You should be able to use the ModeValidation option to disable the particular checks that are causing problems only on the problematic display. The ModeDebug option will tell you for each mode which check is causing it to be rejected.
I haven’t tried ModeValidation yet, because it’s much more complex to use and I need to understand it first, but I believe that the fact that it didn’t take “UseEdidFreqs” in account is a bug, and the fact that I can’t configure independant values of UseEDID for each monitor is also wrong.
In the current state All ModeDebug tells me is that there is no Edid available, and then it builds a long list of possible modes. Here is an excerpts :
[ 255.774] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 255.774] (==) NVIDIA(0): RGB weight 888
[ 255.774] (==) NVIDIA(0): Default visual is TrueColor
[ 255.774] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 255.774] (**) NVIDIA(0): Option "UseEdidFreqs" "FALSE"
[ 255.774] (**) NVIDIA(0): Option "ModeDebug" "True"
[ 255.775] (**) NVIDIA(0): Option "UseEDID" "FALSE"
[ 255.775] (**) NVIDIA(0): Enabling 2D acceleration
[ 255.775] (**) NVIDIA(0): Ignoring EDIDs
[ 256.446] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:2:0:0
[ 256.446] (--) NVIDIA(0): CRT-0
[ 256.446] (--) NVIDIA(0): DFP-0 (boot)
[ 256.446] (--) NVIDIA(0): DFP-1 (boot)
[ 256.447] (II) NVIDIA(0): NVIDIA GPU GeForce GT 710 (GK208) at PCI:2:0:0 (GPU-0)
[ 256.447] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 256.447] (--) NVIDIA(0): VideoBIOS: 80.28.a6.00.10
[ 256.447] (II) NVIDIA(0): Detected PCI Express Link width: 8X
[ 256.462] (--) NVIDIA(GPU-0): CRT-0: connected
[ 256.462] (--) NVIDIA(GPU-0): CRT-0 Name Aliases:
[ 256.462] (--) NVIDIA(GPU-0): DPY-0
[ 256.462] (--) NVIDIA(GPU-0): VGA-0
[ 256.462] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 256.462] (--) NVIDIA(GPU-0): --- EDID for VGA-0 ---
[ 256.462] (--) NVIDIA(GPU-0): No EDID Available.
[ 256.462] (--) NVIDIA(GPU-0): --- End of EDID for VGA-0 ---
[ 256.463] (--) NVIDIA(GPU-0): DFP-0: connected
[ 256.463] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 256.463] (--) NVIDIA(GPU-0): DFP-0 Name Aliases:
[ 256.463] (--) NVIDIA(GPU-0): DPY-1
[ 256.463] (--) NVIDIA(GPU-0): DVI-D-0
[ 256.463] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 256.463] (--) NVIDIA(GPU-0): --- EDID for DVI-D-0 ---
[ 256.463] (--) NVIDIA(GPU-0): No EDID Available.
[ 256.463] (--) NVIDIA(GPU-0): --- End of EDID for DVI-D-0 ---
[ 256.463] (--) NVIDIA(GPU-0): DFP-1: connected
[ 256.463] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 256.463] (--) NVIDIA(GPU-0): DFP-1 Name Aliases:
[ 256.463] (--) NVIDIA(GPU-0): DPY-2
[ 256.463] (--) NVIDIA(GPU-0): HDMI-0
[ 256.463] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 256.463] (--) NVIDIA(GPU-0): --- EDID for HDMI-0 ---
[ 256.463] (II) NVIDIA(GPU-0):
[ 256.463] (II) NVIDIA(GPU-0): --- Building ModePool for CRT-0 ---
[ 256.463] (II) NVIDIA(GPU-0): Validating Mode "640x350_85":
[ 256.463] (II) NVIDIA(GPU-0): Mode Source: VESA
[ 256.463] (II) NVIDIA(GPU-0): 640 x 350 @ 85 Hz
[ 256.463] (II) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
[ 256.463] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 672
[ 256.463] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 736, 832
[ 256.463] (II) NVIDIA(GPU-0): VRes, VSyncStart : 350, 382
[ 256.463] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 385, 445
[ 256.463] (II) NVIDIA(GPU-0): Sync Polarity : +H -V
[ 256.463] (II) NVIDIA(GPU-0): Viewport 640x350+0+0
[ 256.463] (II) NVIDIA(GPU-0): Horizontal Taps 0
[ 256.463] (II) NVIDIA(GPU-0): Vertical Taps 0
[ 256.463] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 256.463] (II) NVIDIA(GPU-0): Base Depth 32
[ 256.463] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 256.463] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 256.463] (II) NVIDIA(GPU-0): Mode "640x350_85" is valid.
[ 256.464] (II) NVIDIA(GPU-0): Validating Mode "640x400_85":
[ 256.464] (II) NVIDIA(GPU-0): Mode Source: VESA
[ 256.464] (II) NVIDIA(GPU-0): 640 x 400 @ 85 Hz
[ 256.464] (II) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
[ 256.464] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 672
[ 256.464] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 736, 832
[ 256.464] (II) NVIDIA(GPU-0): VRes, VSyncStart : 400, 401
[ 256.464] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 404, 445
[ 256.464] (II) NVIDIA(GPU-0): Sync Polarity : -H +V
[ 256.464] (II) NVIDIA(GPU-0): Viewport 640x400+0+0
[ 256.464] (II) NVIDIA(GPU-0): Horizontal Taps 0
[ 256.464] (II) NVIDIA(GPU-0): Vertical Taps 0
[ 256.464] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 256.464] (II) NVIDIA(GPU-0): Base Depth 32
[ 256.464] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 256.464] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 256.464] (II) NVIDIA(GPU-0): Mode "640x400_85" is valid.
[ 256.464] (II) NVIDIA(GPU-0): Validating Mode "720x400_85":
[ 256.464] (II) NVIDIA(GPU-0): 720 x 400 @ 85 Hz
[ 256.464] (II) NVIDIA(GPU-0): Pixel Clock : 35.50 MHz
[ 256.464] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 756
[ 256.464] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 828, 936
[ 256.464] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 404, 446
... Then more than 8000 lines of possible modes enumeration, then
[ 256.625] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 720x400"
[ 256.627] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 700x525"
[ 256.628] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 700x525d60"
[ 256.628] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 680x384"
[ 256.630] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 680x384d60_0"
[ 256.630] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 640x480"
[ 256.631] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 640x480_75"
[ 256.632] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 640x480_73"
[ 256.632] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 640x480_60"
[ 256.633] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 640x400"
[ 256.634] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 640x350"
[ 256.635] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 512x384"
[ 256.635] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 512x384i"
[ 256.636] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 512x384d60"
[ 256.637] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 400x300"
[ 256.639] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 320x240"
[ 256.640] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 320x240d60"
[ 256.640] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: 320x175"
[ 256.642] (II) NVIDIA(0): Adding implicit MetaMode: "DVI-D-0: nvidia-auto-select { ViewPortIn = 1024 x 576, ViewPortOut = 1024 x 576 + 0 + 96 }"
[ 256.642] (WW) NVIDIA(0): DFP-0 does not have an EDID, or its EDID does not contain a
[ 256.642] (WW) NVIDIA(0): maximum image size; cannot compute DPI from DFP-0's EDID.
