3 dgx spark cluster and sparkrun problem
I have three spark in full mesh/ring configuration as per spark-vllm repo netplan. When I installed sparkrun run it doesn’t recognize the cluster correctly and trying to do everything again, but fail and mixed up the netplan. Now I am back using spark-vllm, but can’t enjoy new recipes from sparkrun.
I think if anyone would share with me his cluster files from .config/sparkrun/cluster then I can figure out what I am missing.
Note: that I am using this configuration to run deepseek 4 flash with nccl. But I don’t need it for other models.
recipe_version: "1"        name: deepseek-v4-flash        description: "DeepSeek-V4-Flash"        container: aidendle94/sparkrun-vllm-ds4-gb10:production-v2                                                mods: []        defaults:        model: /root/.cache/huggingface/hub/models--unsloth--DeepSeek-V4-Flash/snapshots/bc486f653513c9179e20a970587dcbe928bf7b96        port: 8000        host: 0.0.0.0        tensor_parallel: 2        pipeline_parallel: 1
  data_parallel: 1
env:
  TILELANG_CLEANUP_TEMP_FILES: "1"
  VLLM_TRITON_MLA_SPARSE: "1"
  VLLM_TRITON_MLA_SPARSE_HEAD_BLOCK_SIZE: "4"
  VLLM_TRITON_MLA_SPARSE_QUERY_CHUNK_SIZE: "512"
  VLLM_TRITON_MLA_SPARSE_TOPK_CHUNK_SIZE: "512"
  HF_HUB_OFFLINE: "1"
  # === NCCL: built-in IB transport (not plugin) ===
  NCCL_NET: "IB"
  NCCL_DEBUG: "WARN"
command: |
  # Per-node HCA selection using VLLM_HOST_IP (set by launch-cluster.sh)
  case "$VLLM_HOST_IP" in
    192.168.100.140) export NCCL_IB_HCA="rocep1s0f1" ;;
    192.168.100.138) export NCCL_IB_HCA="rocep1s0f0" ;;
    192.168.100.162) export NCCL_IB_HCA="rocep1s0f0" ;;
  esac
  echo "Node: $VLLM_HOST_IP -> NCCL_IB_HCA=$NCCL_IB_HCA"
  vllm serv....
The problem that it assume the wrong IP address for cx7 hosts
Hosts:     default cluster 'mesh'
  Head:    192.168.100.138
  Workers: 192.168.100.140
[1/6] Preparing
  done (0.0s)
[2/6] Building image — skipped (no builder)
[3/6] Distributing resources
  SSH cmd <- 192.168.198.12 FAILED rc=255 (5.0s): ssh: connect to host 192.168.198.12 port 22: Connection timed out
  SSH cmd <- 192.168.197.12 FAILED rc=255 (5.0s): ssh: connect to host 192.168.197.12 port 22: Connection timed out
  Distributing image aidendle94/sparkrun-vllm-ds4-gb10:production-v2 to 2 host(s)
  Container image up-to-date on all 2 host(s)
  Distributing model unsloth/DeepSeek-V4-Flash to 2 host(s)
Fetching 74 files: 100%|████████████████████████████████████████████████████████| 74/74 [00:00<00:00, 10179.35it/s]
Download complete: : 0.00B [00:00, ?B/s]                Model synced to 2 host(s)           | 0/74 [00:00<?, ?it/s]
  done (8.2s)
[4/6] Syncing tuning configs
  done (0.0s)
[5/6] Launching vllm runtime
  Step 1/7: Cleaning up existing containers
  Step 2/7: Detecting InfiniBand
  Step 3/7: Detecting head node IP
  Step 4/7: Launching containers
  Step 5/7: Running pre-serve hooks
  Step 6/7: Starting head node serve
  SSH script <- 192.168.100.138 FAILED rc=1 (5.6s): ============================================================
ERROR: Serve process exited immediately (PID 57)
Container logs:
Failed to exec serve on head node: ============================================================
Container logs:
This is from the other node
Available for KV:      99.8 GB
  Warning: model_params not available; model weight estimate is zero
  Warning: Missing architecture info (num_layers, num_kv_heads, head_dim); KV cache estimate unavailable
  Head:    192.168.100.140
  Workers: 192.168.100.138
[1/6] Preparing        done (0.0s)        [2/6] Building image        done (0.0s)        [3/6] Distributing resources        SSH cmd <- 192.168.188.11 FAILED rc=255 (5.0s): ssh: connect to host 192.168.188.11 port 22: Connection timed out        SSH cmd <- 192.168.187.11 FAILED rc=255 (5.0s): ssh: connect to host 192.168.187.11 port 22: Connection timed out        Distributing image aidendle94/sparkrun-vllm-ds4-gb10:production-v2 to 2 host(s)        Container image up-to-date on all 2 host(s)        done (6.4s)        [4/6] Syncing tuning configs        done (0.0s)        [5/6] Launching vllm runtime        Step 1/7: Cleaning up existing containers        Step 2/7: Detecting InfiniBand        Step 3/7: Detecting head node IP        Step 4/7: Launching containers        Step 5/7: Running pre-serve hooks        Step 6/7: Starting head node serve        SSH script <- 192.168.100.140 FAILED rc=1 (5.6s): ============================================================        ERROR: Serve process exited immediately (PID 17)        Container logs:        ============================================================        Failed to exec serve on head node: ============================================================        ERROR: Serve process exited immediately (PID 17)        Container logs:        ============================================================
