I recently upgraded to 370.23, because 367 does not compile the modules correctly under kernel 4.7.2
When starting gdm, the driver crashes with:
Backtrace:
0: /usr/bin/Xorg (xorg_backtrace+0x56) [0x58b4b6]
1: /usr/bin/Xorg (0x400000+0x18f739) [0x58f739]
2: /lib64/libc.so.6 (0x7f6f7105a000+0x33270) [0x7f6f7108d270]
3: /usr/bin/Xorg (xf86nameCompare+0x74) [0x4a36f4]
4: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f6f6b725000+0x99c0c) [0x7f6f6b7bec0c]
5: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f6f6b725000+0x913fc) [0x7f6f6b7b63fc]
6: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f6f6b725000+0x950ce) [0x7f6f6b7ba0ce]
7: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f6f6b725000+0x5a7adc) [0x7f6f6bcccadc]
Segmentation fault at address 0x0
When running Xorg manually, all my 4 displays work as expected. Only when running X trough gdm, the driver crashes.
Could someone please help me to figure out whats wrong?
Her’s the full log an my system config:
Sep 21 17:20:46 morlj020 systemd[1]: Starting GNOME Display Manager...
Sep 21 17:20:46 morlj020 systemd[1]: Started GNOME Display Manager.
Sep 21 17:20:46 morlj020 polkitd[858]: Unregistered Authentication Agent for unix-process:852:55666 (system bus name :1.7, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ) (disconnected from bus)
Sep 21 17:20:46 morlj020 dbus-daemon[500]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service'
Sep 21 17:20:46 morlj020 systemd[1]: Reached target User and Group Name Lookups.
Sep 21 17:20:46 morlj020 systemd[1]: Starting Accounts Service...
Sep 21 17:20:46 morlj020 accounts-daemon[870]: started daemon version 0.6.40
Sep 21 17:20:46 morlj020 dbus-daemon[500]: [system] Successfully activated service 'org.freedesktop.Accounts'
Sep 21 17:20:46 morlj020 systemd[1]: Started Accounts Service.
Sep 21 17:20:46 morlj020 gdm-session-wor[874]: pam_systemd(gdm-launch-environment:session): Unknown parameter 'kill-session-processes=1', ignoring
Sep 21 17:20:46 morlj020 systemd[1]: Created slice user-115.slice.
Sep 21 17:20:46 morlj020 systemd[1]: Starting User Manager for UID 115...
Sep 21 17:20:46 morlj020 systemd-logind[509]: New session c1 of user gdm.
Sep 21 17:20:46 morlj020 systemd[1]: Started Session c1 of user gdm.
Sep 21 17:20:46 morlj020 (systemd)[878]: pam_unix(systemd-user:session): session opened for user gdm by (uid=0)
Sep 21 17:20:46 morlj020 systemd[878]: Reached target Sockets.
Sep 21 17:20:46 morlj020 systemd[878]: Reached target Paths.
Sep 21 17:20:46 morlj020 systemd[878]: Removed slice Root Slice.
Sep 21 17:20:46 morlj020 systemd[878]: Reached target Timers.
Sep 21 17:20:46 morlj020 systemd[878]: Reached target Basic System.
Sep 21 17:20:46 morlj020 systemd[878]: Reached target Default.
Sep 21 17:20:46 morlj020 systemd[878]: Startup finished in 8ms.
Sep 21 17:20:46 morlj020 systemd[1]: Started User Manager for UID 115.
