2.6.31-rt10 a mutex by another name
Linux 2.6.31-rt10 (final) is released. Reportedly this does not work with the Nvidia module because of missing #define of init_MUTEX(mutex) used in usr/src/nv/nv-linux.h line 739:
[codebox]#if defined(CONFIG_PREEMPT_RT)
// #define NV_INIT_MUTEX(mutex) init_MUTEX(mutex)
#define NV_INIT_MUTEX(mutex) sema_init(mutex,1) // possible fix ??
#else
#if !defined(__SEMAPHORE_INITIALIZER) && defined(__COMPAT_SEMAPHORE_INITIALIZER)
#define __SEMAPHORE_INITIALIZER __COMPAT_SEMAPHORE_INITIALIZER
#endif[/codebox]
Anybody looking into this?
http://www.nvnews.net/vbulletin/showthread.php?t=138651
EDIT: Apparently Jan Engelhardt has:
http://www.spinics.net/lists/linux-rt-users/msg04834.html
OK. that was fast :-D
User ibuclaw at nvnews took the above mentioned work for a spin, and came up with a patch for nvidia-190-32:
http://www.nvnews.net/vbulletin/showpost.p…mp;postcount=13
I am still at nvidia driver 190.18 but will try this one out later today with Linux kernel 2.6.29-rt before attempting to upgrade to 2.6.31-rt
BTW: When did Nvidia start including CONFIG_PREEMPT_RT in the driver? It really changes the whole paradigm for what is possible to do with CUDA. For instance, I have an audio application that runs 0.5 ms every 1.0 ms. With preempt I can then also run several instances of glxgears (to produce a test load) as well as a fullscreen video framegrabber. Hey, I can even run an instance of FlightGear (although with this card not in fullscreen…)