[ 256.642] (**) NVIDIA(0): DPI set to (199, 100); computed from "DisplaySize" Monitor
[ 256.642] (**) NVIDIA(0): section option
[ 256.642] (--) Depth 24 pixmap format is 32 bpp
[ 256.642] (II) NVIDIA: Using 12288.00 MB of virtual memory for indirect memory
[ 256.642] (II) NVIDIA: access.
[ 256.693] (II) NVIDIA(0): Setting mode "DFP-0:1440x1080_85.00,DFP-1:1440x1080_85.00,CRT-0:1440x1080_85.00"
[ 256.806] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 256.806] (==) NVIDIA(0): Backing store enabled
[ 256.806] (==) NVIDIA(0): Silken mouse enabled
[ 256.806] (**) NVIDIA(0): DPMS enabled
[ 256.806] (II) Loading sub module "dri2"
[ 256.806] (II) LoadModule: "dri2"
[ 256.806] (II) Module "dri2" already built-in
[ 256.807] (II) NVIDIA(0): [DRI2] Setup complete
[ 256.807] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 256.807] (--) RandR disabled
And if I remove the “Option UseEDID False”, then I get the EDID content, including the wrong values coming from the KVM switch.
[175972.130] (--) NVIDIA(GPU-0): AOC 917W (CRT-0): connected
[175972.130] (--) NVIDIA(GPU-0): AOC 917W (CRT-0) Name Aliases:
[175972.130] (--) NVIDIA(GPU-0): CRT
[175972.130] (--) NVIDIA(GPU-0): CRT-0
[175972.130] (--) NVIDIA(GPU-0): DPY-0
[175972.130] (--) NVIDIA(GPU-0): VGA-0
[175972.130] (--) NVIDIA(GPU-0): DPY-EDID-271a2a23-1bf0-0adb-05ec-ff6a8b69942d
[175972.130] (--) NVIDIA(GPU-0): AOC 917W (CRT-0): 400.0 MHz maximum pixel clock
[175972.130] (--) NVIDIA(GPU-0): --- EDID for AOC 917W (VGA-0) ---
[175972.130] (--) NVIDIA(GPU-0): EDID Version : 1.3
[175972.130] (--) NVIDIA(GPU-0): Manufacturer : AOC
[175972.130] (--) NVIDIA(GPU-0): Monitor Name : AOC 917W
[175972.130] (--) NVIDIA(GPU-0): Product ID : 0x1917
[175972.130] (--) NVIDIA(GPU-0): 32-bit Serial Number : 0x0000b5d2
[175972.130] (--) NVIDIA(GPU-0): Serial Number String : M01A3HA046546
[175972.130] (--) NVIDIA(GPU-0): Manufacture Date : 2010, week 11
[175972.130] (--) NVIDIA(GPU-0): DPMS Capabilities : Active Off
[175972.130] (--) NVIDIA(GPU-0): Input Type : Analog
[175972.130] (--) NVIDIA(GPU-0): Prefer first detailed timing : Yes
[175972.130] (--) NVIDIA(GPU-0): Supports GTF : No
[175972.130] (--) NVIDIA(GPU-0): Maximum Image Size : 400 mm x 250 mm
[175972.130] (--) NVIDIA(GPU-0): Valid HSync Range : 30.0 kHz - 83.0 kHz
[175972.130] (--) NVIDIA(GPU-0): Valid VRefresh Range : 55.0 Hz - 75.0 Hz
[175972.130] (--) NVIDIA(GPU-0): EDID maximum pixel clock : 140.0 MHz
[175972.130] (--) NVIDIA(GPU-0): Standard Timings:
[175972.130] (--) NVIDIA(GPU-0): 1152 x 864 @ 75 Hz
[175972.130] (--) NVIDIA(GPU-0): 1280 x 960 @ 60 Hz
[175972.130] (--) NVIDIA(GPU-0): 1280 x 1024 @ 60 Hz
[175972.130] (--) NVIDIA(GPU-0): 1440 x 900 @ 60 Hz
[175972.130] (--) NVIDIA(GPU-0): 1440 x 900 @ 75 Hz
[175972.131] (--) NVIDIA(GPU-0): Detailed Timings:
[175972.131] (--) NVIDIA(GPU-0): 1440 x 900 @ 60 Hz
[175972.131] (--) NVIDIA(GPU-0): Pixel Clock : 106.50 MHz
[175972.131] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1440, 1520
[175972.131] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 1672, 1904
[175972.131] (--) NVIDIA(GPU-0): VRes, VSyncStart : 900, 903
[175972.131] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 909, 934
[175972.131] (--) NVIDIA(GPU-0): H/V Polarity : -/+
[175972.131] (--) NVIDIA(GPU-0): Image Size : 410 mm x 256 mm
[175972.131] (--) NVIDIA(GPU-0): RGB 444 bpcs : 8
[175972.131] (--) NVIDIA(GPU-0): Established Timings:
[175972.131] (--) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[175972.131] (--) NVIDIA(GPU-0): 640 x 480 @ 72 Hz
[175972.131] (--) NVIDIA(GPU-0): 640 x 480 @ 75 Hz
[175972.131] (--) NVIDIA(GPU-0): 800 x 600 @ 56 Hz
[175972.131] (--) NVIDIA(GPU-0): 800 x 600 @ 60 Hz
[175972.131] (--) NVIDIA(GPU-0): 800 x 600 @ 72 Hz
[175972.131] (--) NVIDIA(GPU-0): 800 x 600 @ 75 Hz
[175972.131] (--) NVIDIA(GPU-0): 1024 x 768 @ 60 Hz
[175972.131] (--) NVIDIA(GPU-0): 1024 x 768 @ 70 Hz
[175972.131] (--) NVIDIA(GPU-0): 1024 x 768 @ 75 Hz
[175972.131] (--) NVIDIA(GPU-0): 1280 x 1024 @ 75 Hz
[175972.131] (--) NVIDIA(GPU-0): --- End of EDID for AOC 917W (VGA-0) ---
[175972.131] (--) NVIDIA(GPU-0): Raw EDID bytes:
[175972.131] (--) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 05 e3 17 19 d2 b5 00 00
[175972.131] (--) NVIDIA(GPU-0): 0b 14 01 03 68 28 19 78 2e d6 a5 a2 59 4a 95 24
[175972.131] (--) NVIDIA(GPU-0): 14 50 54 bf ef 00 71 4f 81 40 81 80 95 00 95 0f
[175972.131] (--) NVIDIA(GPU-0): 01 01 01 01 01 01 9a 29 a0 d0 51 84 22 30 50 98
[175972.131] (--) NVIDIA(GPU-0): 36 00 9a 00 11 00 00 1c 00 00 00 fd 00 37 4b 1e
[175972.131] (--) NVIDIA(GPU-0): 53 0e 00 0a 20 20 20 20 20 20 00 00 00 fc 00 39
[175972.131] (--) NVIDIA(GPU-0): 31 37 57 0a 20 20 20 20 20 20 20 20 00 00 00 ff
[175972.131] (--) NVIDIA(GPU-0): 00 4d 30 31 41 33 48 41 30 34 36 35 34 36 00 6d
[175972.188] (--) NVIDIA(GPU-0): SONY TV (DFP-0): connected
[175972.196] (--) NVIDIA(GPU-0): SONY TV (DFP-0): Internal TMDS
[175972.196] (--) NVIDIA(GPU-0): SONY TV (DFP-0) Name Aliases:
[175972.196] (--) NVIDIA(GPU-0): DFP
[175972.196] (--) NVIDIA(GPU-0): DFP-0
[175972.196] (--) NVIDIA(GPU-0): DPY-1
[175972.196] (--) NVIDIA(GPU-0): DVI-D-0
[175972.196] (--) NVIDIA(GPU-0): DPY-EDID-01fed248-b978-4870-fffc-fb38a420e9a3
[175972.196] (--) NVIDIA(GPU-0): SONY TV (DFP-0): 340.0 MHz maximum pixel clock
[175972.196] (--) NVIDIA(GPU-0): --- EDID for SONY TV (DVI-D-0) ---