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (--) Log file renamed from "/var/log/Xorg.pid-884.log" to "/var/log/Xorg.0.log"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: X.Org X Server 1.18.4
Sep 21 17:20:46 morlj020 gdm-x-session[882]: Release Date: 2016-07-19
Sep 21 17:20:46 morlj020 gdm-x-session[882]: X Protocol Version 11, Revision 0
Sep 21 17:20:46 morlj020 gdm-x-session[882]: Build Operating System: Linux 4.7.2-gentoo x86_64 Gentoo
Sep 21 17:20:46 morlj020 gdm-x-session[882]: Current Operating System: Linux MORLJ020 4.7.2-gentoo #4 SMP Wed Sep 21 10:57:10 CEST 2016 x86_64
Sep 21 17:20:46 morlj020 gdm-x-session[882]: Kernel command line: BOOT_IMAGE=/vmlinuz-4.7.2-gentoo root=/dev/sda3 ro init=/usr/lib/systemd/systemd
Sep 21 17:20:46 morlj020 gdm-x-session[882]: Build Date: 20 September 2016 06:13:08PM
Sep 21 17:20:46 morlj020 gdm-x-session[882]: Current version of pixman: 0.34.0
Sep 21 17:20:46 morlj020 gdm-x-session[882]: Before reporting problems, check http://wiki.x.org
Sep 21 17:20:46 morlj020 gdm-x-session[882]: to make sure that you have the latest version.
Sep 21 17:20:46 morlj020 gdm-x-session[882]: Markers: (--) probed, (**) from config file, (==) default setting,
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (++) from command line, (!!) notice, (II) informational,
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) Log file: "/var/log/Xorg.0.log", Time: Wed Sep 21 17:20:46 2016
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) ServerLayout "Layout0"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) |-->Screen "Screen0" (0)
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) | |-->Monitor "Monitor0"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) | |-->Device "Device0"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) |-->Input Device "Keyboard0"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) |-->Input Device "Mouse0"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) Option "Xinerama" "0"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) Automatically adding devices
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) Automatically enabling devices
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) Automatically adding GPU devices
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) Max clients allowed: 256, resource mask: 0x1fffff
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) FontPath set to:
Sep 21 17:20:46 morlj020 gdm-x-session[882]: /usr/share/fonts/misc/,
Sep 21 17:20:46 morlj020 gdm-x-session[882]: /usr/share/fonts/TTF/,
Sep 21 17:20:46 morlj020 gdm-x-session[882]: /usr/share/fonts/OTF/,
Sep 21 17:20:46 morlj020 gdm-x-session[882]: /usr/share/fonts/Type1/,
Sep 21 17:20:46 morlj020 gdm-x-session[882]: /usr/share/fonts/100dpi/,
Sep 21 17:20:46 morlj020 gdm-x-session[882]: /usr/share/fonts/75dpi/
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) ModulePath set to "/usr/lib64/xorg/modules"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (WW) Disabling Keyboard0
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (WW) Disabling Mouse0
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Loader magic: 0x813d00
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Module ABI versions:
Sep 21 17:20:46 morlj020 gdm-x-session[882]: X.Org ANSI C Emulation: 0.4
Sep 21 17:20:46 morlj020 gdm-x-session[882]: X.Org Video Driver: 20.0
Sep 21 17:20:46 morlj020 gdm-x-session[882]: X.Org XInput driver : 22.1
Sep 21 17:20:46 morlj020 gdm-x-session[882]: X.Org Server Extension : 9.0
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (++) using VT number 7
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) xfree86: Adding drm device (/dev/dri/card0)
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 8 paused 0
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) xfree86: Adding drm device (/dev/dri/card1)
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 9 paused 0
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (--) PCI: (0:4:0:0) 10de:0ffa:103c:094b rev 161, Mem @ 0xee000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (--) PCI:*(0:5:0:0) 10de:0ffa:103c:094b rev 161, Mem @ 0xec000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x0000c000/128, BIOS @ 0x????????/131072
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) LoadModule: "glx"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Module glx: vendor="NVIDIA Corporation"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: compiled for 4.0.2, module version = 1.0.0
Sep 21 17:20:46 morlj020 gdm-x-session[882]: Module class: X.Org Server Extension
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) NVIDIA GLX Module 370.23 Mon Aug 8 17:25:10 PDT 2016
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) LoadModule: "nvidia"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Module nvidia: vendor="NVIDIA Corporation"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: Module class: X.Org Video Driver
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) NVIDIA dlloader X Driver 370.23 Mon Aug 8 17:02:18 PDT 2016
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) systemd-logind: releasing fd for 226:0
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) systemd-logind: releasing fd for 226:1
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Loading sub module "fb"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) LoadModule: "fb"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Loading /usr/lib64/xorg/modules/libfb.so
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Module fb: vendor="X.Org Foundation"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: compiled for 1.18.4, module version = 1.0.0
Sep 21 17:20:46 morlj020 gdm-x-session[882]: ABI class: X.Org ANSI C Emulation, version 0.4
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Loading sub module "wfb"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) LoadModule: "wfb"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Loading /usr/lib64/xorg/modules/libwfb.so
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Module wfb: vendor="X.Org Foundation"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Loading sub module "ramdac"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) LoadModule: "ramdac"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (II) Module "ramdac" already built-in
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) NVIDIA(0): RGB weight 888
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) NVIDIA(0): Default visual is TrueColor
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) NVIDIA(0): Option "Stereo" "0"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) NVIDIA(0): Option "SLI" "off"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) NVIDIA(0): Option "MultiGPU" "Off"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) NVIDIA(0): Option "BaseMosaic" "on"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) NVIDIA(0): Stereo disabled by request
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) NVIDIA(0): NVIDIA SLI disabled.
