364.12 - GTX 580 - weston-subsurfaces dumps core
when trying to run weston-subsurfaces it prints out the following assertion to stdout.
PID: 1078 (weston-subsurfa)
           UID: 1000 (tim)
           GID: 1000 (tim)
        Signal: 6 (ABRT)
     Timestamp: Do 2016-03-24 15:19:39 CET (15min ago)
  Command Line: weston-subsurfaces
    Executable: /usr/bin/weston-subsurfaces
 Control Group: /user.slice/user-1000.slice/session-c1.scope
          Unit: session-c1.scope
         Slice: user-1000.slice
       Session: c1
     Owner UID: 1000 (tim)
       Boot ID: 06090d460e324d4b850365284ef9c91f
    Machine ID: d9e6d0c3bf8941169fe80ed0c0d14717
      Hostname: archlinux
      Coredump: /var/lib/systemd/coredump/core.weston-subsurfa.1000.06090d460e324d4b850365284ef9c91f.1078.1458829179000000000000.lz4
       Message: Process 1078 (weston-subsurfa) of user 1000 dumped core.
                Stack trace of thread 1078:
                #0  0x00007fedac4d72a8 raise (libc.so.6)
                #1  0x00007fedac4d872a abort (libc.so.6)
                #2  0x00007fedac4d01b7 __assert_fail_base (libc.so.6)
                #3  0x00007fedac4d0262 __assert_fail (libc.so.6)
                #4  0x0000000000406bfb n/a (weston-subsurfaces)
                #5  0x0000000000407148 n/a (weston-subsurfaces)
                #6  0x000000000040c194 n/a (weston-subsurfaces)
                #7  0x000000000040c298 n/a (weston-subsurfaces)
                #8  0x000000000040c5a4 n/a (weston-subsurfaces)
                #9  0x000000000040e544 n/a (weston-subsurfaces)
                #10 0x00000000004060e0 n/a (weston-subsurfaces)
                #11 0x00007fedac4c4710 __libc_start_main (libc.so.6)
                #12 0x00000000004064b9 n/a (weston-subsurfaces)
                Stack trace of thread 1081:
                #0  0x00007fedac58cb5f recv (libc.so.6)
                #1  0x00007feda6fcb613 n/a (libEGL_nvidia.so.0)
                #2  0x00007feda6fd93be n/a (libEGL_nvidia.so.0)
                #3  0x00007fedac28e424 start_thread (libpthread.so.0)
                #4  0x00007fedac58bcbd __clone (libc.so.6)
                Stack trace of thread 1079:
                #1  0x00007feda6fcbc62 n/a (libEGL_nvidia.so.0)
GNU gdb (GDB) 7.11
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /usr/bin/weston-subsurfaces...(no debugging symbols found)...done.
warning: core file may not match specified executable file.
[New LWP 1078]
[New LWP 1081]
[New LWP 1079]
warning: Could not load shared library symbols for linux-vdso.so.1.
Do you need "set solib-search-path" or "set sysroot"?
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
Core was generated by `weston-subsurfaces'.
Program terminated with signal SIGABRT, Aborted.
#0  0x00007fedac4d72a8 in raise () from /usr/lib/libc.so.6
[Current thread is 1 (Thread 0x7fedae85d8c0 (LWP 1078))]
