32/5000
Orin How do I adjust the fan speed command? What is the file path of the control fan?
This looks like a Jetson question. What Orin product are you referring to? I can then move your question to the proper forum for support.
[Jetson Orin NX]
Thanks. Moving this to the ORIN NX category.
Please check the L4T doc: Jetson Orin NX Series and Jetson AGX Orin Series — Jetson Linux
Developer Guide 34.1 documentation (nvidia.com)
The Orin NX module hasn’t been lanuched, are you on Orin devkit with emulator configuration?
Yes, the Xavier NX EMMC system is jetpack5.0.1. Where is the file path for adjusting the fan speed? Is it this “etc/ nvfanControl.conf” file?
hello 77097962,
that’s correct,
nvfancontrol is a user-space daemon to manage the fan speed, please check fan profile table for reference.
thanks