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) NVIDIA(0): Option "MetaModes" "GPU-1.DVI-I-1: nvidia-auto-select +0+0, GPU-0.DVI-I-1: nvidia-auto-select +1920+0, GPU-0.DP-1: nvidia-auto-select +3840+0, GPU-1.DP-1: nvidia-auto-select +5760+0"
Sep 21 17:20:46 morlj020 gdm-x-session[882]: (**) NVIDIA(0): Enabling 2D acceleration
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (II) NVIDIA(GPU-0): NVIDIA Base Mosaic enabled.
Sep 21 17:20:47 morlj020 kernel: nvidia-modeset: Allocated GPU:0 (GPU-88f42d73-d727-235f-61f1-88fe62f90523) @ PCI:0000:05:00.0
Sep 21 17:20:47 morlj020 kernel: nvidia-modeset: Allocated GPU:1 (GPU-bfe35ad2-a2ff-331e-205a-29a111830183) @ PCI:0000:04:00.0
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:5:0:0
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): CRT-0
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DFP-0 (boot)
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DFP-1
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DFP-2
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): Valid display device(s) on GPU-1 at PCI:4:0:0
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): CRT-0: disconnected
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2410 (DFP-0): connected
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2410 (DFP-0): Internal TMDS
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2410 (DFP-0): 330.0 MHz maximum pixel clock
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DFP-1: disconnected
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DFP-1: Internal TMDS
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2414H (DFP-2): connected
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2414H (DFP-2): Internal DisplayPort
Sep 21 17:20:47 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2414H (DFP-2): 960.0 MHz maximum pixel clock
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2410 (DFP-0): connected
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2410 (DFP-0): Internal TMDS
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2410 (DFP-0): 330.0 MHz maximum pixel clock
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DFP-1: disconnected
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DFP-1: Internal TMDS
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2414H (DFP-2): connected
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2414H (DFP-2): Internal DisplayPort
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DELL U2414H (DFP-2): 960.0 MHz maximum pixel clock
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): NVIDIA GPU Quadro K600 (GK107GL) at PCI:5:0:0 (GPU-0)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): Memory: 1048576 kBytes
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): VideoBIOS: 80.07.c5.00.0c
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): Detected PCI Express Link width: 16X
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): NVIDIA GPU Quadro K600 (GK107GL) at PCI:4:0:0 (GPU-1)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) NVIDIA(0): device DELL U2410 (DFP-0) (Using EDID frequencies has been
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) NVIDIA(0): enabled on all display devices.)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) NVIDIA(0): device DELL U2414H (DFP-2) (Using EDID frequencies has
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) NVIDIA(0): been enabled on all display devices.)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): Validated MetaModes:
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): "GPU-1.DVI-I-1:nvidia-auto-select+0+0,GPU-0.DVI-I-1:nvidia-auto-select+1920+0,GPU-0.DP-1:nvidia-auto-select+3840+0,GPU-1.DP-1:nvidia-auto-select+5760+0"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): Virtual screen size determined to be 7680 x 1200
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): DPI set to (93, 95); computed from "UseEdidDpi" X config
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(0): option
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) Depth 24 pixmap format is 32 bpp
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA: Using 12288.00 MB of virtual memory for indirect memory
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA: access.
