Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
6.0.1
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: RTX 5060 OC 9 GB
- Driver Version: 595.84
2D Lidar not using nearRangeM parameter setting
Detailed Description
I am trying to simulate a robot which uses 2D RTX Lidars. The issue is that I am giving it 0.05 m for the nearRangeM parameter, which should tell the lidar to place its laser scan point on objects up to 5 cm away from it. However, when testing, I discovered that the minimum distance for the 2D RTX Lidars is 30 cm (0.3 m). Could anyone help me fix this? Thank you!
I have looked through the config files and everything looks correct in the JSON and USDA files, just like in Isaac Sim.
