3D CAD STEP Model for Jetson Nano
I could not find the CAD STEP model for the Jetson Nano here: https://developer.nvidia.com/embedded/downloads
I would like to start designing a 3D printed enclosure for some project ideas (px4 redtail drone) and the STEP models really help get the design started :)
Hi Linux4all, we are starting to prepare a preliminary version of the 3D CAD STEP model for the Jetson Nano Developer Kit, please give us some more time to get it ready.
No problem at all dusty_nv. Much appreciation for the update.
By the way, in the meantime, you may be able to extract a preliminary model from this simulation of JetBot here…
https://github.com/dusty-nv/jetbot_ros#jetbot-model-for-gazebo-robotics-simulator
EDIT — official CAD model of the Nano devkit is now released here:
https://developer.nvidia.com/embedded/dlc/jetson-nano-developer-kit-3D-CAD-Step-Model
Perfect! Thanks dusty_nv. I will see if i can import into fusion 360.
I should be able to extract :) thanks again https://github.com/dusty-nv/jetbot_ros/tree/master/gazebo/jetbot/meshes
Hi! From the STLs provided by dusty_nv I was able to extract Jetson Nano DevKit. Further I simplified it a bit by removing the hidden geometry using Autodesk Meshmixer - See attachment.
From there it can be converted into a solid and imported to Fusion/Inventor.
Jetson_Nano_DK.zip (2.11 MB)
Nice work on this lmeinel. Much appreciated.
Hi, Any update on the step or 3D file. When can we expect the official 3D files?
Hi Roshan, the final version is still being prepared in preparation for the release of the production module, so for now please still use this preliminary version. It should sufficiently capture the footprint of the devkit.
Thank you. Please can you share the link for preliminary version files?
lmeinel / dusty_nv - Thanks for the Jeston Nano model. I used it to create the following enclosure if you’re interested:
Hi Roshan, please see these posts for the links:
Looks great 57Bravo, thanks for sharing! I’ve added a link to your enclosure on the wiki here - https://elinux.org/Jetson_Nano#Enclosures
Hi
Any update for Jetson Nano STEP file??
I drew the Jetson Nano 3D model use Onshape, you can export it to STEP file, if you want.^^
https://cad.onshape.com/documents/e3920b2376e4d0b20df8f75b/w/189b8d517d352f6233dbe546/e/e2e2bac2870d2c71f2489ddb
Great!!! Thanks for your help!!!
Dear Friend, thank you so much for your work and sharing this file
But after download and compared with the real jetson nano kit for developer here in my office
I found that the dimensions of your model “may” not accurate, do you have any official drawing and share with me please !?
Yes, it is not very accurate, I am also waiting for the official circuit diagram.
But It is enough for design of the outer casing i think.
Thanks a lot!