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): configuration option may not be set correctly. When the
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): Config Options in the README.
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): Setting mode "GPU-1.DVI-I-1:nvidia-auto-select+0+0,GPU-0.DVI-I-1:nvidia-auto-select+1920+0,GPU-0.DP-1:nvidia-auto-select+3840+0,GPU-1.DP-1:nvidia-auto-select+5760+0"
Sep 21 17:20:48 morlj020 kernel: snd_hda_codec_hdmi hdaudioC1D0: HDMI: invalid ELD data byte 29
Sep 21 17:20:48 morlj020 kernel: snd_hda_codec_hdmi hdaudioC2D0: HDMI: invalid ELD data byte 34
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (==) NVIDIA(0): Disabling shared memory pixmaps
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (==) NVIDIA(0): Backing store enabled
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (==) NVIDIA(0): Silken mouse enabled
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) NVIDIA(0): DPMS enabled
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) Loading sub module "dri2"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) LoadModule: "dri2"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) Module "dri2" already built-in
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): [DRI2] Setup complete
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) RandR disabled
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) Initializing extension GLX
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) Indirect GLX disabled.
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device Power Button (/dev/input/event1)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Power Button: Applying InputClass "evdev keyboard catchall"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Power Button: Applying InputClass "system-keyboard"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) LoadModule: "evdev"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) Module evdev: vendor="X.Org Foundation"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: compiled for 1.18.4, module version = 2.10.3
Sep 21 17:20:48 morlj020 gdm-x-session[882]: Module class: X.Org XInput Driver
Sep 21 17:20:48 morlj020 gdm-x-session[882]: ABI class: X.Org XInput driver, version 22.1
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 34 paused 0
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) Using input driver 'evdev' for 'Power Button'
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Power Button: always reports core events
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) evdev: Power Button: Device: "/dev/input/event1"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) evdev: Power Button: Vendor 0 Product 0x1
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) evdev: Power Button: Found keys
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) evdev: Power Button: Configuring as keyboard
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Option "xkb_rules" "evdev"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Option "xkb_model" "pc105"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Option "xkb_layout" "de"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device Power Button (/dev/input/event0)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 35 paused 0
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) evdev: Power Button: Device: "/dev/input/event0"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) No input driver specified, ignoring this device.
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) This device may have been added with another device file.
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event12)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 36 paused 0
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) Using input driver 'evdev' for 'Logitech USB Receiver'
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Logitech USB Receiver: always reports core events
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) evdev: Logitech USB Receiver: Device: "/dev/input/event12"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc52b
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) evdev: Logitech USB Receiver: Found keys
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) evdev: Logitech USB Receiver: Configuring as keyboard
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C52B.0001/input/input15/event12"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 8)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event14)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 37 paused 0
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) evdev: Logitech USB Receiver: Device: "/dev/input/event14"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) evdev: Logitech USB Receiver: Found 20 mouse buttons
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) evdev: Logitech USB Receiver: Found scroll wheel(s)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) evdev: Logitech USB Receiver: Found relative axes
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) evdev: Logitech USB Receiver: Found x and y relative axes
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) evdev: Logitech USB Receiver: Found absolute axes
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) evdev: Logitech USB Receiver: Forcing absolute x/y axes to exist.
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) evdev: Logitech USB Receiver: Configuring as mouse
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) evdev: Logitech USB Receiver: Adding scrollwheel support
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) evdev: Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C52B.0003/input/input17/event14"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 9)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) evdev: Logitech USB Receiver: initialized for relative axes.
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (WW) evdev: Logitech USB Receiver: ignoring absolute axes.
