The network-input-shape is batch, channel, sequence, height, width.
It is possible to set it to batch, sequence, channel, height, width instead without editing the custom lib code? I have a difference model and the input shape is different (NxDxCxHXW).
Hi @H19012
The custom-lib is for NCDHW only. so if you want NDCHW, you have to modify the source code. there are comments in source code to help user where to update.
