3d_action_detection got stuck in Running
• Hardware Platform (Jetson / GPU): Linux - RTX 3060
• DeepStream Version: 6.2
**• TensorRT Version: 8.5.1-1+cuda11.8 **
**• NVIDIA GPU Driver Version (valid for GPU only): 545.23.06 **
• Issue Type( questions, new requirements, bugs): bugs
Hey,
I am trying to use 3d_action_detection on deepstream but I am struggling with errors. I solved most of them in the last one I got stuck. when I run that
deepstream-3d-action-recognition -c deepstream_action_recognition_config.txt
it gives that error.
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
0:00:21.556735051 11735 0x557225815e40 WARN nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:21.556767442 11735 0x557225815e40 WARN nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop: error: streaming stopped, reason not-negotiated (-4)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(2369): gst_nvinfer_output_loop (): /GstPipeline:preprocess-test-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
sequence_image_process.cpp:586, [INFO: CUSTOM_LIB] SequenceImagePreprocess is deinitializing
Deleting pipeline
I searched on the web, I just found a solution but it did not work. It says write
export DISPLAY=:0.0
to console. I wrote that. In that case the code got stuck in running. The produced output is like that:
Now playing: file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_walk.mov, file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_ride_bike.mov, file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_run.mov, file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_push.mov,
Running…
Could you help me? Thanks in advance!
Hi @beratersari0
The solution with export DISPLAY=:0 is for a different issue, the error message in that case looks like this:
No EGL Display
nvbufsurftransform: Could not get EGL display connection
In your case, the internal pipeline is failing during CAPS negotiation, as noted by streaming stopped, reason not-negotiated (-4), but that still doesn’t give us much information on how to solve the issue.
Did you make changes to the deepstream_action_recognition_config.txt, or are you using the original?
If you are using the original input files, try running them with a gst-launch pipeline and enabling GST_DEBUG to provide us with more information.
GST_DEBUG=2 gst-launch-1.0 \
uridecodebin3 uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_walk.mov ! \
fakesink
You can also export the GST_DEBUG level and run the DeepStream app
export GST_DEBUG=2 #WARNING
Since you are using a dGPU and not a Jetson, my guess is that you are missing some decoders or depayloaders for the input files. The logs will provide us with more information on that.
0:00:00.272204197 9037 0x561c9585e610 WARN nvstreammux gstnvstreammux.c:2926:gst_nvstreammux_change_state: warning: Rounding muxer output width to the next multiple of 8: 72
0:00:00.272268697 9037 0x561c9585e610 WARN nvstreammux gstnvstreammux.c:2934:gst_nvstreammux_change_state: warning: Rounding muxer output height to the next multiple of 4: 52
WARNING: …/nvdsinfer/nvdsinfer_model_builder.cpp:1487 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-3d-action-recognition/resnet18_3d_of_hmdb5_32.etlt_b4_gpu0_fp16.engine open error
0:00:01.913351049 9037 0x561c9585e610 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-3d-action-recognition/resnet18_3d_of_hmdb5_32.etlt_b4_gpu0_fp16.engine failed
0:00:01.981673025 9037 0x561c9585e610 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-3d-action-recognition/resnet18_3d_of_hmdb5_32.etlt_b4_gpu0_fp16.engine failed, try rebuild
0:00:01.981689746 9037 0x561c9585e610 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
ERROR: [TRT]: 3: [builder.cpp::~Builder::307] Error Code 3: API Usage Error (Parameter check failed at: optimizer/api/builder.cpp::~Builder::307, condition: mObjectCounter.use_count() == 1. Destroying a builder object before destroying objects it created leads to undefined behavior.
WARNING: [TRT]: onnx2trt_utils.cpp:377: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: TensorRT encountered issues when converting weights between types and that could affect accuracy.
WARNING: [TRT]: If this is not the desired behavior, please modify the weights or retrain with regularization to adjust the magnitude of the weights.
WARNING: [TRT]: Check verbose logs for the list of affected weights.
WARNING: [TRT]: - 21 weights are affected by this issue: Detected subnormal FP16 values.
WARNING: [TRT]: - 20 weights are affected by this issue: Detected values less than smallest positive FP16 subnormal value and converted them to the FP16 minimum subnormalized value.
