Using openSUSE Linux KDE I run into this bug over and over again:
Application: kdeinit5 (kdeinit5), signal: Aborted
Using host libthread_db library “/lib64/libthread_db.so.1”.
[KCrash Handler]
#6 0x00007fe616f7d160 in raise () from /lib64/libc.so.6
#7 0x00007fe616f7e741 in abort () from /lib64/libc.so.6
#8 0x00007fe616fc04a7 in __libc_message () from /lib64/libc.so.6
#9 0x00007fe616fc6cc3 in malloc_printerr () from /lib64/libc.so.6
#10 0x00007fe616fc85c9 in _int_free () from /lib64/libc.so.6
#11 0x00007fe615400fb9 in ?? () from /usr/X11R6/lib64/libGL.so.1
#12 0x00007fe611c0fb80 in ?? () from /usr/lib64/libnvidia-glcore.so.340.107
#13 0x00007fe6153df0af in ?? () from /usr/X11R6/lib64/libGL.so.1
#14 0x00007fe618df32d2 in _dl_fini () from /lib64/ld-linux-x86-64.so.2
#15 0x00007fe616f7fd78 in __run_exit_handlers () from /lib64/libc.so.6
#16 0x00007fe616f7fdca in exit () from /lib64/libc.so.6
#17 0x00005651b039e926 in ?? ()
#18 0x00005651b039fc5c in ?? ()
#19 0x00005651b03a05cf in ?? ()
#20 0x00005651b039b43c in ?? ()
#21 0x00007fe616f67f8a in __libc_start_main () from /lib64/libc.so.6
#22 0x00005651b039c09a in ?? ()
[Inferior 1 (process 5613) detached]
Do you have debug symbols so I can send a debug report?
The KDE details are here: 409112 – kdeinit5 (kdeinit5), signal: Aborted Using host libthread_db library "/lib64/libthread_db.so.1"
nvidia-bug-report.log.gz (103 KB)
