If I do
nvidia-xconfig
Xorg will Seg Fault
If I do
nvidia-xconfig --no-allow-glx-with-composite
Xorg will start but none of my OpenGL apps will start or work
I will try and get a bug report uploaded…
nvidia-bug-report.log.gz (63.1 KB)
If I do
nvidia-xconfig
Xorg will Seg Fault
If I do
(gdb) run
Starting program: /usr/bin/glxinfo
Program received signal SIGSEGV, Segmentation fault.
__GI_____strtol_l_internal (nptr=0x7fffffffe48a "\t3653\nUid:\t0\t0\t0\t0\nGid:\t0\t0\t0\t0\nFDSize:\t64\nGroups:\t0 ",
endptr=0x0, base=0, group=0, loc=0x0) at ../stdlib/strtol_l.c:246
246 ../stdlib/strtol_l.c: No such file or directory.
(gdb) bt
#0 __GI_____strtol_l_internal (
nptr=0x7fffffffe48a "\t3653\nUid:\t0\t0\t0\t0\nGid:\t0\t0\t0\t0\nFDSize:\t64\nGroups:\t0 ", endptr=0x0, base=0,
#1 0x00007ffff7b59ecd in ?? () from /usr/lib/nvidia-310/libGL.so.1
#2 0x00007ffff7b59f19 in ?? () from /usr/lib/nvidia-310/libGL.so.1
#3 0x00007ffff7b65699 in ?? () from /usr/lib/nvidia-310/libGL.so.1
#4 0x00007ffff7b3e218 in ?? () from /usr/lib/nvidia-310/libGL.so.1
#5 0x00007ffff7de9830 in call_init (l=l@entry=0x7ffff7ff94c0, argc=argc@entry=1, argv=argv@entry=0x7fffffffe6a8,
env=env@entry=0x7fffffffe6b8) at dl-init.c:69
#6 0x00007ffff7de9930 in call_init (env=<optimized out>, argv=<optimized out>, argc=<optimized out>, l=0x7ffff7ff94c0)
at dl-init.c:55
#7 _dl_init (main_map=0x7ffff7ffe268, argc=1, argv=0x7fffffffe6a8, env=0x7fffffffe6b8) at dl-init.c:133
#8 0x00007ffff7ddb68a in _dl_start_user () from /lib64/ld-linux-x86-64.so.2
#9 0x0000000000000001 in ?? ()
#10 0x00007fffffffe8b1 in ?? ()
#11 0x0000000000000000 in ?? ()
(gdb)
Hope this helps