[175972.196] (--) NVIDIA(GPU-0): EDID Version : 1.3
[175972.196] (--) NVIDIA(GPU-0): Manufacturer : SNY
[175972.196] (--) NVIDIA(GPU-0): Monitor Name : SONY TV
[175972.196] (--) NVIDIA(GPU-0): Product ID : 0x2c02
[175972.196] (--) NVIDIA(GPU-0): 32-bit Serial Number : 0x01010101
[175972.196] (--) NVIDIA(GPU-0): Serial Number String :
[175972.196] (--) NVIDIA(GPU-0): Manufacture Date : 2011, week 1
[175972.196] (--) NVIDIA(GPU-0): DPMS Capabilities :
[175972.196] (--) NVIDIA(GPU-0): Input Type : Digital
[175972.196] (--) NVIDIA(GPU-0): Prefer first detailed timing : Yes
[175972.196] (--) NVIDIA(GPU-0): Supports GTF : No
[175972.196] (--) NVIDIA(GPU-0): Maximum Image Size : 890 mm x 500 mm
[175972.196] (--) NVIDIA(GPU-0): Valid HSync Range : 14.0 kHz - 70.0 kHz
[175972.196] (--) NVIDIA(GPU-0): Valid VRefresh Range : 48.0 Hz - 62.0 Hz
[175972.196] (--) NVIDIA(GPU-0): EDID maximum pixel clock : 150.0 MHz
[175972.196] (--) NVIDIA(GPU-0): CEA-861 extension block # : 0
[175972.196] (--) NVIDIA(GPU-0): CEA-861 revision : 3
[175972.196] (--) NVIDIA(GPU-0): IEEE Vendor Registration ID: 00-0c-03
[175972.196] (--) NVIDIA(GPU-0): Supports YCbCr 4:4:4 : Yes
[175972.196] (--) NVIDIA(GPU-0): Supports YCbCr 4:2:2 : Yes
[175972.196] (--) NVIDIA(GPU-0): Supports Basic Audio : Yes
[175972.196] (--) NVIDIA(GPU-0): Audio Descriptor : 0
[175972.196] (--) NVIDIA(GPU-0): Audio Format : PCM
[175972.196] (--) NVIDIA(GPU-0): Maximum Channels : 2
[175972.196] (--) NVIDIA(GPU-0): Sample Rates : 32KHz, 44KHz, 48KHz
[175972.196] (--) NVIDIA(GPU-0): Sample Sizes : 16-bits, 20-bits, 24-bits
[175972.196] (--) NVIDIA(GPU-0): Audio Descriptor : 1
[175972.196] (--) NVIDIA(GPU-0): Audio Format : AC-3
[175972.196] (--) NVIDIA(GPU-0): Maximum Channels : 6
[175972.196] (--) NVIDIA(GPU-0): Maximum Bit Rate : 640 kHz
[175972.196] (--) NVIDIA(GPU-0): Speaker Allocation Data :
[175972.196] (--) NVIDIA(GPU-0): Front Left + Front Right
[175972.196] (--) NVIDIA(GPU-0): Standard Timings:
[175972.196] (--) NVIDIA(GPU-0): 1280 x 1024 @ 60 Hz
[175972.196] (--) NVIDIA(GPU-0): Detailed Timings:
[175972.196] (--) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[175972.196] (--) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[175972.196] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[175972.196] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[175972.196] (--) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[175972.196] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[175972.196] (--) NVIDIA(GPU-0): H/V Polarity : +/+
[175972.196] (--) NVIDIA(GPU-0): Image Size : 886 mm x 498 mm
[175972.196] (--) NVIDIA(GPU-0): RGB 444 bpcs : 8, 10, 12
[175972.196] (--) NVIDIA(GPU-0): YUV 444 bpcs : 8, 10, 12
[175972.196] (--) NVIDIA(GPU-0): YUV 422 bpcs : 8, 10, 12
[175972.196] (--) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[175972.196] (--) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[175972.196] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[175972.196] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[175972.196] (--) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[175972.196] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[175972.196] (--) NVIDIA(GPU-0): Established Timings:
[175972.196] (--) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[175972.196] (--) NVIDIA(GPU-0): 800 x 600 @ 60 Hz
[175972.196] (--) NVIDIA(GPU-0): 1024 x 768 @ 60 Hz
[175972.196] (--) NVIDIA(GPU-0): CEA-861B Timings:
[175972.196] (--) NVIDIA(GPU-0): 1920 x 1080 @ 50 Hz
[175972.196] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[175972.196] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[175972.196] (--) NVIDIA(GPU-0): CEA Format : 31
[175972.196] (--) NVIDIA(GPU-0): Aspect Ratio : 16:9
[175972.196] (--) NVIDIA(GPU-0): Pixel Clock : 148.35 MHz
[175972.196] (--) NVIDIA(GPU-0): CEA Format : 16
[175972.197] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[175972.197] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[175972.197] (--) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[175972.197] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 1094, 1124
[175972.197] (--) NVIDIA(GPU-0): H/V Polarity : +/+
[175972.197] (--) NVIDIA(GPU-0): Interlaced : yes
[175972.197] (--) NVIDIA(GPU-0): CEA Format : 20
[175972.197] (--) NVIDIA(GPU-0): Aspect Ratio : 16:9
[175972.197] (--) NVIDIA(GPU-0): RGB 444 bpcs : 8, 10, 12
[175972.197] (--) NVIDIA(GPU-0): YUV 444 bpcs : 8, 10, 12
[175972.197] (--) NVIDIA(GPU-0): YUV 422 bpcs : 8, 10, 12
[175972.197] (--) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[175972.197] (--) NVIDIA(GPU-0): Pixel Clock : 74.18 MHz
[175972.197] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[175972.197] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[175972.197] (--) NVIDIA(GPU-0): CEA Format : 5
[175972.197] (--) NVIDIA(GPU-0): 1280 x 720 @ 50 Hz
[175972.197] (--) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[175972.197] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1720
[175972.197] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 1760, 1980
[175972.197] (--) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[175972.197] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[175972.197] (--) NVIDIA(GPU-0): CEA Format : 19
[175972.197] (--) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[175972.197] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[175972.197] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[175972.197] (--) NVIDIA(GPU-0): CEA Format : 4
