2D Parallel Reduction
I was trying to wirte a Parallel Reduction for a 2D-Matrix based on cuda reduction sdk sample (Description can be found at http://www.nvidia.com/object/cuda_sample_data-parallel.html).
Parallel Reduction on a 1D Array works as expected, but 2D works only partially.
Here is the kernel:
#define A_loc(x,y)	A_loc[y * block_size + x]
__kernel void
ParallelReduction2D(__global float * res,	//result
		__global float * A,		//input Matrix
		__local float * A_loc)		//shared memory - for input array
	int group_id_x = get_group_id(0);			//group id - x - COL
	int group_id_y = get_group_id(1);			//group id - y - ROW
	int tx = get_local_id(0);				//local id - x
	int ty = get_local_id(1);				//local id - y
	int global_id_x = get_global_id(0);			//global id - x
	int global_id_y = get_global_id(1);			//global id - y
	int global_size_x = get_global_size(0);			//global size - x
	int block_size = get_local_size(0);			//work group size
	int num_groups_x = get_num_groups(0);			//nr of work groups - x
	//int block_size = get_local_size(0);			//work group size
	//copy from global to shared memory
	A_loc(tx,ty) = A[global_id_y * global_size_x + global_id_x];
	//sync
	barrier(CLK_LOCAL_MEM_FENCE);
	//parallel reduction -> sum up values
	if (block_size >= 512) { if(tx < 256){ A_loc(tx,ty) += A_loc(tx + 256,ty);  barrier(CLK_LOCAL_MEM_FENCE);} }
	if (block_size >= 256) { if(tx < 128){ A_loc(tx,ty) += A_loc(tx + 128,ty); barrier(CLK_LOCAL_MEM_FENCE);} }
	if (block_size >= 128) { if(tx < 64){ A_loc(tx,ty) += A_loc(tx + 64,ty);  barrier(CLK_LOCAL_MEM_FENCE);} }
	if (tx <= 32)
		if (block_size >= 64) { A_loc(tx,ty) += A_loc(tx + 32,ty); barrier(CLK_LOCAL_MEM_FENCE); }
		if (block_size >= 32) { A_loc(tx,ty) += A_loc(tx + 16,ty); barrier(CLK_LOCAL_MEM_FENCE); }
		if (block_size >= 16) { A_loc(tx,ty) += A_loc(tx + 8,ty); barrier(CLK_LOCAL_MEM_FENCE); }
		if (block_size >= 8) { A_loc(tx,ty) += A_loc(tx + 4,ty); barrier(CLK_LOCAL_MEM_FENCE); }
		if (block_size >= 4) { A_loc(tx,ty) += A_loc(tx + 2,ty); barrier(CLK_LOCAL_MEM_FENCE); }
		if (block_size >= 2) { A_loc(tx,ty) += A_loc(tx + 1,ty); barrier(CLK_LOCAL_MEM_FENCE); }
	//writing result to global memory in order to do final sum up
	if(tx == 0)
	 res[global_id_y * global_size_x + global_id_x] = A_loc(tx,ty);
In order to keep it simple for now I use the same size for res and A.
So if block_size is 16 and A is filled with 1, I’d expect some result matrix like:
16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 16 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
but what I get instead is:
8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
So the first row of each block is calculated correctly, but the rest is wrong.
What am i doing wrong in this case?
After some research I found out that the problem wasn’t the kernel code. The kenel code above is working as expected.
The reason for the wrong behavior is that I declared memory to small:
Instead of
err = clSetKernelArg(kernels[0], 2, sizeof(float) * BLOCK_SIZE * BLOCK_SIZE, 0);
I had
err = clSetKernelArg(kernels[0], 2, sizeof(float) * BLOCK_SIZE, 0);
Now it works fine.
