Run the.Sh file:“sh NVIDIA-Linux-x86_64-390.46.run”
“ERROR: Unable to determine the version of the kernel sources located in ‘/lib/modules/4.14.32-xx/build’. Please make sure you have installed the kernel source files for your kernel and that
they are properly configured; on Red Hat Linux systems, for example, be sure you have the ‘kernel-source’ or ‘kernel-devel’ RPM installed. If you know the correct kernel source files are
installed, you may specify the kernel source path with the ‘–kernel-source-path’ command line option.”
It will also appear the same error when run “sh NVIDIA-Linux-x86_64-390.46.run --kernel-source-path /lib/modules/4.14.32-xx/build”
The kernel.h file can be found
“ls /lib/modules/4.14.32-xx/build/include/linux/ | grep kernel.h”
kernel.h
pps_kernel.h
ptp_clock_kernel.h
start_kernel.h