[175972.197] (--) NVIDIA(GPU-0): 1920 x 1080 @ 24 Hz
[175972.197] (--) NVIDIA(GPU-0): Pixel Clock : 74.16 MHz
[175972.197] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2558
[175972.197] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2602, 2750
[175972.197] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[175972.197] (--) NVIDIA(GPU-0): CEA Format : 32
[175972.197] (--) NVIDIA(GPU-0): 1920 x 1080 @ 30 Hz
[175972.197] (--) NVIDIA(GPU-0): CEA Format : 34
[175972.197] (--) NVIDIA(GPU-0): 1280 x 720 @ 24 Hz
[175972.197] (--) NVIDIA(GPU-0): Pixel Clock : 59.33 MHz
[175972.197] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 3040
[175972.197] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 3080, 3300
[175972.197] (--) NVIDIA(GPU-0): CEA Format : 60
[175972.197] (--) NVIDIA(GPU-0): 1280 x 720 @ 30 Hz
[175972.197] (--) NVIDIA(GPU-0): H/V Polarity : -/+
[175972.197] (--) NVIDIA(GPU-0): CEA Format : 62
[175972.197] (--) NVIDIA(GPU-0): 720 x 576 @ 50 Hz
[175972.197] (--) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[175972.197] (--) NVIDIA(GPU-0): HRes, HSyncStart : 720, 732
[175972.197] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 796, 864
[175972.197] (--) NVIDIA(GPU-0): VRes, VSyncStart : 576, 581
[175972.197] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 586, 625
[175972.197] (--) NVIDIA(GPU-0): H/V Polarity : -/-
[175972.197] (--) NVIDIA(GPU-0): CEA Format : 18
[175972.197] (--) NVIDIA(GPU-0): 720 x 480 @ 60 Hz
[175972.197] (--) NVIDIA(GPU-0): HRes, HSyncStart : 720, 736
[175972.197] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 798, 858
[175972.198] (--) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[175972.198] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 495, 525
[175972.198] (--) NVIDIA(GPU-0): H/V Polarity : -/-
[175972.198] (--) NVIDIA(GPU-0): CEA Format : 3
[175972.198] (--) NVIDIA(GPU-0): Aspect Ratio : 16:9
[175972.198] (--) NVIDIA(GPU-0): RGB 444 bpcs : 8, 10, 12
[175972.198] (--) NVIDIA(GPU-0): YUV 444 bpcs : 8, 10, 12
[175972.198] (--) NVIDIA(GPU-0): YUV 422 bpcs : 8, 10, 12
[175972.198] (--) NVIDIA(GPU-0): 720 x 576 @ 50 Hz
[175972.198] (--) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[175972.198] (--) NVIDIA(GPU-0): HRes, HSyncStart : 720, 732
[175972.198] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 796, 864
[175972.198] (--) NVIDIA(GPU-0): VRes, VSyncStart : 576, 581
[175972.198] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 586, 625
[175972.198] (--) NVIDIA(GPU-0): CEA Format : 17
[175972.198] (--) NVIDIA(GPU-0): Aspect Ratio : 4:3
[175972.198] (--) NVIDIA(GPU-0): 720 x 480 @ 60 Hz
[175972.198] (--) NVIDIA(GPU-0): HRes, HSyncStart : 720, 736
[175972.198] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 798, 858
[175972.198] (--) NVIDIA(GPU-0): CEA Format : 2
[175972.198] (--) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[175972.198] (--) NVIDIA(GPU-0): Pixel Clock : 25.17 MHz
[175972.198] (--) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[175972.198] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 800
[175972.198] (--) NVIDIA(GPU-0): VRes, VSyncStart : 480, 490
[175972.198] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 525
[175972.198] (--) NVIDIA(GPU-0): CEA Format : 0
[175972.198] (--) NVIDIA(GPU-0): Extension Block Detailed Timings:
[175972.198] (--) NVIDIA(GPU-0): 1920 x 1080 @ 50 Hz
[175972.198] (--) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[175972.198] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[175972.198] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[175972.198] (--) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[175972.198] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[175972.198] (--) NVIDIA(GPU-0): H/V Polarity : +/+
[175972.198] (--) NVIDIA(GPU-0): Image Size : 886 mm x 498 mm
[175972.198] (--) NVIDIA(GPU-0): 1280 x 720 @ 50 Hz
[175972.198] (--) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[175972.198] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1720
[175972.198] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 1760, 1980
[175972.198] (--) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[175972.198] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[175972.198] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 1094, 1124
[175972.198] (--) NVIDIA(GPU-0): Interlaced : yes
[175972.198] (--) NVIDIA(GPU-0): --- End of EDID for SONY TV (DVI-D-0) ---
[175972.198] (--) NVIDIA(GPU-0): Raw EDID bytes:
[175972.198] (--) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 4d d9 02 2c 01 01 01 01
[175972.198] (--) NVIDIA(GPU-0): 01 15 01 03 80 59 32 78 0a 0d c9 a0 57 47 98 27
[175972.198] (--) NVIDIA(GPU-0): 12 48 4c 21 08 00 81 80 01 01 01 01 01 01 01 01
[175972.198] (--) NVIDIA(GPU-0): 01 01 01 01 01 01 02 3a 80 18 71 38 2d 40 58 2c
[175972.198] (--) NVIDIA(GPU-0): 45 00 76 f2 31 00 00 1e 01 1d 00 72 51 d0 1e 20
[175972.198] (--) NVIDIA(GPU-0): 6e 28 55 00 76 f2 31 00 00 1e 00 00 00 fc 00 53
[175972.198] (--) NVIDIA(GPU-0): 4f 4e 59 20 54 56 0a 20 20 20 20 20 00 00 00 fd
[175972.198] (--) NVIDIA(GPU-0): 00 30 3e 0e 46 0f 00 0a 20 20 20 20 20 20 01 09
[175972.198] (--) NVIDIA(GPU-0): 02 03 3b f0 53 1f 10 14 05 13 04 20 22 3c 3e 12
[175972.198] (--) NVIDIA(GPU-0): 16 03 07 11 15 02 06 01 26 09 07 07 15 07 50 83
