331.20 & openSuSE 12.3 - Xinerama Multiple Monitors 3 Separate Screensavers not Synch'ed
System Specs: MSI 890FXA-GD65, AMD Phenom™ II X6 1090T Processor 6 core @ 3.2 GHz, 16 GB DDR3 1333, 4x Seagate 1 TB ST31000528AS, 2x Nvidia GeForce GT610
Previous installation:
openSuSE 12.1 x86_64 kernel 3.1.9-4
nVidia 310.32
Current installation:
openSuSE 12.3 x86_64 kernel 3.7.10-1.1
nVidia 331.20
I have three displays on 2 NVIDIA GPU GeForce GT 610
No problem with spreading everything across all three displays - BUT
when I get thrown into the screensaver, each display has it’s own screensaver session - each display starts its own separate screensaver.
Previously when I ran openSuSE 12.1 with 310.32, a single screensaver instance ran across all three displays.
I went through the exercise of un-installing 331.20 and trying 310.32 & 319.17 against openSuSE 12.3 x86_64 kernel 3.7.10-1.1 - no joy.
[code]
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Fri Dec 27 03:05:00 2013
installer version: 331.20
PATH: /sbin:/usr/sbin:/usr/local/sbin:/root/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 331.20.
-> There appears to already be a driver installed on your system (version: 331.20). As part of installing this driver (version: 331.20), the existing driver will be uninstalled. Are you sure you want to continue? (‘no’ will abort installation) (Answer: Yes)
-> Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
-> done.
-> Performing CC sanity check with CC=“cc”.
-> Kernel source path: ‘/lib/modules/3.7.10-1.1-desktop/source’
-> Kernel output path: ‘/lib/modules/3.7.10-1.1-desktop/build’
-> Performing rivafb check.
-> Performing nvidiafb check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Cleaning kernel module build directory.
executing: ‘cd ./kernel; make clean’…
-> Building NVIDIA kernel module:
executing: ‘cd ./kernel; make module SYSSRC=/lib/modules/3.7.10-1.1-desktop/source SYSOUT=/lib/modules/3.7.10-1.1-desktop/build NV_BUILD_MODULE_INSTANCES=’…
NVIDIA: calling KBUILD…
make[1]: Entering directory `/usr/src/linux-3.7.10-1.1’
make -C /lib/modules/3.7.10-1.1-desktop/build
KBUILD_SRC=/usr/src/linux-3.7.10-1.1
KBUILD_EXTMOD="/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel" -f /usr/src/linux-3.7.10-1.1/Makefile
modules
test -e include/generated/autoconf.h -a -e include/config/auto.conf || (
echo >&2;
echo >&2 " ERROR: Kernel configuration is invalid.";
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";
echo >&2 " Run ‘make oldconfig && make prepare’ on kernel src to fix it.";
echo >&2 ;
/bin/false)
mkdir -p /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_versions ; rm -f /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_versions/*
make -f /usr/src/linux-3.7.10-1.1/scripts/Makefile.build obj=/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-i
nline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv.c
In file included from /usr/src/linux-3.7.10-1.1/include/linux/kernel.h:10:0,
from /usr/src/linux-3.7.10-1.1/include/linux/sched.h:15,
from /usr/src/linux-3.7.10-1.1/include/linux/utsname.h:5,
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-linux.h:44,
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv.c:13:
/usr/src/linux-3.7.10-1.1/include/linux/bitops.h: In function ‘hweight_long’:
/usr/src/linux-3.7.10-1.1/include/linux/bitops.h:66:41: warning: signed and unsigned type in conditional expression [-Wsign-compare]
In file included from /usr/src/linux-3.7.10-1.1/arch/x86/include/asm/uaccess.h:594:0,
from /usr/src/linux-3.7.10-1.1/include/linux/poll.h:11,
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-linux.h:97,
/usr/src/linux-3.7.10-1.1/arch/x86/include/asm/uaccess_64.h: In function ‘copy_from_user’:
/usr/src/linux-3.7.10-1.1/arch/x86/include/asm/uaccess_64.h:62:6: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-acpi.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-function
s-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_acpi)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-acpi.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-acpi.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-acpi.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-chrdev.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-in
line-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_chrdev)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-chrdev.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-chrdev.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-chrdev.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-cray.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unw
ind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_cray)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-cray.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-cray.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-cray.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-drm.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynch
ronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_drm)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-drm.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-drm.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-drm.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-gvi.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fa
synchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_gvi)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-gvi.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-gvi.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-gvi.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-i2c.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointe
r -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_i2c)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-i2c.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-i2c.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-i2c.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-mempool.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-fra
me-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_mempool)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-mempool.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-mempool.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-mempool.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-mlock.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-
but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_mlock)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-mlock.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-mlock.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-mlock.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-mmap.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protec
tor -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_mmap)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-mmap.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-mmap.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-mmap.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-p2p.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-st
ack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_p2p)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-p2p.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-p2p.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-p2p.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-pat.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -f
no-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_pat)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-pat.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-pat.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-pat.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-procfs.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than
=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_procfs)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-procfs.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-procfs.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-procfs.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-usermap.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno
-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_usermap)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-usermap.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-usermap.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-usermap.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-vm.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -
mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_vm)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-vm.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-vm.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-vm.c:14:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.nv-vtophys.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-m
mx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_vtophys)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_nv-vtophys.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-vtophys.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/nv-vtophys.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.os-interface.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -W
no-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_interface)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_os-interface.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/os-interface.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/os-interface.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.os-pci.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_F
XSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_pci)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_os-pci.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/os-pci.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/os-pci.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.os-registry.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DC
ONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“331.20” -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=“nvidia” -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_registry)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.tmp_os-registry.o /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/os-registry.c
from /tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/os-registry.c:15:
cc -Wp,-MD,/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel/.os-smp.o.d -nostdinc -isystem /usr/lib64/gcc/x86_64-suse-linux/4.7/include -I/usr/src/linux-3.7.10-1.1/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.7.10-1.1/include -Iinclude -I/usr/src/linux-3.7.10-1.1/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.7.10-1.1/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.7.10-1.1/include/linux/kconfig.h -I/tmp/selfgz2300/NVIDIA-Linux-x86_64-331.20/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1
-DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -pipe -Wno-sign-compare -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=2048 -fno-stack-protector -Wno-unused-but-set-variable -fomit-frame-pointer -fasynchronous-unwind-tables -g -fno-inline-functions-called-once -W
I would like to thank everyone for their input on this.
This is one of the distinct reasons that Linux still has the monumental problem of gaining mainstream acceptance - distinct lack of serious vendor support. I wonder how many vendors offered support for a thing called DOS 2.1?
I am not alone on this as there are multiple posts that have lingered for months with +100 views, but nary a comment.
Thank you nVidia community - you have severed me NOT well… BTW, just dropped $490 on two new RADEON cards… that’s voting with my pocket. You had your chance - and, um, all responsibility on you - you lost my money.
Fare thee NOT well…
Oh - for those of you that are actually interested in the problem - upgraded to latest long term stable driver - now my screensaver is synchronized - at the screen lock login, even though random screensavers are selected in the screensaver mode…
Thanks everyone!!!
I think this is intentional behavior in xscreensaver. I don’t know why an older driver with an older version of SuSE would make a difference. Maybe that behavior changed in a newer version of xscreensaver?
By default, xscreensaver will run a separately-chosen hack on each screen. Approximately nine years ago I patched it to add the option of running (multiple instances of) the same hack across all screens. This change (well, jwz’s reimplementation of it) showed up in xscreensaver 4.21.
Perhaps the OP’s xscreensaver preferences were overwritten during the update process?