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Logitech USB Receiver: (accel) acceleration profile 0
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Logitech USB Receiver: (accel) acceleration threshold: 4
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event7)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event2)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event3)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event4)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event5)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event6)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device daskeyboard (/dev/input/event13)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) daskeyboard: Applying InputClass "evdev keyboard catchall"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) daskeyboard: Applying InputClass "system-keyboard"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 38 paused 0
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) Using input driver 'evdev' for 'daskeyboard'
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) daskeyboard: always reports core events
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) evdev: daskeyboard: Device: "/dev/input/event13"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) evdev: daskeyboard: Vendor 0x4d9 Product 0x2013
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) evdev: daskeyboard: Found keys
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) evdev: daskeyboard: Configuring as keyboard
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/0003:04D9:2013.0002/input/input16/event13"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) XINPUT: Adding extended input device "daskeyboard" (type: KEYBOARD, id 10)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) config/udev: Adding input device daskeyboard (/dev/input/event15)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 39 paused 0
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) evdev: daskeyboard: Device: "/dev/input/event15"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:04D9:2013.0004/input/input18/event15"
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (II) XINPUT: Adding extended input device "daskeyboard" (type: KEYBOARD, id 11)
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-0): DELL U2414H (DFP-2): connected
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-0): DELL U2414H (DFP-2): Internal DisplayPort
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-0): DELL U2414H (DFP-2): 960.0 MHz maximum pixel clock
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-1): DELL U2414H (DFP-2): connected
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-1): DELL U2414H (DFP-2): Internal DisplayPort
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-1): DELL U2414H (DFP-2): 960.0 MHz maximum pixel clock
Sep 21 17:20:48 morlj020 gdm-x-session[882]: Activating service name='org.a11y.Bus'
Sep 21 17:20:48 morlj020 gdm-x-session[882]: Successfully activated service 'org.a11y.Bus'
Sep 21 17:20:48 morlj020 dbus-daemon[896]: Activating service name='org.a11y.atspi.Registry'
Sep 21 17:20:48 morlj020 dbus-daemon[896]: Successfully activated service 'org.a11y.atspi.Registry'
Sep 21 17:20:48 morlj020 dbus-daemon[908]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Sep 21 17:20:48 morlj020 dbus-daemon[500]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service'
Sep 21 17:20:48 morlj020 systemd[1]: Starting Daemon for power management...
Sep 21 17:20:48 morlj020 dbus-daemon[500]: [system] Successfully activated service 'org.freedesktop.UPower'
Sep 21 17:20:48 morlj020 systemd[1]: Started Daemon for power management.
Sep 21 17:20:48 morlj020 gdm-x-session[882]: Activating service name='org.gtk.vfs.Daemon'
Sep 21 17:20:48 morlj020 gdm-x-session[882]: Successfully activated service 'org.gtk.vfs.Daemon'
Sep 21 17:20:48 morlj020 gnome-session-b[898]: Entering running state
Sep 21 17:20:48 morlj020 dbus-daemon[500]: [system] Activating via systemd: service name='org.freedesktop.ColorManager' unit='colord.service'
Sep 21 17:20:48 morlj020 systemd[1]: Starting Manage, Install and Generate Color Profiles...
Sep 21 17:20:48 morlj020 dbus-daemon[500]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service'
Sep 21 17:20:48 morlj020 dbus-daemon[500]: [system] Successfully activated service 'org.freedesktop.ColorManager'
Sep 21 17:20:48 morlj020 systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Sep 21 17:20:48 morlj020 systemd[1]: Started Manage, Install and Generate Color Profiles.
Sep 21 17:20:48 morlj020 dbus-daemon[500]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Sep 21 17:20:48 morlj020 systemd[1]: Started RealtimeKit Scheduling Policy Service.
Sep 21 17:20:48 morlj020 rtkit-daemon[989]: Successfully called chroot.
Sep 21 17:20:48 morlj020 rtkit-daemon[989]: Successfully dropped privileges.
Sep 21 17:20:48 morlj020 rtkit-daemon[989]: Successfully limited resources.
Sep 21 17:20:48 morlj020 rtkit-daemon[989]: Running.
Sep 21 17:20:48 morlj020 rtkit-daemon[989]: Watchdog thread running.
Sep 21 17:20:48 morlj020 rtkit-daemon[989]: Canary thread running.
Sep 21 17:20:48 morlj020 rtkit-daemon[989]: Successfully made thread 985 of process 985 (/usr/bin/pulseaudio) owned by '115' high priority at nice level -11.