[175972.198] (--) NVIDIA(GPU-0): 01 00 00 74 03 0c 00 10 00 b8 2d 2f d0 0a 01 40
[175972.198] (--) NVIDIA(GPU-0): 00 7f 20 30 70 80 90 76 e2 00 fb 02 3a 80 d0 72
[175972.198] (--) NVIDIA(GPU-0): 38 2d 40 10 2c 45 80 76 f2 31 00 00 1e 01 1d 00
[175972.198] (--) NVIDIA(GPU-0): bc 52 d0 1e 20 b8 28 55 40 76 f2 31 00 00 1e 01
[175972.198] (--) NVIDIA(GPU-0): 1d 80 d0 72 1c 16 20 10 2c 25 80 76 f2 31 00 00
[175972.198] (--) NVIDIA(GPU-0): 9e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 65
[175972.252] (--) NVIDIA(GPU-0): LG Electronics LG TV (DFP-1): connected
[175972.252] (--) NVIDIA(GPU-0): LG Electronics LG TV (DFP-1): Internal TMDS
[175972.252] (--) NVIDIA(GPU-0): LG Electronics LG TV (DFP-1) Name Aliases:
[175972.252] (--) NVIDIA(GPU-0): DFP
[175972.252] (--) NVIDIA(GPU-0): DFP-1
[175972.252] (--) NVIDIA(GPU-0): DPY-2
[175972.252] (--) NVIDIA(GPU-0): HDMI-0
[175972.252] (--) NVIDIA(GPU-0): DPY-EDID-bb0f1420-d68d-f67f-79fc-5e03bbbc97ac
[175972.252] (--) NVIDIA(GPU-0): LG Electronics LG TV (DFP-1): 340.0 MHz maximum pixel clock
[175972.252] (--) NVIDIA(GPU-0): --- EDID for LG Electronics LG TV (HDMI-0) ---
[175972.252] (--) NVIDIA(GPU-0): EDID Version : 1.3
[175972.252] (--) NVIDIA(GPU-0): Manufacturer : GSM
[175972.252] (--) NVIDIA(GPU-0): Monitor Name : LG Electronics LG TV
[175972.252] (--) NVIDIA(GPU-0): Product ID : 0x0001
[175972.252] (--) NVIDIA(GPU-0): 32-bit Serial Number : 0x01010101
[175972.252] (--) NVIDIA(GPU-0): Serial Number String :
[175972.252] (--) NVIDIA(GPU-0): Manufacture Date : 2013, week 1
[175972.252] (--) NVIDIA(GPU-0): DPMS Capabilities :
[175972.252] (--) NVIDIA(GPU-0): Input Type : Digital
[175972.252] (--) NVIDIA(GPU-0): Prefer first detailed timing : Yes
[175972.252] (--) NVIDIA(GPU-0): Supports GTF : No
[175972.252] (--) NVIDIA(GPU-0): Maximum Image Size : 1600 mm x 900 mm
[175972.252] (--) NVIDIA(GPU-0): Valid HSync Range : 30.0 kHz - 83.0 kHz
[175972.252] (--) NVIDIA(GPU-0): Valid VRefresh Range : 58.0 Hz - 62.0 Hz
[175972.252] (--) NVIDIA(GPU-0): EDID maximum pixel clock : 160.0 MHz
[175972.252] (--) NVIDIA(GPU-0): CEA-861 extension block # : 0
[175972.252] (--) NVIDIA(GPU-0): CEA-861 revision : 3
[175972.252] (--) NVIDIA(GPU-0): IEEE Vendor Registration ID: 00-0c-03
[175972.252] (--) NVIDIA(GPU-0): Supports YCbCr 4:4:4 : Yes
[175972.252] (--) NVIDIA(GPU-0): Supports YCbCr 4:2:2 : Yes
[175972.252] (--) NVIDIA(GPU-0): Supports Basic Audio : Yes
[175972.252] (--) NVIDIA(GPU-0): Audio Descriptor : 0
[175972.252] (--) NVIDIA(GPU-0): Audio Format : AC-3
[175972.252] (--) NVIDIA(GPU-0): Maximum Channels : 6
[175972.252] (--) NVIDIA(GPU-0): Sample Rates : 32KHz, 44KHz, 48KHz
[175972.252] (--) NVIDIA(GPU-0): Maximum Bit Rate : 640 kHz
[175972.252] (--) NVIDIA(GPU-0): Audio Descriptor : 1
[175972.252] (--) NVIDIA(GPU-0): Audio Format : PCM
[175972.252] (--) NVIDIA(GPU-0): Maximum Channels : 2
[175972.252] (--) NVIDIA(GPU-0): Sample Rates : 32KHz, 44KHz, 48KHz, 96KHz, 192KHz
[175972.252] (--) NVIDIA(GPU-0): Sample Sizes : 16-bits, 20-bits, 24-bits
[175972.252] (--) NVIDIA(GPU-0): Standard Timings:
[175972.252] (--) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[175972.252] (--) NVIDIA(GPU-0): 800 x 600 @ 60 Hz
[175972.252] (--) NVIDIA(GPU-0): 1024 x 768 @ 60 Hz
[175972.252] (--) NVIDIA(GPU-0): 1152 x 864 @ 60 Hz
[175972.252] (--) NVIDIA(GPU-0): Detailed Timings:
[175972.252] (--) NVIDIA(GPU-0): 1360 x 768 @ 60 Hz
[175972.252] (--) NVIDIA(GPU-0): Pixel Clock : 85.50 MHz
[175972.252] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1360, 1424
[175972.252] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 1536, 1792
[175972.252] (--) NVIDIA(GPU-0): VRes, VSyncStart : 768, 771
[175972.252] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 777, 795
[175972.252] (--) NVIDIA(GPU-0): H/V Polarity : +/+
[175972.252] (--) NVIDIA(GPU-0): Image Size : 1600 mm x 900 mm
[175972.252] (--) NVIDIA(GPU-0): RGB 444 bpcs : 8
[175972.252] (--) NVIDIA(GPU-0): YUV 444 bpcs : 8
[175972.252] (--) NVIDIA(GPU-0): YUV 422 bpcs : 8
[175972.252] (--) NVIDIA(GPU-0): Pixel Clock : 65.00 MHz
[175972.252] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1048
[175972.252] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 1184, 1344
[175972.252] (--) NVIDIA(GPU-0): VRes, VSyncStart : 768, 784
[175972.252] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 819, 806
[175972.252] (--) NVIDIA(GPU-0): H/V Polarity : -/-
[175972.253] (--) NVIDIA(GPU-0): YUV 444 bpcs : 8
[175972.253] (--) NVIDIA(GPU-0): YUV 422 bpcs : 8
[175972.253] (--) NVIDIA(GPU-0): Established Timings:
[175972.253] (--) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[175972.253] (--) NVIDIA(GPU-0): 800 x 600 @ 60 Hz
[175972.253] (--) NVIDIA(GPU-0): 1024 x 768 @ 60 Hz
[175972.253] (--) NVIDIA(GPU-0): CEA-861B Timings:
[175972.253] (--) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[175972.253] (--) NVIDIA(GPU-0): Pixel Clock : 148.35 MHz
[175972.253] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[175972.253] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[175972.253] (--) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[175972.253] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[175972.253] (--) NVIDIA(GPU-0): H/V Polarity : +/+
[175972.253] (--) NVIDIA(GPU-0): CEA Format : 16
[175972.253] (--) NVIDIA(GPU-0): Aspect Ratio : 16:9
