Hi NV Support Team
From the orin pinmux some pin use 1.8 power domain but it can change by 3.3V Tolerance Enable.
My query is that if the we enable the 3.3V tolerence.
Q1: The pin only used as open drain output with external pull up to 3.3V. Is it correct?
Q2: The pin input 3.3V dont have issue with 1.8V power domian?
Q3: The pin can not used as cmos push pull if enable 3.3V tolerence?
One more: what is LPDR enable feature?
Yutai