WARNING: …/nvdsinfer/nvdsinfer_model_builder.cpp:1459 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-3d-action-recognition/resnet18_3d_of_hmdb5_32.etlt_b1_gpu0_fp16.engine opened error
0:00:21.845004575 9037 0x561c9585e610 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1950> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-3d-action-recognition/resnet18_3d_of_hmdb5_32.etlt_b1_gpu0_fp16.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_of 2x32x224x224
1 OUTPUT kFLOAT fc_pred 5
0:00:21.931907256 9037 0x561c9585e610 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:config_infer_primary_3d_action.txt sucessfully
sequence_image_process.cpp:494, [INFO: CUSTOM_LIB] 3D custom sequence network info(NCSHW), [N: 2, C: 3, S: 32, H: 224, W:224]
sequence_image_process.cpp:522, [INFO: CUSTOM_LIB] Sequence preprocess buffer manager initialized with stride: 1, subsample: 0
sequence_image_process.cpp:526, [INFO: CUSTOM_LIB] SequenceImagePreprocess initialized successfully
Using user provided processing height = 224 and processing width = 224
0:00:21.934469420 9037 0x561c9585e610 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete: pad not activated yet
Decodebin child added: source
Decodebin child added: decodebin0
0:00:21.934728573 9037 0x561c9585e610 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete: pad not activated yet
0:00:21.934959513 9037 0x561c9585e610 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete: pad not activated yet
Decodebin child added: decodebin1
0:00:21.935084085 9037 0x561c9585e610 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete: pad not activated yet
0:00:21.935235097 9037 0x561c9585e610 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete: pad not activated yet
Decodebin child added: decodebin2
0:00:21.935391618 9037 0x561c9585e610 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete: pad not activated yet
0:00:21.935527862 9037 0x561c9585e610 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete: pad not activated yet
Decodebin child added: decodebin3
0:00:21.935664727 9037 0x561c9585e610 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete: pad not activated yet
Running…
WARNING from element stream-muxer: Rounding muxer output width to the next multiple of 8: 72
Warning: Rounding muxer output width to the next multiple of 8: 72
WARNING from element stream-muxer: Rounding muxer output height to the next multiple of 4: 52
Warning: Rounding muxer output height to the next multiple of 4: 52
Decodebin child added: qtdemux2
Decodebin child added: qtdemux3
Decodebin child added: qtdemux1
Decodebin child added: qtdemux0
0:00:21.940405071 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.940425789 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type pasp
0:00:21.940441929 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:21.940447650 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:21.940453711 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type text
0:00:21.940457959 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.940466164 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.940472376 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux.c:7810:qtdemux_parse_container: length too long (2184644 > 37)
0:00:21.940477255 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type keys
0:00:21.940511469 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:21.940524724 9037 0x7f3f58023b00 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.940543328 9037 0x7f3f58023b00 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type pasp
0:00:21.940554720 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:21.940559939 9037 0x7f3f58023b00 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:21.940566141 9037 0x7f3f58023b00 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:21.940572633 9037 0x7f3f58023b00 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type text
0:00:21.940579576 9037 0x7f3f58023b00 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.940579255 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux.c:9885:qtdemux_parse_segments: Segment 0 extends to 0:00:09.609633333 past the end of the declared movie duration 0:00:09.609600000 movie segment will be extended
0:00:21.940589434 9037 0x7f3f58023b00 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.940593101 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 3
0:00:21.940597149 9037 0x7f3f58023b00 WARN qtdemux qtdemux.c:7810:qtdemux_parse_container: length too long (2184644 > 37)
0:00:21.940604773 9037 0x7f3f58023b00 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type keys
0:00:21.940632194 9037 0x7f3f58023b00 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:21.940662961 9037 0x7f3f58023b00 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:21.940696033 9037 0x7f3f58023b00 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 3
Decodebin child added: multiqueue0
Decodebin child added: multiqueue1
0:00:21.940896747 9037 0x7f3f60065cc0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.940912787 9037 0x7f3f60065cc0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type pasp
0:00:21.940923096 9037 0x7f3f60065cc0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:21.940930860 9037 0x7f3f60065cc0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:21.940937092 9037 0x7f3f60065cc0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type text
0:00:21.940942763 9037 0x7f3f60065cc0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.940948593 9037 0x7f3f60065cc0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.940955767 9037 0x7f3f60065cc0 WARN qtdemux qtdemux.c:7810:qtdemux_parse_container: length too long (2184644 > 37)
0:00:21.940950307 9037 0x561cb4d201e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.940962469 9037 0x7f3f60065cc0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type keys
0:00:21.940973229 9037 0x561cb4d201e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type pasp
0:00:21.940993046 9037 0x561cb4d201e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sgpd
0:00:21.941001362 9037 0x7f3f60065cc0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:21.941002414 9037 0x561cb4d201e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type sbgp
0:00:21.941016049 9037 0x561cb4d201e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type text
0:00:21.941022481 9037 0x561cb4d201e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.941027691 9037 0x7f3f60065cc0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:21.941032530 9037 0x561cb4d201e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type tmcd
0:00:21.941040034 9037 0x561cb4d201e0 WARN qtdemux qtdemux.c:7810:qtdemux_parse_container: length too long (2184644 > 37)
0:00:21.941046676 9037 0x561cb4d201e0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type keys
0:00:21.941055883 9037 0x7f3f60065cc0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 3
0:00:21.941066724 9037 0x561cb4d201e0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:21.941094195 9037 0x561cb4d201e0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:21.941119652 9037 0x561cb4d201e0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex: failed to find fragment defaults for stream 3