[175972.253] (--) NVIDIA(GPU-0): RGB 444 bpcs : 8
[175972.253] (--) NVIDIA(GPU-0): 1920 x 1080 @ 50 Hz
[175972.253] (--) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[175972.253] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[175972.253] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[175972.253] (--) NVIDIA(GPU-0): CEA Format : 31
[175972.253] (--) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[175972.253] (--) NVIDIA(GPU-0): Pixel Clock : 74.18 MHz
[175972.253] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[175972.253] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[175972.253] (--) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[175972.253] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[175972.253] (--) NVIDIA(GPU-0): CEA Format : 4
[175972.253] (--) NVIDIA(GPU-0): 1280 x 720 @ 50 Hz
[175972.253] (--) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[175972.253] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1720
[175972.253] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 1760, 1980
[175972.253] (--) NVIDIA(GPU-0): CEA Format : 19
[175972.253] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 1094, 1124
[175972.253] (--) NVIDIA(GPU-0): Interlaced : yes
[175972.253] (--) NVIDIA(GPU-0): CEA Format : 5
[175972.253] (--) NVIDIA(GPU-0): CEA Format : 20
[175972.253] (--) NVIDIA(GPU-0): 720 x 480 @ 60 Hz
[175972.253] (--) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[175972.253] (--) NVIDIA(GPU-0): HRes, HSyncStart : 720, 736
[175972.253] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 798, 858
[175972.253] (--) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[175972.253] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 495, 525
[175972.253] (--) NVIDIA(GPU-0): H/V Polarity : -/-
[175972.253] (--) NVIDIA(GPU-0): Aspect Ratio : 4:3
[175972.253] (--) NVIDIA(GPU-0): 720 x 576 @ 50 Hz
[175972.253] (--) NVIDIA(GPU-0): HRes, HSyncStart : 720, 732
[175972.253] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 796, 864
[175972.253] (--) NVIDIA(GPU-0): VRes, VSyncStart : 576, 581
[175972.254] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 586, 625
[175972.254] (--) NVIDIA(GPU-0): H/V Polarity : -/-
[175972.254] (--) NVIDIA(GPU-0): CEA Format : 18
[175972.254] (--) NVIDIA(GPU-0): Aspect Ratio : 16:9
[175972.254] (--) NVIDIA(GPU-0): RGB 444 bpcs : 8
[175972.254] (--) NVIDIA(GPU-0): YUV 444 bpcs : 8
[175972.254] (--) NVIDIA(GPU-0): YUV 422 bpcs : 8
[175972.254] (--) NVIDIA(GPU-0): 1920 x 1080 @ 24 Hz
[175972.254] (--) NVIDIA(GPU-0): Pixel Clock : 74.16 MHz
[175972.254] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2558
[175972.254] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2602, 2750
[175972.254] (--) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[175972.254] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[175972.254] (--) NVIDIA(GPU-0): H/V Polarity : +/+
[175972.254] (--) NVIDIA(GPU-0): CEA Format : 32
[175972.254] (--) NVIDIA(GPU-0): 1920 x 1080 @ 25 Hz
[175972.254] (--) NVIDIA(GPU-0): Pixel Clock : 74.25 MHz
[175972.254] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2448
[175972.254] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2492, 2640
[175972.254] (--) NVIDIA(GPU-0): CEA Format : 33
[175972.254] (--) NVIDIA(GPU-0): 1920 x 1080 @ 30 Hz
[175972.254] (--) NVIDIA(GPU-0): Pixel Clock : 74.18 MHz
[175972.254] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[175972.254] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[175972.254] (--) NVIDIA(GPU-0): CEA Format : 34
[175972.254] (--) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[175972.254] (--) NVIDIA(GPU-0): Pixel Clock : 25.17 MHz
[175972.254] (--) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[175972.254] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 800
[175972.254] (--) NVIDIA(GPU-0): VRes, VSyncStart : 480, 490
[175972.254] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 525
[175972.254] (--) NVIDIA(GPU-0): CEA Format : 0
[175972.254] (--) NVIDIA(GPU-0): Aspect Ratio : 4:3
[175972.254] (--) NVIDIA(GPU-0): Extension Block Detailed Timings:
[175972.254] (--) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[175972.254] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 1094, 1124
[175972.254] (--) NVIDIA(GPU-0): Interlaced : yes
[175972.254] (--) NVIDIA(GPU-0): Image Size : 160 mm x 90 mm
[175972.254] (--) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[175972.254] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[175972.254] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[175972.254] (--) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[175972.254] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[175972.254] (--) NVIDIA(GPU-0): Image Size : 800 mm x 450 mm
[175972.254] (--) NVIDIA(GPU-0): 720 x 480 @ 60 Hz
[175972.254] (--) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[175972.254] (--) NVIDIA(GPU-0): HRes, HSyncStart : 720, 736
[175972.254] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 798, 858
[175972.254] (--) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[175972.254] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 495, 525
[175972.254] (--) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[175972.254] (--) NVIDIA(GPU-0): --- End of EDID for LG Electronics LG TV (HDMI-0) ---
What’s the list of modes without the kvm?
