2022 MAX can't not use with omniverse,not connector
2022 MAX can’t not use with omniverse,not connector 2022 MAX can’t not use with omniverse,not connector
2022 MAX can’t not use with omniverse,not connector please help…
I can not use it too in 2020max
Hi @seanliangbally & @1402050243! The development team is working on support for Maya 2022. I don’t have an ETA, but you can check our Public Roadmap & our Announcement Forums for any updates.
Max 2020 Should work, Max 2022 is in progress, no date yet.
Currently, you cant have other USD plugins loaded at the same time as Omniverse USD plugins. You would need to disable the other USD plugin.
Future versions will allow them to work with each other.
I try to use it again with tour way,but this is same question,
3dsMax 2022 support will be in the next release of the Connector.
If you are having issue with 3dsMax 2020 or othe version of the connector, can you let us know if there any thing listed in the script editor or can you send the log file please.
3dsMax 2022 support is now released with the newest connector available on the Omniverse launcher.