Decodebin child added: multiqueue2
Decodebin child added: multiqueue3
Decodebin child added: h264parse1
Decodebin child added: h264parse0
Decodebin child added: h264parse2
Decodebin child added: capsfilter0
Decodebin child added: capsfilter2
Decodebin child added: capsfilter1
Decodebin child added: h264parse3
Decodebin child added: capsfilter3
Decodebin child added: aacparse0
Decodebin child added: aacparse2
Decodebin child added: aacparse1
Decodebin child added: aacparse3
Decodebin child added: avdec_aac1
Decodebin child added: avdec_aac2
Decodebin child added: avdec_aac3
Decodebin child added: avdec_aac0
Decodebin child added: nvv4l2decoder0
Decodebin child added: nvv4l2decoder1
Decodebin child added: nvv4l2decoder2
Decodebin child added: nvv4l2decoder3
0:00:21.977566076 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977568090 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.977568090 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977589149 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat MJPG
0:00:21.977580213 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
0:00:21.977601693 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977604358 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.977608465 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MJPG
0:00:21.977607493 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977621259 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat MJPG
0:00:21.977625918 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat MJPG
0:00:21.977623734 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977621489 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MJPG
0:00:21.977644422 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977636638 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.977657617 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat AV10
0:00:21.977662296 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.977651626 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MJPG
0:00:21.977639443 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat AV10
0:00:21.977678275 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977633352 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977668036 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat AV10
0:00:21.977686150 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat AV10
0:00:21.977694055 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat MJPG
0:00:21.977693764 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977700276 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977704414 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.977708051 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977714453 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat AV10
0:00:21.977715605 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat AV10
0:00:21.977720223 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat DVX5
0:00:21.977718290 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat AV10
0:00:21.977721897 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977734380 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977741734 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat DVX5
0:00:21.977736384 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat AV10
0:00:21.977751462 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977748456 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977758835 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977761741 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat DVX5
0:00:21.977764827 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat DVX5
0:00:21.977757022 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat DVX5
0:00:21.977770768 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977773783 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977771158 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.977773823 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977782339 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat DVX5
0:00:21.977789993 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat DVX4
0:00:21.977782800 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat DVX5
0:00:21.977782229 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat DVX5
0:00:21.977795574 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977795303 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977810963 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977814579 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat DVX4
0:00:21.977818777 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat DVX4
0:00:21.977809460 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat DVX4
0:00:21.977826061 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977824317 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977827744 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977838063 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat DVX4
0:00:21.977833114 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG4
0:00:21.977847481 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977848593 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977804531 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.977859293 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat MPG4
0:00:21.977854153 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG4
0:00:21.977849605 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat DVX4
0:00:21.977872658 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat DVX4
0:00:21.977878559 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977880592 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.977864863 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977883167 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG4
0:00:21.977892374 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat MPG4
0:00:21.977887625 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat DVX4
0:00:21.977902984 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977906661 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.977908975 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat MPG2
0:00:21.977874952 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977903765 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977917912 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG4
0:00:21.977920376 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977922270 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat MPG4
0:00:21.977927119 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG2
0:00:21.977930485 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.977925396 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977942197 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG2
0:00:21.977937128 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat MPG4
0:00:21.977926147 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat MPG2
0:00:21.977943059 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977946485 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.977962074 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977954781 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.977961844 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG2
