Some may remember my last post for Fedora 19 and the same issue. I decided to start a new thread since a lot of time, driver versions, and 2 fedora releases have passed but still has yet to be resolved.
PROBLEM: After installing the NVIDIA drivers, the machine will boot with plymouth just fine, but then it switches to a black screen. Apparently the gnome-session is active because I can blindly log-in and issue terminal commands to restart the machine or redirect terminal output to files; I just can’t see anything while doing it.
The Xorg log confirms that the card is connected to DFP-0 (I had to manually dump / provide the EDID); however, if I check xrandr it says that HDMI-0 is connected. If you look at my .xsession I try to set both displays to off before letting xrandr --auto take over.
Any thoughts or help? I really do not want to resort back to Bumblebee and I do not have a BIOS option to disable the intel card.
Xorg log: http://pastebin.com/bGCTbqiR
(==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
(**) NVIDIA(0): Option "ConnectedMonitor" "DFP-0"
(**) NVIDIA(0): Option "CustomEDID" "DFP-0:/etc/X11/dfp0.bin.edid"
(**) NVIDIA(0): Enabling 2D acceleration
(**) NVIDIA(0): ConnectedMonitor string: "DFP-0"
(II) NVIDIA(0): Using ConnectedMonitor string "DFP-0".
(II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
(II) NVIDIA(0): NVIDIA GPU GeForce GT 555M (GF106) at PCI:1:0:0 (GPU-0)
(--) NVIDIA(0): Memory: 3145728 kBytes
(--) NVIDIA(0): VideoBIOS: 70.06.32.00.02
(II) NVIDIA(0): Detected PCI Express Link width: 16X
(--) NVIDIA(0): Valid display device(s) on GeForce GT 555M at PCI:1:0:0
(--) NVIDIA(0): Chi Mei Optoelectronics corp. (DFP-0) (connected)
(--) NVIDIA(0): Chi Mei Optoelectronics corp. (DFP-0): Internal TMDS
(--) NVIDIA(GPU-0): Chi Mei Optoelectronics corp. (DFP-0): 165.0 MHz maximum pixel clock
(**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
(**) NVIDIA(0): device Chi Mei Optoelectronics corp. (DFP-0) (Using EDID
(**) NVIDIA(0): frequencies has been enabled on all display devices.)
(II) NVIDIA(0): Validated MetaModes:
(II) NVIDIA(0): "DFP-0:nvidia-auto-select"
(II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
(--) NVIDIA(0): DPI set to (128, 130); computed from "UseEdidDpi" X config
Xorg.conf: http://pastebin.com/pKf8t0id
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "intel"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Section "Device"
Identifier "intel"
Driver "intel"
BusID "PCI:00:02:0"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:01:00:0"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
SubSection "Display"
Modes "nvidia-auto-select"
EndSubSection
EndSection
.Xsession: http://pastebin.com/eJYmGJkP
xrandr --setprovideroutputsource intel NVIDIA-0
#xrandr --output DFP-0 --off
#xrandr --output HDMI-0 --off
xrandr --auto
