2D Array Filter (very simple) Error due to my C code...
Hello Forum,
I’m a raw beginner in CUDA programing. When I run the attached program the following error-messages occour:
When I change X and Y to:
the error messages change to:
Does anyone please can help me - or give me a hint to solve this error? Maybe it’s quite simple… but I can’t figure it out External Media
Enclosed I attached the source code.
Thank you very much for your help and your time.
Best regards,
Sandra
#include <cuda.h>
#include <stdio.h>
#include <cutil_inline.h>
// Kernel that executes on the CUDA device
__global__ void filter(int *grey[X][Y], int *color[X][Y])
	int x = blockIdx.x * blockDim.x + threadIdx.x;
	int y = blockIdx.y * blockDim.y + threadIdx.y;
	if (x > 1 && y > 1 && x < X-1 && y < Y-1)
		color[x][y] = grey[x-1][y-1] +
			grey[x][y-1]   +
			grey[x+1][y-1] +
			grey[x-1][y]   +
			grey[x+1][y]   +
			grey[x-1][y+1] +
			grey[x][y+1]   +
			grey[x+1][y+1];
int main(void)
	int X = 10;
	int Y = 10;
	int elemente = X * Y;
	int size = elemente * sizeof(int);
	int** ENbayered_h = new int[X][Y];		  // Allocate array on host
	int** DEbayered_h = new int[X][Y];		  // Allocate array on host
	int** ENbayered_d;
	int** DEbayered_d;
	cudaMalloc((void **) &ENbayered_d, size);   // Allocate array on device
	cudaMalloc((void **) &DEbayered_d, size);   // Allocate array on device
	// blocksize
	int block_size = 256;
	// number of blocks
	int n_blocks = elemente/block_size + (size%block_size == 0 ? 0:1);
	// Initialize host array
	for (int i=0; i<X; i++)
		for (int j=0; j<Y; j++)
			ENbayered_h[i][j] = 1; // enbayered grey values
	cudaMemcpy(ENbayered_d, ENbayered_h, size, cudaMemcpyHostToDevice);
	filter <<< n_blocks, block_size >>> (ENbayered_d, DEbayered_d);
	cudaMemcpy(DEbayered_h, DEbayered_d, size, cudaMemcpyDeviceToHost);
	free(ENbayered_h);
	free(DEbayered_h);
	cudaFree(ENbayered_d);
	cudaFree(DEbayered_d);
That syntax is totally illegal. If you are passing pointers to pointers do it like this:
__global__ void filter(int **grey, int **color)
I should warn you that your host side memory allocation and copying to device memory are also doomed to fail as they are written as well. Consider using simple 1D arrays for you storage on both device and host, it will make life considerably less complex in the long run.
It seems you are declaring X and Y in the wrong scope. You could declare them as global variables or you could pass them along in your kernel invocation
ex: myKernel(grey, color, X,Y)
If X,Y are known at compile time however, you might as well declare them as constant integers as that might be beneficial performance wise.
#include <cuda.h>
#include <stdio.h>
constant int X = 10;
constant int Y = 10;
			grey[x][y-1]   +
			grey[x+1][y-1] +