0:00:21.977977683 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat H265
0:00:21.977981450 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat MPG2
0:00:21.977982592 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.977984326 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977985678 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG2
0:00:21.978000937 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat H265
0:00:21.977995977 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H265
0:00:21.978010554 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.978011596 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.977990227 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.978023839 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat VP90
0:00:21.978017287 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H265
0:00:21.978017057 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.978025863 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat MPG2
0:00:21.978029380 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.978046872 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.978048525 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat VP90
0:00:21.978037264 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.978037204 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H265
0:00:21.978058023 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.978059886 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat H265
0:00:21.978063844 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.978070246 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat VP80
0:00:21.978073071 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP90
0:00:21.978076137 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.978062491 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H265
0:00:21.978081827 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat VP80
0:00:21.978082438 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.978092948 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.978089311 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.978095773 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat H265
0:00:21.978092778 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.978111272 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.978114087 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat H264
0:00:21.978116963 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat VP90
0:00:21.978120279 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:21.978103197 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP90
0:00:21.978123555 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.978097386 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP90
0:00:21.978133383 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat H264
0:00:21.978133033 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.978139254 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat VP90
0:00:21.978161937 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.978165894 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat VP80
0:00:21.978153351 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP80
0:00:21.978142260 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.978171785 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.978177516 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.978188025 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat VP80
0:00:21.978187474 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP90
0:00:21.978200919 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP80
0:00:21.978202642 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.978211629 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.978215276 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat H264
0:00:21.978215236 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.978217109 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP80
0:00:21.978231997 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H264
0:00:21.978224513 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:21.978238319 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:21.978242376 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat H264
0:00:21.978245693 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.978245092 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H264
0:00:21.978252766 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP80
0:00:21.978265680 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.978273234 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H264
0:00:21.978280187 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:21.978285427 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H264
0:00:21.978529061 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:src Unable to try format: Unknown error -1
0:00:21.978534371 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:21.978537767 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:src Unable to try format: Unknown error -1
0:00:21.978545742 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:src Could not probe minimum capture size for pixelformat NM12
0:00:21.978551092 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:src Unable to try format: Unknown error -1
0:00:21.978554839 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe minimum capture size for pixelformat NM12
0:00:21.978559107 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:src Could not probe maximum capture size for pixelformat NM12
0:00:21.978562303 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:21.978537907 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:src Could not probe minimum capture size for pixelformat NM12
0:00:21.978571971 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:src Unable to try format: Unknown error -1
0:00:21.978536134 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:21.978583252 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe minimum capture size for pixelformat NM12
0:00:21.978586107 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe maximum capture size for pixelformat NM12
0:00:21.978576699 9037 0x7f3f5400b400 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x7f3f400b4390 Failed to determine interlace mode
0:00:21.978594232 9037 0x7f3f48010520 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x7f3f3808bc80 Failed to determine interlace mode
0:00:21.978587760 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:21.978604982 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe maximum capture size for pixelformat NM12
0:00:21.978578302 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:src Could not probe maximum capture size for pixelformat NM12
0:00:21.978612055 9037 0x7f3f5400be40 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x7f3f44063a10 Failed to determine interlace mode
0:00:21.978616193 9037 0x7f3f5001d400 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x7f3f3c0844b0 Failed to determine interlace mode
In cb_newpad
In cb_newpad
