Installed and manage to run view which was working fine until it crashes, then on whenever I try to open any (Even the demo samples like astronaut usd file) USD files it will hang and crash, sometimes stalling the whole computer.
Hi @DavidDPD! I took a look at your logs and I will need to have a developer take a look. While I ask for their help, could you let me know what your operating system you are using and your GPU / GPU Driver? They may ask me to get more information from you, but this will help point them in the right direction! Thanks for letting us know!
I read through the provided log file. I found 3 warnings related to connecting to Nucleus and a single error regarding a remote server not supporting WebSockets.
Are you able to use other Omniverse apps? My initial impression is that this is a local networking issue or a possible Nucleus problem. I have not seen a similar problem locally.
I am able to use Omniverse Create 2022.1.1 just fine, similarly everything running locally on local nucleus. I would guess the error on remote server is trying to access the astronaut demo files on aws.
