3D Print Request: 10 inch rack mount for DGX Spark (link to design in topic)
Hello all,
I recently ran into a custom 10 inch rack mount design at Cults3D.com for DGX Spark that I like, but unfortunately do not have a 3D printer (or any requisite 3D printing experience) with which to print my own.
By chance, does anyone here have a 3D printer that can print from the design files at the provided link? Of course, I’d pay an agreed upon price, so feel free to message me.
I’m racking my DGX Spark in my 10 in DeskPI Rackmate T2, but currently it has to sit on a shelf. I’d rather have a custom rack mount for it.
I absolutely could print this but I have misgivings about the model. They adapted one which may have originally been from the minisforum MS-01. That model hugs the case on the sides and part of the top. I believe the entire case of the DGX Spark is effectively a part of the heat sink and intended to be open air exposed, or as much as possible.
For what it’s worth, I put mine on a metal shelf with some stops screwed through the holes in the shelf at the corners of the unit. This results in minimal contact with the case and basically no airflow disruption.
That’s a good point you make regarding making sure to not restrict airflow, since it can get pretty hot. I’m also running agentic sustained workloads, so cooling is a factor. Maybe I should think about this a bit more….
I have mine setup in a 10 inch rack as well, but have them on shelves and I have a 120mm fan blowing directly into the intake on both.
Really my dream would be for a 3U 3d printed 10 rack frame, with a slot for a 140mm fan slight gap and then mount for 2x Spark/GB10 devices. It would have to be a 10 inch rack depth but it should work and these get pretty toasty.
On this originally suggested rack, which is the same I am using, you can run shelves at half space intervals. So my Spark is using 1.5U. I’d still suggest two metal shelves, and then mounting maybe a pair of fans off the front if you like.
