[36.3] Terminal input delay
Hi all,
When utilizing version 36.3, I’ve encountered an issue where the terminal experiences input delays after being used for a certain period. Sometimes occurs this issue after the Terminal prints a large amount of information, such as print dmesg several times.
Is any one saw this issue?
There is another post reporting this. We notice this.
Please help me do a test. If you run sudo jetson_clocks, will you still observe this issue?
Hi @WayneWWW,
After I run jetson_clocks, this issue no longer occurred. But it will come back after reboot. Is there a way to permanently set the state of jetson_clocks? Or do I have to execute it every time I boot to resolve this issue?
Hello, is there a better solution to this problem now?
$ sudo apt-get update
$ sudo apt-get install --no-install-recommends mutter-common libmutter-10-0 gir1.2-mutter-10
This would resolve this problem.