Sep 21 17:20:48 morlj020 rtkit-daemon[989]: Supervising 1 threads of 1 processes of 1 users.
Sep 21 17:20:48 morlj020 pulseaudio[985]: [pulseaudio] main.c: Compiled with DEPRECATED libsamplerate support!
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-0): CRT-0: disconnected
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-0): DELL U2410 (DFP-0): connected
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-0): DELL U2410 (DFP-0): Internal TMDS
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-0): DELL U2410 (DFP-0): 330.0 MHz maximum pixel clock
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-1): CRT-0: disconnected
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-1): CRT-0: 400.0 MHz maximum pixel clock
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-1): DELL U2410 (DFP-0): connected
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-1): DELL U2410 (DFP-0): Internal TMDS
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-1): DELL U2410 (DFP-0): 330.0 MHz maximum pixel clock
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-1): DFP-1: disconnected
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-1): DFP-1: Internal TMDS
Sep 21 17:20:48 morlj020 gdm-x-session[882]: (--) NVIDIA(GPU-1): DFP-1: 165.0 MHz maximum pixel clock
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (II) NVIDIA(0): Setting mode "GPU-0.DVI-I-1: nvidia-auto-select @1920x1200 +1920+0 {ViewPortIn=1920x1200, ViewPortOut=1920x1200+0+0}, GPU-0.DP-1: nvidia-auto-select @1920x1080 +3840+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, GPU-1.DP-1: nvidia-auto-select @1920x1080 +3840+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE)
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) Backtrace:
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) 0: /usr/bin/Xorg (xorg_backtrace+0x56) [0x58b4b6]
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) 1: /usr/bin/Xorg (0x400000+0x18f739) [0x58f739]
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) 2: /lib64/libc.so.6 (0x7f6f7105a000+0x33270) [0x7f6f7108d270]
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) 3: /usr/bin/Xorg (xf86nameCompare+0x74) [0x4a36f4]
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) 4: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f6f6b725000+0x99c0c) [0x7f6f6b7bec0c]
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) 5: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f6f6b725000+0x913fc) [0x7f6f6b7b63fc]
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) 6: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f6f6b725000+0x950ce) [0x7f6f6b7ba0ce]
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) 7: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (0x7f6f6b725000+0x5a7adc) [0x7f6f6bcccadc]
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) Segmentation fault at address 0x0
Sep 21 17:20:49 morlj020 gdm-x-session[882]: Fatal server error:
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) Caught signal 11 (Segmentation fault). Server aborting
Sep 21 17:20:49 morlj020 gdm-x-session[882]: Please consult the The X.Org Foundation support
Sep 21 17:20:49 morlj020 gdm-x-session[882]: at http://wiki.x.org
Sep 21 17:20:49 morlj020 gdm-x-session[882]: for help.
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Sep 21 17:20:49 morlj020 kernel: snd_hda_codec_hdmi hdaudioC1D0: HDMI: invalid ELD data byte 45
Sep 21 17:20:49 morlj020 kernel: snd_hda_codec_hdmi hdaudioC2D0: HDMI: invalid ELD data byte 40
Sep 21 17:20:49 morlj020 rtkit-daemon[989]: Supervising 1 threads of 1 processes of 1 users.
Sep 21 17:20:49 morlj020 rtkit-daemon[989]: Successfully made thread 995 of process 985 (/usr/bin/pulseaudio) owned by '115' RT at priority 5.
Sep 21 17:20:49 morlj020 rtkit-daemon[989]: Supervising 2 threads of 1 processes of 1 users.
Sep 21 17:20:49 morlj020 gdm-x-session[882]: (EE) Server terminated with error (1). Closing log file.
Sep 21 17:20:49 morlj020 gnome-session-b[898]: XIO: fatal IO error 11 (Die Ressource ist zur Zeit nicht verfügbar) on X server ":0"
Sep 21 17:20:49 morlj020 gnome-session-b[898]: after 249 requests (249 known processed) with 9 events remaining.