0:00:22.090129255 9037 0x7f3f5400be40 WARN v4l2videodec gstv4l2videodec.c:1836:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:22.090161595 9037 0x7f3f5400be40 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:nvv4l2decoder1:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:22.090714546 9037 0x7f3f5001df60 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder1:pool:src Driver should never set v4l2_buffer.field to ANY
In cb_newpad
In cb_newpad
0:00:22.092026651 9037 0x7f3f48010520 WARN v4l2videodec gstv4l2videodec.c:1836:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:22.092041228 9037 0x7f3f48010520 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
In cb_newpad
In cb_newpad
0:00:22.098051257 9037 0x7f3f5001d400 WARN v4l2videodec gstv4l2videodec.c:1836:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:22.098076013 9037 0x7f3f5001d400 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:nvv4l2decoder3:pool:src Uncertain or not enough buffers, enabling copy threshold
In cb_newpad
In cb_newpad
0:00:22.098519930 9037 0x7f3f5400b400 WARN v4l2videodec gstv4l2videodec.c:1836:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:22.098546048 9037 0x7f3f5400b400 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:nvv4l2decoder2:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:22.117664844 9037 0x7f3f400ba760 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:22.117667810 9037 0x7f3f3c0914c0 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder2:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:22.117685192 9037 0x7f3f4406a9e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder3:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:22.257184243 9037 0x561c94b71400 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2922:gst_eglglessink_configure_caps: Cuda Init failed
0:00:22.257198119 9037 0x561c94b71400 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2933:gst_eglglessink_configure_caps: Configuring caps failed
0:00:22.257224057 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257277066 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257281545 9037 0x561c9485da40 WARN GST_PADS gstpad.c:4231:gst_pad_peer_query:queue6:src could not send sticky events
0:00:22.257796194 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257812394 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257820549 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257836930 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257844604 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257851607 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257858069 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257902722 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257911108 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257927468 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257934541 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257941514 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257947986 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257956422 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257963175 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257969567 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257976730 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257983042 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257989774 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.257997940 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258004632 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258011124 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258019410 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258033816 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258040870 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258047392 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258062159 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258068862 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258075494 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258082096 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258088669 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258095662 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258102194 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258108496 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258115308 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258122131 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.258129124 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.262696404 9037 0x561c9485da40 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps: Failed to configure caps
0:00:22.279977926 9037 0x561c94b71640 WARN nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:22.280043669 9037 0x561c94b71640 WARN nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop: error: streaming stopped, reason not-negotiated (-4)
0:00:22.280875699 9037 0x561c94b71760 WARN nvdspreprocess gstnvdspreprocess.cpp:2301:gst_nvdspreprocess_output_loop: error: Internal data stream error.
0:00:22.280891509 9037 0x561c94b71760 WARN nvdspreprocess gstnvdspreprocess.cpp:2301:gst_nvdspreprocess_output_loop: error: streaming stopped, reason not-negotiated (-4)
0:00:22.291778185 9037 0x7f3f60065cc0 WARN qtdemux qtdemux.c:6619:gst_qtdemux_loop: error: Internal data stream error.
0:00:22.291805176 9037 0x7f3f60065cc0 WARN qtdemux qtdemux.c:6619:gst_qtdemux_loop: error: streaming stopped, reason not-negotiated (-4)
0:00:22.291910662 9037 0x7f3f480106a0 WARN libav gstavauddec.c:628:gst_ffmpegauddec_drain:<avdec_aac3> send packet failed, could not drain decoder
0:00:22.293757053 9037 0x7f3f58023b00 WARN qtdemux qtdemux.c:6619:gst_qtdemux_loop: error: Internal data stream error.
0:00:22.293768885 9037 0x7f3f58023b00 WARN qtdemux qtdemux.c:6619:gst_qtdemux_loop: error: streaming stopped, reason not-negotiated (-4)
0:00:22.293812356 9037 0x7f3f5001d580 WARN libav gstavauddec.c:628:gst_ffmpegauddec_drain:<avdec_aac1> send packet failed, could not drain decoder
0:00:22.297078081 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux.c:6619:gst_qtdemux_loop: error: Internal data stream error.
0:00:22.297102036 9037 0x7f3f5c01a9e0 WARN qtdemux qtdemux.c:6619:gst_qtdemux_loop: error: streaming stopped, reason not-negotiated (-4)
0:00:22.297184239 9037 0x7f3f5400b580 WARN libav gstavauddec.c:628:gst_ffmpegauddec_drain:<avdec_aac2> send packet failed, could not drain decoder
0:00:22.299876595 9037 0x561cb4d201e0 WARN qtdemux qtdemux.c:6619:gst_qtdemux_loop: error: Internal data stream error.
0:00:22.299890261 9037 0x561cb4d201e0 WARN qtdemux qtdemux.c:6619:gst_qtdemux_loop: error: streaming stopped, reason not-negotiated (-4)
0:00:22.299933281 9037 0x7f3f48014800 WARN libav gstavauddec.c:628:gst_ffmpegauddec_drain:<avdec_aac0> send packet failed, could not drain decoder
when I debugged, the code gave warning and errors
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks.
  1. from the log, it is because elgsink failed to initialize. for test, you can use fakesink by setting fakesink=1 in deepstream_action_recognition_config.txt.
  2. please refer to this topic for eglsink 219 problem.
