First off I’d like to state that the PhysX documentation is severely lacking any explanation on how to cook meshes, actually, it’s lacking in everything.
Ok so now my problem… I’ve tried alot of ways of filling the TriangleMeshDesc but IsValid is always false, looking into source it is like this due to the MaterialIndices not being filled (NULL) , so it seems it’s a required field to fill, But as I said… Due to lack of any documentation, What am I supposed to put in there?
In the case that it’s not required, which seems more likely when looking at PxToolkit and other rare cases I managed to find mesh cooking code on google, I can’t figure out why PxCooking->CookTriangleMesh() always returns false as I can’t look into the source to see what checks it does.
I use DirectX 9.0 and DirectX meshes (.x file)
Here’s my code:
bool PhysXEngine::BakeMesh(LPD3DXMESH mesh)
PxTriangleMeshDesc* description=new PxTriangleMeshDesc();
description->setToDefault();
description->points.count= mesh->GetNumVertices();
description->triangles.count=mesh->GetNumFaces()*3;
PxVec3* vertices = new PxVec3[mesh->GetNumVertices()];
PxU32* indices = new PxU32[mesh->GetNumFaces()*3];
BYTE* vPtr = NULL;
DWORD numVerts=mesh->GetNumVertices();
DWORD fvf=mesh->GetFVF();
DWORD vertSize=D3DXGetFVFVertexSize(fvf);
mesh->LockVertexBuffer(0,(LPVOID*)&vPtr);
for (DWORD i=0;i<numVerts;i++)
D3DXVECTOR3 *ptr=(D3DXVECTOR3 *) vPtr;
vertices[i] =PxVec3(ptr->x,ptr->y,ptr->z);
vPtr+=vertSize;
mesh->UnlockVertexBuffer();
description->points.count = mesh->GetNumVertices();
description->points.stride = sizeof(PxVec3);
description->points.data = vertices;
LPDIRECT3DINDEXBUFFER9 pIndBuf;
mesh->GetIndexBuffer(&pIndBuf);
void* pInd = NULL;
DWORD numFaces=mesh->GetNumFaces();
pIndBuf->Lock(0,numFaces*3*sizeof(WORD),(void**) &pInd,D3DLOCK_DISCARD);
DWORD* iptr=(DWORD*) pInd;
for (int i=0;i<numFaces;i++)
for (int j=0;j<3;j++)
indices[i] =iptr[i*3+j];
pIndBuf->Unlock();
pIndBuf->Release();
description->triangles.data = indices;
description->triangles.count = mesh->GetNumFaces()*3;
description->triangles.stride = sizeof(PxU32);
PxDefaultMemoryOutputStream stream;
if(cooking->cookTriangleMesh(*description,stream))
std::cout << "Mesh has been baked successfully" << std::endl;
else
std::cout << "Mesh failed baking." << std::endl;
return false;
//code never comes here due to cookTriangleMesh always failing
//code handling the final cooked mesh