Sep 21 17:20:49 morlj020 kernel: Xorg (884) used greatest stack depth: 10416 bytes left
Sep 21 17:20:49 morlj020 dbus-daemon[896]: A connection to the bus can't be made
Sep 21 17:20:49 morlj020 gnome-session-b[898]: WARNING: Lost name on bus: org.gnome.SessionManager
Sep 21 17:20:49 morlj020 gnome-session-b[898]: gnome-session-binary[898]: WARNING: Lost name on bus: org.gnome.SessionManager
Sep 21 17:20:49 morlj020 gdm[867]: Child process 874 was already dead.
Sep 21 17:20:49 morlj020 gdm[867]: Unable to kill session worker process
Sep 21 17:20:49 morlj020 gdm-session-wor[998]: pam_systemd(gdm-launch-environment:session): Unknown parameter 'kill-session-processes=1', ignoring
Sep 21 17:20:49 morlj020 systemd-logind[509]: New session c2 of user gdm.
Sep 21 17:20:49 morlj020 kernel: nvidia-modeset: Freed GPU:0 (GPU-88f42d73-d727-235f-61f1-88fe62f90523) @ PCI:0000:05:00.0
Sep 21 17:20:49 morlj020 kernel: nvidia-modeset: Freed GPU:1 (GPU-bfe35ad2-a2ff-331e-205a-29a111830183) @ PCI:0000:04:00.0
Sep 21 17:20:49 morlj020 pulseaudio[985]: [pulseaudio] module-alsa-card.c: Failed to open mixer for jack detection
Sep 21 17:20:49 morlj020 systemd[1]: Started Session c2 of user gdm.
Sep 21 17:20:49 morlj020 dbus-daemon[500]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service'
Sep 21 17:20:49 morlj020 pulseaudio[985]: [pulseaudio] main.c: Failed to acquire org.PulseAudio1: org.freedesktop.DBus.Error.Disconnected: Connection is closed
Sep 21 17:20:49 morlj020 dbus-daemon[500]: [system] Activation via systemd failed for unit 'dbus-org.bluez.service': Unit dbus-org.bluez.service failed to load: No such file or directory.
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (--) Log file renamed from "/var/log/Xorg.pid-1006.log" to "/var/log/Xorg.0.log"
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: X.Org X Server 1.18.4
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: Release Date: 2016-07-19
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: X Protocol Version 11, Revision 0
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: Build Operating System: Linux 4.7.2-gentoo x86_64 Gentoo
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: Current Operating System: Linux MORLJ020 4.7.2-gentoo #4 SMP Wed Sep 21 10:57:10 CEST 2016 x86_64
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: Kernel command line: BOOT_IMAGE=/vmlinuz-4.7.2-gentoo root=/dev/sda3 ro init=/usr/lib/systemd/systemd
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: Build Date: 20 September 2016 06:13:08PM
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: Current version of pixman: 0.34.0
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: Before reporting problems, check http://wiki.x.org
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: to make sure that you have the latest version.
