I recently updated to 346.16.
Since then the display connected to my docking station no longer works. I have a configuration where a display is connected via VGA (needed for the vconsole) and DVI to a docking station. The display used to be recognized as DP-1 and the internal display as LVDS-0.
When I now connect the laptop to the docking station, I have 4 displays turning up, but none of them is the external monitor. When I enable it manually via xrandr it works, however, it flickers every ~2 seconds.
Attached is the nvidia bug report.
Edit: or maybe not, since the forum, as usual, hangs at “scanning” and doesn’t let me upload it neither plain nor .tar.gz. Ah well: http://pastebin.com/ktHefxJF
As comparison: this is the xrandr output when I downgrade to 343.22, which works:
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
VGA-0 connected (normal left inverted right x axis y axis)
1920x1080 60.00 +
1680x1050 59.95
1600x1200 60.00
1440x900 74.98 59.89
1280x1024 75.02 60.02
1280x960 60.00
1280x800 59.81
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
640x480 75.00 72.81 59.94
LVDS-0 connected primary 1600x900+0+0 (normal left inverted right x axis y axis) 309mm x 174mm
1600x900 60.01*+ 40.00
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 60.00*+ 50.00
1680x1050 59.95
1600x1200 60.00
1280x960 60.00
1280x800 59.81
1280x720 60.00 50.00
1152x864 75.00
720x576 50.00
720x480 59.94
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
Also with this driver nvidia-settings sees the monitors with names,
With 346.16 they are just CRT-0, DFP-1, DFP-2, DFP-3
Thanks in advance for looking into this.
Kind regards,
Foxie
nvidia-bug-report.log.tar.gz (54.2 KB)
