35.3.1, how to massflash into Orin Nano
Hi JackyChen,
what you done confused me.
if you flash Orin nano, why create mfi on Orin AGX instead of Orin NX carrier board?
please try all the steps on carrier board you want to flash.
let us try again, please test based on your Orin nano carrier board.
commands below have verified on third-party Orin NX carrier board.
just modify board.conf name. and try again.
1)create mfi
sudo ./tools/backup_restore/l4t_backup_restore.sh -b -c p3509-a02+p3767-0000
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --use-backup-image --no-flash --external-device nvme0n1p1 -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg” -c ./tools/kernel_flash/flash_l4t_external.xml --massflash 5 --showlogs --network usb0 p3509-a02+p3767-0000 nvme0n1p1
2) flash
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --network usb0 --massflash 5 --showlogs
if failed ,upload mfi log and flash log, of course ,rcm should correct first.
@Jeffli Hi,
  1. Because I use orin agx as my server.
  2. the log of command
#create mfi
sudo ./tools/backup_restore/l4t_backup_restore.sh -b -c jetson-orin-nano-devkit-nvme
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --use-backup-image --no-flash --external-device nvme0n1p1 -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg" -c ./tools/kernel_flash/flash_l4t_external.xml --massflash 5 --showlogs --network usb0 jetson-orin-nano-devkit-nvme nvme0n1p1
jeff_ops_on_agx.log (207.0 KB)
  1. the log of command
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --network usb0 --massflash 1 --showlogs
jeff_ops_flash_on_x86_host.log (7.0 KB)
and the Orin Nano devkit serial output log
Orin-Nano-flash-usb-timeout-serial-output.log (4.2 KB)
@Jeffli Hi,
That’s how I did it before
  1. ssh login to Orin agx Server(Orin agx software version is 35.2.1)
  2. release SDK 35.3.1 and prepare the environment on Orin agx Server
tar xpf Jetson_Linux_R35.3.1_aarch64.tbz2
sudo tar xpf Tegra_Linux_Sample-Root-Filesystem_R35.3.1_aarch64.tbz2 # run in path Linux_for_Tegra/rootfs/
sudo ./tools/l4t_flash_prerequisites.sh
sudo ./apply_binaries.sh
  1. Generate mfi package
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --external-device nvme0n1p1 -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg" -c ./tools/kernel_flash/flash_l4t_external.xml --massflash 5 --showlogs --network usb0 jetson-orin-nano-devkit-nvme nvme0n1p1
  1. cp the mfi package to x86 host(ubuntu22.04)
scp mfi_jetson-orin-nano-devkit-nvme.tar.gz  $x86_host_IP
  1. ssh login to x86 host and release mfi package
tar zxvf mfi_jetson-orin-nano-devkit-nvme.tar.gz
  1. flash
PS:
The reason we used orin agx as the server was that we could preinstall nvidia-jetpack into the Linux_for_Tegra/rootfs file system via chroot
Hi JackyChen,
have you ever tried that use x86 host 20.04 to create mfi directly, then flash?
if NOT, could you try it?
@Jeffli Today I tried using the x86 host ubuntu20.04 and encountered the same error, with the same error log.
Hi JackyChen,
you mean mfi ok, flash failed with usb timeout?
@Jeffli Yes
Finially, we use command for generating mfi and there were no errors during the flashing process.
sudo BOARDID=3767 BOARDSKU=0003 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --external-device nvme0n1p1 -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg" -c ./tools/kernel_flash/flash_l4t_external.xml --massflash 5 --showlogs --network usb0 p3768-0000+p3767-0000 nvme0n1p1
or
sudo BOARDID=3767 BOARDSKU=0003 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --external-device nvme0n1p1 -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg" -c ./tools/kernel_flash/flash_l4t_external.xml --massflash 5 --showlogs --network usb0 jetson-orin-nano-devkit-nvme nvme0n1p1
Hi JackyChen,
good news. summary here to help more uses who try to mass flash Orin nano with 35.3.1
1)mfi
sudo ./tools/backup_restore/l4t_backup_restore.sh -b -c p3768-0000+p3767-0000
sudo BOARDID=3767 BOARDSKU=0003 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --external-device nvme0n1p1 -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg” -c ./tools/kernel_flash/flash_l4t_external.xml --massflash 5 --showlogs --network usb0 p3768-0000+p3767-0000 nvme0n1p1
2)flash