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: Markers: (--) probed, (**) from config file, (==) default setting,
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (++) from command line, (!!) notice, (II) informational,
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (==) Log file: "/var/log/Xorg.0.log", Time: Wed Sep 21 17:20:49 2016
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (==) ServerLayout "Layout0"
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (**) |-->Screen "Screen0" (0)
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (**) | |-->Monitor "Monitor0"
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (**) | |-->Device "Device0"
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (**) |-->Input Device "Keyboard0"
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (**) |-->Input Device "Mouse0"
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (**) Option "Xinerama" "0"
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (==) Automatically adding devices
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (==) Automatically enabling devices
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (==) Automatically adding GPU devices
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (==) Max clients allowed: 256, resource mask: 0x1fffff
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: (==) FontPath set to:
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: /usr/share/fonts/misc/,
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: /usr/share/fonts/TTF/,
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: /usr/share/fonts/OTF/,
Sep 21 17:20:49 morlj020 gdm-x-session[1004]: /usr/share/fonts/Type1/,
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: /usr/share/fonts/100dpi/,
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: /usr/share/fonts/75dpi/
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (==) ModulePath set to "/usr/lib64/xorg/modules"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (WW) Disabling Keyboard0
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (WW) Disabling Mouse0
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Loader magic: 0x813d00
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Module ABI versions:
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: X.Org ANSI C Emulation: 0.4
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: X.Org Video Driver: 20.0
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: X.Org XInput driver : 22.1
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: X.Org Server Extension : 9.0
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (++) using VT number 7
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/c2
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) xfree86: Adding drm device (/dev/dri/card0)
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 8 paused 0
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) xfree86: Adding drm device (/dev/dri/card1)
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 9 paused 0
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (--) PCI: (0:4:0:0) 10de:0ffa:103c:094b rev 161, Mem @ 0xee000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (--) PCI:*(0:5:0:0) 10de:0ffa:103c:094b rev 161, Mem @ 0xec000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x0000c000/128, BIOS @ 0x????????/131072
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) LoadModule: "glx"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Module glx: vendor="NVIDIA Corporation"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: compiled for 4.0.2, module version = 1.0.0
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: Module class: X.Org Server Extension
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) NVIDIA GLX Module 370.23 Mon Aug 8 17:25:10 PDT 2016
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) LoadModule: "nvidia"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Module nvidia: vendor="NVIDIA Corporation"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: Module class: X.Org Video Driver
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) NVIDIA dlloader X Driver 370.23 Mon Aug 8 17:02:18 PDT 2016
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) systemd-logind: releasing fd for 226:0
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) systemd-logind: releasing fd for 226:1
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Loading sub module "fb"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) LoadModule: "fb"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Loading /usr/lib64/xorg/modules/libfb.so
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Module fb: vendor="X.Org Foundation"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: compiled for 1.18.4, module version = 1.0.0
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: ABI class: X.Org ANSI C Emulation, version 0.4
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Loading sub module "wfb"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) LoadModule: "wfb"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Loading /usr/lib64/xorg/modules/libwfb.so
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Module wfb: vendor="X.Org Foundation"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Loading sub module "ramdac"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) LoadModule: "ramdac"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (II) Module "ramdac" already built-in
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (==) NVIDIA(0): RGB weight 888
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (==) NVIDIA(0): Default visual is TrueColor
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (**) NVIDIA(0): Option "Stereo" "0"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (**) NVIDIA(0): Option "SLI" "off"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (**) NVIDIA(0): Option "MultiGPU" "Off"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (**) NVIDIA(0): Option "BaseMosaic" "on"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (**) NVIDIA(0): Stereo disabled by request
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (**) NVIDIA(0): NVIDIA SLI disabled.
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (**) NVIDIA(0): Option "MetaModes" "GPU-1.DVI-I-1: nvidia-auto-select +0+0, GPU-0.DVI-I-1: nvidia-auto-select +1920+0, GPU-0.DP-1: nvidia-auto-select +3840+0, GPU-1.DP-1: nvidia-auto-select +5760+0"
Sep 21 17:20:50 morlj020 gdm-x-session[1004]: (**) NVIDIA(0): Enabling 2D acceleration
lspci
# lspci -v -s 04:00.0
04:00.0 VGA compatible controller: NVIDIA Corporation GK107GL [Quadro K600] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Hewlett-Packard Company GK107GL [Quadro K600]
Flags: bus master, fast devsel, latency 0, IRQ 26, NUMA node 0
Memory at ee000000 (32-bit, non-prefetchable)
Memory at d0000000 (64-bit, prefetchable)
Memory at e0000000 (64-bit, prefetchable)
I/O ports at d000
Expansion ROM at ef000000 [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nvidia
Kernel modules: nvidia_drm, nvidia
# lspci -v -s 05:00.0
05:00.0 VGA compatible controller: NVIDIA Corporation GK107GL [Quadro K600] (rev a1) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 25, NUMA node 0
Memory at ec000000 (32-bit, non-prefetchable)
Memory at b0000000 (64-bit, prefetchable)
Memory at c0000000 (64-bit, prefetchable)
I/O ports at c000
Expansion ROM at 000c0000 [disabled]
config.gz (24.1 KB)
xorg.conf.txt (1.85 KB)
Xorg.successful.run.log (654 KB)
