313.x - 319.23 drivers fail to build on any kernel after 3.9.0, heads up for kernel 3.10.0
That’s any driver 313.x up to NVIDIA-Linux-x86_64-319.23.run
from /usr/src/NVIDIA-Linux-x86_64-319.17/kernel/nv-linux.h:115,
from /usr/src/NVIDIA-Linux-x86_64-319.17/kernel/nv-i2c.c:15:
/usr/src/linux-3.9.0/arch/x86/include/asm/uaccess_64.h: In function ‘copy_from_user’:
/usr/src/linux-3.9.0/arch/x86/include/asm/uaccess_64.h:62:6: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
/usr/src/NVIDIA-Linux-x86_64-319.17/kernel/nv-i2c.c: In function ‘nv_i2c_del_adapter’:
/usr/src/NVIDIA-Linux-x86_64-319.17/kernel/nv-i2c.c:316:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
/usr/src/NVIDIA-Linux-x86_64-319.17/kernel/nv-i2c.c:328:13: error: void value not ignored as it ought to be
make[4]: *** [/usr/src/NVIDIA-Linux-x86_64-319.17/kernel/nv-i2c.o] Error 1
make[3]: *** [module/usr/src/NVIDIA-Linux-x86_64-319.17/kernel] Error 2
make[2]: *** [sub-make] Error 2
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make[1]: *** [module] Error 1
make: *** [install] Error 2
CODE:-
BOOL NV_API_CALL nv_i2c_del_adapter(nv_state_t *nv, void *data)
struct i2c_adapter *pI2cAdapter = (struct i2c_adapter *)data;
int osstatus = 0;
i2c_del_adapter(pI2cAdapter);
BOOL wasReleased = FALSE;
#if defined(KERNEL_2_4)
if (!NV_WEAK_SYMBOL_PRESENT(i2c_add_adapter))
return FALSE;
if (!NV_WEAK_SYMBOL_PRESENT(i2c_del_adapter))
return FALSE;
#endif
if (!pI2cAdapter) return FALSE;
// attempt release with the OS
osstatus = i2c_del_adapter(pI2cAdapter);
if (!osstatus)
os_free_mem(pI2cAdapter);
wasReleased = TRUE;
return wasReleased;
https://devtalk.nvidia.com/default/topic/543728/linux/building-nvidia-driver-on-kernel-3-9-0/post/3814531/#3814531 #17
