Hi, I use the argument --massflash to generate *.tar.gz that can be flashed to the device.
I found this tar.gz file includes rootfs folder in 35.3.1; however the file created by 35.2.1 doesn’t have rootfs folder.
Is there any way to have the tar.gz file that doesn’t have rootfs folder in 35.3.1?
If it is necessary to have rootfs folder, is there any way to reduce the size of the tar.gz file?
the rootfs is necessary for the board to be flashed.
Do you mean the mfi package too large for you in R35.3.1?
What’s current size and what’s your desired size?
Hi Kevin,
We use Orin NX 16GB SOM with Xavier NX Devkit(NVMe).
In 35.3.1, the tar.gz file is around 4.5GB. In 35.2.1, the tar.gz file is around 2.42GB.
There is a huge size difference between 35.3.1 and 35.2.1.
Therefore, we are wondering that is there any way to reduce the size of the tar.gz file?
Do you run the same command to generate mfi package?
Could you help to provide the detailed steps and command you use to generate the package(.tar.gz)?
It seems 4.x GB is the expected size of mfi package for Orin NX.
Sorry, we don’t have related method to minimize the size of mfi package.
May I know what’s the purpose or use case for you to get lower size of mfi package?
Hi Kevin,
Currently, we do not have any use case for us to get lower size of mfi package.
We just see that difference between 35.2.1 and 35.3.1, and are interested in why the 35.3.1 package is much larger than that of 35.2.1.
If possible, may we know the reason?
