I have been trying for some time to get CUDA installed with Visual Studio 2008 (Standard Edition), SP1, without success so far. The OS is Vista 64, but I want to create 32-bit code. The error is:
‘cl’ is not recognized as an internal or external command
operable program or batch file.
Project : error PRJ0019: A tool returned an error code from “Compiling with CUDA Build Rule…”
I have an installation on XP (32-bit) that seems to work.
Try to change dir bin to bin64 in your cuda toolkit directory. You need to install 32 bit version of toolkit. I was very angry on this, cause I need to to develop 32-bit application on win64 too. Need to ask NV developers.
Hi im new to cuda, i’m using windows 7 64-bit and i have the GT240. i am having troubles using the nvcc such as nvcc fatal and cl.exe cant be found in PATH and so on, so bottom line can you please list for me from A to Z all the necessary applications and drivers and all that i need in order to start compiling .cu files and CUDA…
thank you!
I renamed bin and lib directory in toolkit to bin64 and lib64. Cuda3.2 should support 32 bit compilation for win7 64 bit systems. Also try to ask on vista subforum.
