4";
