When I set display to native resolution in nvidia settings panel, I get 1440x810 and the bottom of screen is cut off. However, when using ‘auto’ mode the problem doesn’t occur (It correctly sets resolution to 1440x900). The same was with 304.84 driver, 304.64 worked fine. It’s not a big deal, because as I said - ‘auto’ mode works.
When I use direct (1440x900) option Xorg.0.log says:
[ 1019.637] (II) NVIDIA(0): Setting mode "DVI-I-1:nvidia-auto-select{ViewPortIn=1440x810,ViewPortOut=1440x810+0+45}"
‘auto’ option:
[ 1138.661] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select@1440x900+0+0"
System: Slackware 32bit
Card: geforce 7600 gs
Driver: 304.88
Kernel: 3.8.5
Edit: OK, it IS a big deal. I just tried few games (using wine), they change resolution automatically but now launching them takes me back to login screen. I’m not sure if those issues are related in any way. 304.64 works OK though.
Edit2: Although issue with resolution changing still exists, I managed to solve the problem with wine games - default xorg.conf file generated by nvidia installer made the trick.
nvidia-bug-report.log.gz (57 KB)
