Hi, I’ve to copy an array of int from the host to device and tried to use the functions cudaMallocPitch and cudaMemcpy2D but all I obtained is a segmentation fault when I try to modify these data on the device…
This is the code that I wrote:
on the host:
int** vect=new int*[20];
for (int i=0; i<20; ++i) {
vect[i]=new int[30];
for (int j=0; j<30; ++j)
vect[i][j]=i*j;
int** d_vect;
size_t pitch=sizeof(int);
cudaMallocPitch((void**) &d_vect, &pitch, 30*sizeof(int), 20);
cudaMemcpy2D(d_vect, pitch, vect, pitch, 30*sizeof(int), 20, cudaMemcpyHostToDevice);
dim3 grid(30,20);
nothing<<< grid, 1 >>>(d_vect);
cudaMemcpy2D(vect, pitch, d_vect, pitch, 30*sizeof(int), 20, cudaMemcpyDeviceToHost);
__global__ void nothing(int** vect) {
vect[blockIdx.x][blockIdx.y]=-vect[blockIdx.x][blockIdx.y];
I’m sure there’re some error in this code, can you explain me where these are?
I’m not sure I understood well how to do… Many thanks and excuse me for the disturb but it’s my first code with cuda…
on the host:
vect[i][j]=i*j;
int** d_vect;
dim3 grid(30,20);
The error is in the level of indirection:
cudaMallocPitch() does allocate a “flat” array of pitchheigth bytes (use int instead of int**).
