1x Spark new workhorse: DFlash2 + SGLang is fairly fast for Qwen3.8 27B NVFP4
I am mostly using the official SGLang cookbook here via docker setup. With only a few settings tweaked. For example, I set max concurrency to 8, enabled cache report and performance metrics. On a single DGX Spark I am getting ~104GB unified RAM usage. Works way better than Qwen3.5 122B A10B which was my previous workhorse. Very happy with the setup
You will also want to add “–sleep-on-idle” to your docker run command. Otherwise it will constantly pin one of the CPU core to 100% which is annoying.
Hi, Can you share recipe/script/command?
I used the official SGLang cook book via the docker option. That is really all you need.
I’ve created a docker compose config in case it helps : Qwen3.8-27B benchmarking on one DGX Spark: DFlash2 beat vLLM+MTP, and greedy beat the "thinking" sampler