Without the KVM there is no EDID block transmitted for CRT-0:
[176222.050] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[176222.050] (==) NVIDIA(0): RGB weight 888
[176222.050] (==) NVIDIA(0): Default visual is TrueColor
[176222.050] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[176222.050] (**) NVIDIA(0): Option "UseEdidFreqs" "FALSE"
[176222.050] (**) NVIDIA(0): Option "ModeDebug" "True"
[176222.050] (**) NVIDIA(0): Enabling 2D acceleration
[176222.053] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:2:0:0
[176222.053] (--) NVIDIA(0): CRT-0
[176222.053] (--) NVIDIA(0): DFP-0 (boot)
[176222.053] (--) NVIDIA(0): DFP-1 (boot)
[176222.057] (II) NVIDIA(0): NVIDIA GPU GeForce GT 710 (GK208) at PCI:2:0:0 (GPU-0)
[176222.057] (--) NVIDIA(0): Memory: 2097152 kBytes
[176222.057] (--) NVIDIA(0): VideoBIOS: 80.28.a6.00.10
[176222.057] (II) NVIDIA(0): Detected PCI Express Link width: 8X
[176222.082] (--) NVIDIA(GPU-0): CRT-0: connected
[176222.082] (--) NVIDIA(GPU-0): CRT-0 Name Aliases:
[176222.082] (--) NVIDIA(GPU-0): DPY-0
[176222.082] (--) NVIDIA(GPU-0): VGA-0
[176222.082] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
Should be here...
[176222.140] (--) NVIDIA(GPU-0): SONY TV (DFP-0): connected
[176222.140] (--) NVIDIA(GPU-0): SONY TV (DFP-0): Internal TMDS
[176222.140] (--) NVIDIA(GPU-0): SONY TV (DFP-0) Name Aliases:
[176222.140] (--) NVIDIA(GPU-0): DFP
[176222.140] (--) NVIDIA(GPU-0): DFP-0
[176222.140] (--) NVIDIA(GPU-0): DPY-1
[176222.140] (--) NVIDIA(GPU-0): DVI-D-0
[176222.140] (--) NVIDIA(GPU-0): DPY-EDID-01fed248-b978-4870-fffc-fb38a420e9a3
[176222.140] (--) NVIDIA(GPU-0): SONY TV (DFP-0): 340.0 MHz maximum pixel clock
[176222.140] (--) NVIDIA(GPU-0): --- EDID for SONY TV (DVI-D-0) ---
[176222.140] (--) NVIDIA(GPU-0): EDID Version : 1.3
[176222.140] (--) NVIDIA(GPU-0): Manufacturer : SNY
[176222.140] (--) NVIDIA(GPU-0): Monitor Name : SONY TV
[176222.140] (--) NVIDIA(GPU-0): Product ID : 0x2c02
[176222.140] (--) NVIDIA(GPU-0): 32-bit Serial Number : 0x01010101
[176222.140] (--) NVIDIA(GPU-0): Serial Number String :
[176222.140] (--) NVIDIA(GPU-0): Manufacture Date : 2011, week 1
[176222.140] (--) NVIDIA(GPU-0): DPMS Capabilities :
[176222.140] (--) NVIDIA(GPU-0): Input Type : Digital
[176222.140] (--) NVIDIA(GPU-0): Prefer first detailed timing : Yes
[176222.140] (--) NVIDIA(GPU-0): Supports GTF : No
[176222.140] (--) NVIDIA(GPU-0): Maximum Image Size : 890 mm x 500 mm
[176222.140] (--) NVIDIA(GPU-0): Valid HSync Range : 14.0 kHz - 70.0 kHz
[176222.140] (--) NVIDIA(GPU-0): Valid VRefresh Range : 48.0 Hz - 62.0 Hz
[176222.140] (--) NVIDIA(GPU-0): EDID maximum pixel clock : 150.0 MHz
[176222.140] (--) NVIDIA(GPU-0): CEA-861 extension block # : 0
[176222.140] (--) NVIDIA(GPU-0): CEA-861 revision : 3
The modes are
[176222.232] (II) NVIDIA(GPU-0): --- Modes in ModePool for CRT-0 ---
[176222.232] (II) NVIDIA(GPU-0): "nvidia-auto-select" : 1024 x 768 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "2048x1536" : 2048 x 1536 @ 75.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "2048x1536_75" : 2048 x 1536 @ 75.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "2048x1536_60" : 2048 x 1536 @ 60.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1920x1440" : 1920 x 1440 @ 85.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1920x1440_85" : 1920 x 1440 @ 85.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1920x1440_75" : 1920 x 1440 @ 75.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1920x1440_60" : 1920 x 1440 @ 60.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1920x1200" : 1920 x 1200 @ 60.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1920x1200_60" : 1920 x 1200 @ 60.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1920x1080" : 1920 x 1080 @ 59.9 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1920x1080_60" : 1920 x 1080 @ 59.9 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1856x1392" : 1856 x 1392 @ 75.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1856x1392_75" : 1856 x 1392 @ 75.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1856x1392_60" : 1856 x 1392 @ 60.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1792x1344" : 1792 x 1344 @ 75.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1792x1344_75" : 1792 x 1344 @ 75.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1792x1344_60" : 1792 x 1344 @ 60.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1680x1050" : 1680 x 1050 @ 84.9 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1680x1050_85" : 1680 x 1050 @ 84.9 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1680x1050_75" : 1680 x 1050 @ 74.9 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1680x1050_70" : 1680 x 1050 @ 69.9 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1680x1050_60" : 1680 x 1050 @ 60.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1680x1050_60_0" : 1680 x 1050 @ 59.9 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1600x1200" : 1600 x 1200 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1600x1200_85" : 1600 x 1200 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1600x1200_75" : 1600 x 1200 @ 75.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1600x1200_70" : 1600 x 1200 @ 70.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1600x1200_65" : 1600 x 1200 @ 65.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1600x1200_60" : 1600 x 1200 @ 60.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.232] (II) NVIDIA(GPU-0): "1440x1080_85.00" : 1440 x 1080 @ 84.9 Hz (from: X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1440x1080_85" : 1440 x 1080 @ 84.9 Hz (from: X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1440x900" : 1440 x 900 @ 59.9 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1440x900_60" : 1440 x 900 @ 59.9 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1400x1050" : 1400 x 1050 @ 85.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1400x1050_85" : 1400 x 1050 @ 85.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1400x1050_75" : 1400 x 1050 @ 74.8 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1400x1050_70" : 1400 x 1050 @ 70.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1400x1050_60" : 1400 x 1050 @ 60.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1360x1020_85.00" : 1360 x 1020 @ 84.9 Hz (from: X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1360x1020_85" : 1360 x 1020 @ 84.9 Hz (from: X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1360x768" : 1360 x 768 @ 60.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1360x768_60" : 1360 x 768 @ 60.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1360x768_60_0" : 1360 x 768 @ 59.8 Hz (from: X Server, X Configuration file ModeLine)
[176222.232] (II) NVIDIA(GPU-0): "1280x1024" : 1280 x 1024 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1280x1024_85" : 1280 x 1024 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1280x1024_75" : 1280 x 1024 @ 75.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1280x1024_60" : 1280 x 1024 @ 60.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1280x960" : 1280 x 960 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1280x960_85" : 1280 x 960 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1280x960_60" : 1280 x 960 @ 60.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1280x720_60.00" : 1280 x 720 @ 59.9 Hz (from: X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "1280x720_60" : 1280 x 720 @ 59.9 Hz (from: X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "1152x864" : 1152 x 864 @ 100.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "1152x864_100" : 1152 x 864 @ 100.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "1152x864_85" : 1152 x 864 @ 85.1 Hz (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "1152x864_85_0" : 1152 x 864 @ 85.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "1152x864_75" : 1152 x 864 @ 75.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1152x864_75_0" : 1152 x 864 @ 75.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "1152x864_70" : 1152 x 864 @ 70.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "1152x864_60" : 1152 x 864 @ 60.0 Hz (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "1024x768" : 1024 x 768 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1024x768i" : 1024 x 768 @ 87.0 Hz Interlace (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "1024x768_85" : 1024 x 768 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1024x768_75" : 1024 x 768 @ 75.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1024x768_70" : 1024 x 768 @ 70.1 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1024x768_60" : 1024 x 768 @ 60.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "1024x768_87i" : 1024 x 768 @ 87.0 Hz Interlace (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "1024x768_87i_0" : 1024 x 768 @ 87.0 Hz Interlace (from: VESA)
[176222.233] (II) NVIDIA(GPU-0): "960x600" : 960 x 600 @ 60.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "960x600d60" : 960 x 600 @ 60.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "960x540" : 960 x 540 @ 60.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "960x540d60" : 960 x 540 @ 60.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "840x525" : 840 x 525 @ 85.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "840x525d85" : 840 x 525 @ 85.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "840x525d75" : 840 x 525 @ 75.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "840x525d70" : 840 x 525 @ 69.9 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "840x525d60" : 840 x 525 @ 60.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "840x525d60_0" : 840 x 525 @ 59.9 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "832x624" : 832 x 624 @ 74.6 Hz (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "832x624_75" : 832 x 624 @ 74.6 Hz (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "800x600" : 800 x 600 @ 85.1 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "800x600_85" : 800 x 600 @ 85.1 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "800x600_75" : 800 x 600 @ 75.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "800x600_72" : 800 x 600 @ 72.2 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "800x600_60" : 800 x 600 @ 60.3 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "800x600_56" : 800 x 600 @ 56.2 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "720x450" : 720 x 450 @ 59.9 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "720x450d60" : 720 x 450 @ 59.9 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "720x400" : 720 x 400 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "720x400_85" : 720 x 400 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "700x525" : 700 x 525 @ 74.8 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "700x525d75" : 700 x 525 @ 74.8 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "700x525d60" : 700 x 525 @ 60.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "680x384" : 680 x 384 @ 60.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "680x384d60" : 680 x 384 @ 60.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "680x384d60_0" : 680 x 384 @ 59.8 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "640x480" : 640 x 480 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "640x480_85" : 640 x 480 @ 85.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "640x480_75" : 640 x 480 @ 75.0 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "640x480_73" : 640 x 480 @ 72.8 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "640x480_60" : 640 x 480 @ 59.9 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "640x400" : 640 x 400 @ 85.1 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "640x400_85" : 640 x 400 @ 85.1 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "640x350" : 640 x 350 @ 85.1 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "640x350_85" : 640 x 350 @ 85.1 Hz (from: X Server, X Configuration file ModeLine, VESA)
[176222.233] (II) NVIDIA(GPU-0): "512x384" : 512 x 384 @ 70.1 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "512x384i" : 512 x 384 @ 87.1 Hz Interlace DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "512x384d70" : 512 x 384 @ 70.1 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "512x384d60" : 512 x 384 @ 60.0 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "512x384d87i" : 512 x 384 @ 87.1 Hz Interlace DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "400x300" : 400 x 300 @ 72.2 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "400x300d72" : 400 x 300 @ 72.2 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "320x240" : 320 x 240 @ 72.8 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "320x240d73" : 320 x 240 @ 72.8 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "320x240d60" : 320 x 240 @ 60.1 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "320x175" : 320 x 175 @ 85.3 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): "320x175d85" : 320 x 175 @ 85.3 Hz DoubleScan (from: X Server, X Configuration file ModeLine)
[176222.233] (II) NVIDIA(GPU-0): --- End of ModePool for CRT-0: ---
The logs say that the monitor you’ve connected to the vga port is an AOC 917W. Is that correct?
That would be an LCD and not an CRT. And the native resolution would be 1440x900.
No, that’s what I told above : It’s some “random” value which is stored in de kvm switch to simulated the presence of a monitor when it’s connected to the other computer. It might get updated if the kvm switch is able to ask the EDID from the monitor, but since my monitor doesn’t support EDID, it won’t happen.
My monitor is an old Iiyama syncmaster 454 CRT which doesn’t supports EDID (which you can see in my reply to your previous question.)
I think with the kvm switch faking an edid with no means to turn that off, your best shot would be to create a custom edid and load that.
See: [url]http://kodi.wiki/view/Creating_and_using_edid.bin_via_xorg.conf#Method_2:_Generate_edid.bin_from_an_Xorg_modeline_.28edid-generator.29[/url]
I hoped I would be able to “Option “UseEDID” “FALSE”” for the VGA port only, but it seems the designers didn’t realise that it might not make a very limited to have it activated or deactivated for all ports at once -_-".
I’m currently runnning with edid disabled for all monitors but it’s unconfortable while I’m investigating this possibility of forging a custom edid. I had found this page, but this procedure doesn’t seem to allow making edid “for the monitor”. It seems you can only provide one only mode with the edid-generator X-D.
No, you create single files for each modeline you want and in the end, you issue ‘make’ and it assembles all the files into one edid.bin with all modelines.
Well… Did you do it ? Because that’s what I believed it would make but that’s not what I obtain…
If you did it, I’d be glad to have your help to understand what I did wrong.
By the way, I’m not a specialist of Makefiles syntax, but as far as I understand what it tells, i wonder how it would make anything else, because there is only one source (edid.S), and it’s not a top file. On the contrary, it is included from all the *.S with my modes. I see no reason why it would make a final consolidater edid.bin with everything inside.
for now I’m making it the hard way withs the specs in my hand, and it’s quite a tedious process X-(
Ok, it works : I found an edid editor for windoze, which did the job with wine
Don’t know if you tried it but xrandr do hava a --scale-from word, It might get you to you want… Personally still working to get my newest laptop to start with something sensible and not ultra hd on a small but capeable screen. 1280x720 or 1920x1080 would be possuble to work with (I do need a 16:9 format, so eventually I am aiming for 1280x720 not something not to strain my — old? … eyes- Atm it’ unuseable at native resultion. LVDS are not easy to set up atm
